Nissan Sentra 2008 P0300
- Mariowinax1
4 years 5 months ago #48710
by Mariowinax1
Nissan Sentra 2008 P0300 was created by Mariowinax1
Hey guys
Am having P0300 misfire code
Cylinder 1 and 4 is misfiring
Misfruing counter gave me that information and I checked its not firing when coil is removed and Crank to check spark but 2 and 3 is having spark.
Please can anyone help me probe this ?
Also can I get fsm or wiring diagram for the coil plug so I can check for continuity and wiring integrity
Thanks
Sent from my SM-G965F using Tapatalk
Thanks
- Mariowinax1
4 years 5 months ago #48717
by Mariowinax1
Replied by Mariowinax1 on topic Re:Nissan Sentra 2008 P0300
Swapped coils and even the spark plugs of the working cylinder 2 &3 to the non working 1 &4
Misfires didn't move
Is not a compression issue BTW because crank outside the hole of the spark plug is not even sparking light/ fire in 1&4
- jreardon
- Thank you received: 198
4 years 5 months ago #48718
by jreardon
Replied by jreardon on topic Re:Nissan Sentra 2008 P0300
www.nicoclub.com/nissan-service-manuals
It's a 3 wire coil - power, ground and control wire (0-5v pulses on scope). The control wire will be the color that's unique to all the coils. Run a headlight bulb across the power and ground to check power and ground. Check control wire for a signal with a meter you should get some voltage fluctuations like 0-.3v on a multimeter while engine's idling. 0v could be open, short, poor connection, maybe jump the control wire from a firing coil into the dead coil's control wire and see if it'll fire then. dunno where computer lives so do as much as you can at the coil.
The following user(s) said Thank You: Mariowinax1
- Mariowinax1
4 years 5 months ago #48719
by Mariowinax1
Thats great
Will look into it
Thanks
Will look into it
Thanks
- Mariowinax1
4 years 5 months ago #49005
by Mariowinax1
- Mariowinax1
4 years 5 months ago #49006
by Mariowinax1
- Mariowinax1
4 years 4 months ago #49370
by Mariowinax1
Fixed
Replaced PCM /ECM
Thanks everyone
Replaced PCM /ECM
Thanks everyone
