Wiring Diagram Peugeot 4007
- Wightscope
- Thank you received: 30
4 years 9 months ago #49694
by Wightscope
Replied by Wightscope on topic Wiring Diagram Peugeot 4007
From your vid wire labels the feedback supply is pink and the yellow and purple are the outputs. Probably 5v so you will likely get 0.5-4.5v on pink-yellow and pink-purple. One will be the the opposite of the other and it will change according to valve position. I expect the next page to the one you show will give details.
- Nelixuk2003
- Thank you received: 2
4 years 9 months ago - 4 years 9 months ago #49725
by Nelixuk2003
Replied by Nelixuk2003 on topic Wiring Diagram Peugeot 4007
I have managed to spend some more time on the car this evening.
I checked the Resistance a pin 1 & 2 of the throttle body, unplugged at the component and i'm only getting 1.1 Ohms, AutoData quotas I should be seeing 3 Ohms.
I am seeing the voltages you describe on the pink and purple wires, Im not getting anything from Pin 1 (Green) other than slight voltage between .05 - .33 both with the ignition on and at idle.
I read the codes using DiagBox instead of the Verus Pro before taking any live data and the codes are as follows:
P2128 - Air Mixer butterfly valve position repeat fault
P0237 - Supercharging pressure sensor
P2111 - Air mixer motorised butterfly valve fault
P0488 - Air metering valve
I took a small video showing air flow and metering position readings using DiagBox:
I cleared the codes but have not checked them again following taking the video, I'll do that now and update the post.
Cheers
EDIT: DTC's Attached in screenshots
Cheers
Last edit: 4 years 9 months ago by Nelixuk2003. Reason: Add screenshots as attachments
- Nelixuk2003
4 years 8 months ago #49732
by Nelixuk2003
I forgot to mention that when I felt the motor of the EGR once the revs started to hunt, it was hot to the touch. Not so hot that you would burn yourself but hotter and expected, I realise that it’s connected to the exhaust but not sure it should get so hot.
- Wightscope
4 years 8 months ago - 4 years 8 months ago #49734
by Wightscope
WellI I would say that as you are seeing the PWM signal come into the throttle/butterfly, the resistance measurement is out on the motor and the ECU is saying there is a fault with it, then there are strong odds that it is faulty.
I would just double check that the "Air Mixer butterfly valve" is the part you are looking at.
Last edit: 4 years 8 months ago by Wightscope.
- T1000email@gmail.com
4 years 7 months ago #50643
by T1000email@gmail.com
Replied by T1000email@gmail.com on topic Wiring Diagram Peugeot 4007
I know it’s been a while but thought I would provide an update. The delay in progressing with this was due to finances, or lack of, however, based on the data a collected and the readings from the butterfly motor, plus the trouble Code pointing to the throttle body/butterfly, I took the risk and purchased a new throttle body, fitted it this evening and took it for a drive, got it up to temp and all appears good. I’m going to give it a few days of driving before I draw a line under it but up to now it looks like it’s fixed.
Yeah, I’m mobile again.
Took a resistance reading from pins 1 & 2 of the new throttle body to compare and was getting 6.7 ohms, higher then Autodata said it should be but very different from the old one.
Thanks for all the help guys.
Time to create page: 0.264 seconds
