2015 ford transit no crank/no start UPDATE
  • surplus238
  • surplus238's Avatar Topic Author
5 years 6 months ago #43158 by surplus238
Replied by surplus238 on topic 2015 ford transit no crank/no start
Hello again, no power at pin 37 but I am having a problem finding out what pins should show power, the ground look to be easy but check me if I am wrong. The grounds are, pin 50, 69 and 70. Should I go through the connector one pin at a time to see which ones have power with the switch on? While I was in there I checked continuity between my test connector and #29 fuse it is a good connection so the wire is good. If I were to jump that wire would the starter turn?
5 years 6 months ago #43160 by Chad
Replied by Chad on topic 2015 ford transit no crank/no start
Yes. The GROUNDS are Pins 50, 69, and 70. Powers are Pins 67 and 68.
In addition to jumping POWER to this circuit, you will also need to supply a GROUND on the yellow wire from Pin 7 to activate the RELAY. Alternatively, you you could pull the RELAY and supply a power, only, to the GRY/ORG wire going to the Stater Solenoid, from the relay. This should crank the starter, too.
  • surplus238
5 years 6 months ago #43162 by surplus238
Thanks Chad, I know the starter works, when I first started working on the cooling fan problem I bought a extra relay of each type and removed the plastic so I could work the relay with my finger. I will go out and check pin 67 and 68 now.
  • surplus238
5 years 6 months ago #43163 by surplus238
Hello again Chad, no power to 67 or 68 The grounds are good
  • surplus238
5 years 6 months ago #43165 by surplus238
Went out again to check the fuses. I did not know what condition to check the pins in but I checked them with the connector unplugged with the key in the on position.
5 years 6 months ago #43167 by Chad
Check with all connectors connected.
If you, still, have no power on Pins 67 & 68, then our next stop is the PCM Relay.
File Attachment:
File Name: 2015TransitEngine.pdf
File Size:986 KB
The following user(s) said Thank You: Yegorov
  • surplus238
5 years 6 months ago #43181 by surplus238
Fuse 35 is good and the connectors are clean, I don't have the aux battery system, will I still have the aux battery junction box? Next I will check for power at pin 5 of the PCM relay and get back to you.
Thanks
Bill
5 years 6 months ago #43182 by Chad
Do you get power on Fuse 35, with the key on?
I believe, you will.
  • surplus238
5 years 6 months ago #43186 by surplus238
Ok, checking this morning, with the PCM connector connected and the key on I have power on the two yellow with green leads, I have power on pin one at the relay and the relay seems to be working, when I turn the key on the throttle body makes noise. if I remove the relay with the key on it clicks off, when I replace it, it comes back on.
I think I should have power on the yellow/green leads at this time with the key on and I do.
5 years 6 months ago #43188 by Chad
surplus238 wrote: I have power on the two yellow with green leads
Where is this? Are you referring to Pins 67 & 68?
  • surplus238
5 years 6 months ago - 5 years 6 months ago #43189 by surplus238
I am probing the two yellow/green leads at the PCM connector with the key on. They should be pin 67 and pin68
Last edit: 5 years 6 months ago by surplus238.
5 years 6 months ago #43190 by Chad
Okay. The diagram says they should be Yellow/gray.
So, you have power on Pins 67, and 68. That's good. Make sure your Grounds on Pins 50, 69, and 70 are good. Do this by swithing your volt meter to milli-volts. Connect your volt meter BLACK lead to Battery (-). With the RED lead, measure the voltage on the GROUNDS at Pins 50, 69, and 70 ...WHILE THE KEY IS ON AND YOU HAVE POWER ON PINS 67 and 68. It is important that the PCM is receiving POWER when you do this. You want to see no more than 100mV, or so. The closer to zero, the better. Anything over 200mV is a concern.
If all that checks out, and you are getting POWER on Pin 16, when the Key is in the START position, but no Power comes out of the PCM on Pin 37, it's not looking good for the PCM.
Can you start the engine by turning the ignition to the RUN position and cranking the starter by applying POWER to the Gray/Orange wire on the starter Solenoid?
  • surplus238
5 years 6 months ago #43192 by surplus238
The engine will crank but will not start, by putting my finger on the relays I feel the #2 relay for the ign click and the throttle body hums but no start, I am having trouble blaming the PCM because the symptoms are the same as with the old pcm and it is a new pcm programed to my vin by ford and it acts the same as the old one.
I will check out what you have listed and get back to you.
  • surplus238
5 years 6 months ago #43198 by surplus238
Bk/gn 69 mv, Bk/yel .9 mv, Power on pin 16, no power on pin 37 key in start position. Are there any controls that could be getting to us? EG neutral safety, ect.
Keep in mind that the problem started intermitently and progressed to a no start condition.
  • surplus238
5 years 6 months ago #43200 by surplus238
Back again, I have looked at the diagram and it looks to me like I am looking at it backwards, should the power be coming in to pin 3 on the PCM relay and going out to the #29 fuse? If that is the case I have no power on the relay pin 3. That would be a problem in the aux junction box?
5 years 6 months ago - 5 years 6 months ago #43201 by Chad
The highlighted circuit is the Park/Neutral circuit. I'm not sure what voltage should be on this circuit. I would, simply, look for a "Change" from High to Low, or Low to High, while shifting from PRNDL Make sure the "change" is the same at all 3 point.
Do you see any signs of PATS? (Passive Anti-Theft System)
Last edit: 5 years 6 months ago by Chad.
  • surplus238
5 years 6 months ago #43204 by surplus238
No flashing light on the dash, my key programming device does not show anything and all the lights come on when the key is turned on and dim when pressed to start.
5 years 6 months ago - 5 years 6 months ago #43208 by Chad
Monde wrote: My question is: shouldn't we check for power on pin 7 and ground on pin 37?
You are correct. That is what we did in the second post of this thread.
Chad wrote: Do you have power on Fuse 29 when attempting to crank? If so, the PCM is sending power to the Starter Relay. If not, do you have power at Pin 37 of the PCM? If you have power at Pin 37 and Fuse 29, then that is good. The relay is getting control POWER (barring any problems with the relay socket). The Yellow wire should receive a control GROUND from the PCM on Pin 25. If you have power on Pin 25, while cranking, then the PCM is not providing a control GROUND.
By checking for power on Fuse 29, we are checking Pin 37, as Fuse 29 is powered by Pin 37.
Do to this diagram covering multiple engines, with a few differences, I mis-quoted the Yellow wire as being on Pin 25, instead of Pin 7.
5 years 6 months ago - 5 years 6 months ago #43210 by Chad
Monde wrote: My question is: shouldn't we check for power on pin 7 and ground on pin 37? Usually, in a relay, you always have both powers at the top and grounds at the bottom.
Re-reading your question, I see that you asking if Pin 7 is POWER, and Pin 37 is GROUND. Pin 37 CANNOT be a GROUND. If Pin 37 was Grounded, Fuse 29 would blow.
I'm not saying it isn't done but, I have never seen a fuse on the ground side of a circuit.
  • surplus238
5 years 6 months ago #43211 by surplus238
HI Guy's I want to thank you for all the help. I have found some damage in the wire's from the transmission, I have to get the rig in the air and check that out but I probably won't get back on until tomorrow.
Time to create page: 0.426 seconds
