1992 Corolla diagnosis
  • robert.whitman
  • robert.whitman's Avatar Topic Author
4 years 4 days ago #55339 by robert.whitman
Replied by robert.whitman on topic 1992 Corolla diagnosis
Condition is all the time warm or cold.
Should the green wire on the tps be 12v all the time or change with throttle position?
Yes 1.6.
Yes pinky finger size vacuum line right on the bottom of throttle body. Do you have a vacuum diagram? Noticed no line to throttle diaphragm..??
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 4 days ago #55340 by VegasJAK
Replied by VegasJAK on topic 1992 Corolla diagnosis
No not all the time. Just as the idle, blue wire, drops to 0v on idle, the green wire drops to 0v on throttle plate at 70° or more.
Both will have 12v between idle (1.5°) and 70°.
Clarify, you have no vacuum line from the throttle opening diaphragm to the throttle body?
  • robert.whitman
4 years 4 days ago #55341 by robert.whitman
Correct... No line to throttle diaphragm.
Doesn't even seem to have a nipple on it.???
  • VegasJAK
  • VegasJAK's Avatar
4 years 4 days ago #55342 by VegasJAK
Tried to find better pic... best I could come up with right now.
  • robert.whitman
4 years 4 days ago #55345 by robert.whitman
Yes I see. "Throttle open diaphragm" ??
The one on this car is different as there is no nipple or vac line. Seems strange to me as it doesn't seem to be doing anything no wires or vac line just a plunger on the throttle butterfly cam.??? I will try to post a pic after work.
  • robert.whitman
4 years 4 days ago #55349 by robert.whitman
Pic of mine
  • robert.whitman
4 years 4 days ago #55350 by robert.whitman
Maby mine has fallen apart?? Do you know where the other end of said vacuum line connects?
  • VegasJAK
  • VegasJAK's Avatar
4 years 4 days ago #55351 by VegasJAK
Toyota uses several different types of throttle openers. I believe yours does not have an external vacuum port but instead the TO uses throttle body internal vacuum to pull the spring loaded valve back... any way the reason for all this was to test the TP switch for correct positioning. Did you or someone tamper with or remove and replace the TO switch?
  • robert.whitman
4 years 4 days ago #55352 by robert.whitman
No tampering. To switch? Where is this located?
  • robert.whitman
4 years 4 days ago #55353 by robert.whitman
The car was running fine and all the sudden it wasn't.
  • VegasJAK
  • VegasJAK's Avatar
4 years 4 days ago #55354 by VegasJAK
The black box with the blue, green and brown wires. Bolted to side of throttle body with two screws.
  • robert.whitman
4 years 4 days ago #55355 by robert.whitman
Ok... Sorry I was confused...I thought you were referring to another part.... Any other ideas on what might cause it to idle good but sputters/stall when trying to accelerate? Will rev up fine if I open throttle by hand very slowly.
  • VegasJAK
  • VegasJAK's Avatar
4 years 4 days ago #55356 by VegasJAK
You reported that the 12v remains on the blue (IDL) wire when you rotate the throttle plate. You can test the TP switch by unplugging it. Use an Ohm meter on the corresponding TPS pins for the blue and brown wires you should have continuity with throttle shut and no continuity just a hint open. Suggested is to use a .035 in feeler gauge between the throttle stop. (for the hint open position). If you don't get the proper readings, the TPS is most likely gone bad. This is why the 12v stays on. It doesn't get pulled to ground. Hope I explained that well enough:blink:
  • robert.whitman
4 years 4 days ago #55357 by robert.whitman
Upon testing it while connected the blue lead is 0v closed throttle 12v throttle open alittle bit. I will check with feeler. I thinking now that it is operating properly and it is something else causing my issue... Any ideas?
  • VegasJAK
  • VegasJAK's Avatar
4 years 4 days ago #55358 by VegasJAK
EGR comes to mind. Not fully closed due to carbon buildup. Fuel pressure low. Don't believe the fuel system has a schrader valve to test from on your engine. Don't think it's the ecm though.
  • robert.whitman
4 years 4 days ago #55359 by robert.whitman
I don't think it is the ecu now either. I was confused by the 12v at the tps. Do you know where the egr is located? Also could ot be a distributor problem?
  • VegasJAK
  • VegasJAK's Avatar
4 years 4 days ago #55361 by VegasJAK
Unless it's a California version will not have it.
At this stage can't rule it out. Have to look but I think Paul has a video of his son's 92 or 94 Toyota with a dist problem. I think it was no start though.
  • robert.whitman
4 years 4 days ago #55362 by robert.whitman
I'm going to put the timing light on it tomorrow. It acts like an old car with a bad vacuum advance. I'll post after
  • robert.whitman
4 years 3 days ago #55386 by robert.whitman
Ok... Timing seems to be good. But pulled the spark plugs and they are black with carbon"not oil fouled" I just cleaned and re gaped the plugs the day after the car started having problems. It seems to me that something is causing an overabundance of fuel going in to the cylinders. I checked the cold start by taking it off and plugging port from fuel rail. No change. If I squirt the smallest amount of carb cleaner into intake while idlng it dies. Checked the fpr seems fine. Checked the fuel return it is clear. Anybody have any ideas??? Is there any way to test the components in the distributor?
Time to create page: 0.548 seconds
