Could this be root cause? solved but some new codes-need hose identified
  • Sopey52
  • Sopey52's Avatar Topic Author
5 years 1 week ago #47779 by Sopey52
Replied by Sopey52 on topic Could this be root cause?
Time to throw in the towel. I thought I was making progress but I am not. It is not bad grounds and its way above my pay grade and not worth the time and money. This is one of 3 vehicles and my daughter just wrecked one of the three today. Fortunate that nobody was hurt. We are down to one vehicle now and its time for this Venture to go to the junk yard. Thanks very much for your time. I bought the book because I figured it was the least I should do since I was asking for help. Most of that book is way above my pay grade stuff I will never get into. I appreciate the time you folks put into videos. I learned alot but I also know this van is no longer worth the time and money. Thanks to Chad and Nelson for the time you gave me.
5 years 1 week ago #47781 by Nelson60
Replied by Nelson60 on topic Could this be root cause?
Thanks for the update but was hoping and wishing for a better outcome.
I find it difficult, and frustrating most times with trying to help online due to the fact I don't have the vehicle in front of me to personally see, hear, and feel the variables affecting it. I guess I would be a failure at a call center for auto troubleshooting.
The purchase of Paul's book will pay for its self in keeping your fleet running and out of the shops. Don't let the content overwhelm you, take a little bite out of it and practice some of the techniques and tests shown.
Glad to hear your daughter is fine after the recent crash.
Post back any questions you might have on a future car purchase you may be considering.
Nelson
  • Sopey52
5 years 1 week ago #47805 by Sopey52
My thread about my van is closed and likely because I said I wanted to throw in the towel. I am not going to give up just yet. It seems like I did make some progress. It runs longer when it does start. However I am frustrated.
DOES IT MAKE A DIFFERENCE WHERE THE GROUNDS ARE LOCATED?
On this 2003 Chevy Venture, G113 and G111 ( I just figured out) are on the same bolt and separated by nut. Thus there are two nuts on that bolt. I found a drawing online that proves it. G117 is slightly behind and above it. There are ground wires connected to 113 that are solid and clean looking and I can pull on them pretty hard. They stay connected. I cannot tell the difference between two identical looking, thinner ground wires that are around 20 or 18 gauge coming out of the same place in the loom. One of them is supposed to go to G111. and one is supposed to go to G117.
An earth ground was going to G117. I replaced it because it was corroded. Because I did not get any results, I decided to move it to G111.
My grounds may just be in the wrong place and/or I may have improved the ground wire connections but also screwed them up by putting them in the wrong place. Is there an easy way to test and figure out where each ground wire goes to besides tearing apart all the wire loom which is what a novice like me might have to do?
Also, if I replaced the earth cable from block to driver side of body opposite of battery and then I moved it from G117 to G111 as an experiment. Could I have created a new problem because G111 is on the same bolt as G113 and battery negative connects to G113?
So far i have improved the run time, I got rid of the security light. I still get a Battery and Low Fuel light. Once the van shuts off, it kind of acts like maybe I have a bad alternator but the alternator tests at 14.59 volts when running. After the van has stalled, the fuel pump will turn on and turn off an turn on and turn off but there is space between the on times and it no longer ends up sputtering on and off like a machine gun but it does have a sputter in it some times, just not nearly as extreme.
I hate going back and revisiting these ground wires because I have to remove the air box which includes unplugging mass airflow and removing 1/2 of the air intake hows with the air box and that is not easy at all because it is tightly surrounded by a fork of wire loom as the PCM sits on top of the air box. However, my problem needs to be ground wires or I am giving up and the van is going to junk yard.
How can I most easily figure out that I have the right ground wires in the right location?
5 years 1 week ago #47809 by Tutti57
Replied by Tutti57 on topic Could this be root cause?
The ground location doesn't matter, just that they are good. I'm not familiar with your other thread, but in general, if you can get to the component that isnt working, you make sure that it's on or supposed to be on, and make sure it has near battery voltage on the power side and near 0v on the ground side. The circuit has to be on and energized for this test to be valid.
The battery ground goes to the frame or chassis or whatever, and makes those parts also the ground, which is why it doesn't matter where it is.
As far as the alternator putting out 14v, it's possible that it's not enough current, but still shows the higher voltage. That same power and ground tests applies to the alternator. I bet a lot of alternators are replaced that just have a bad power connection or something, then they unknowingly fix the problem when they replace it.
Some research in voltage drop testing will help you out with your ground tests. Paul has some videos on it for sure.
The following user(s) said Thank You: Sopey52
  • Sopey52
5 years 1 week ago #47818 by Sopey52
Thanks for your time. Can you explain to me what causes a "ground loop" and what that actually is?
I was concerned that could happen if a ground is in the wrong place.
This Chevy venture has error codes that I will attach and it has evidence of patchwork done by previous owner within the wire loom. I will avoid reposting my videos of my decade long saga with reappearing elecrical gremlins which have now manifested themselves into the van begging to be sent to the junk yard because it has 200,361 miles on it. I thought I could maybe figure this problem out myself without having to put more money than its worth into it. I might as a question here and there but I do not think this van issue is a ground issue anymore. I was getting battery/low fuel/security and I managed to get the security light out of that equation. I do have fuel pump that wants to turn off and on and off and on when the van is not running when the key is in run. I at least got that issue to stop sounding like a machine gun with the fuel relay and fuel injectors included.
5 years 1 week ago #47823 by Tyler
Replied by Tyler on topic Could this be root cause?
Hey Sopey52! FYI, I merged the ground location thread into your original thread. Not trying to kill the conversation, but having multiple threads about the same issue/vehicle/repair makes it more difficult for anyone else to follow along.
Let me catch up with what you've posted so far. :cheer:
5 years 1 week ago - 5 years 1 week ago #47824 by Tyler
I tried to watch the YouTube videos you posted early on, but they all show as private? :unsure:
Doesn't really matter, 'cause I think you should stay on this path:
That's a perceptible symptom that can we can use to get some good direction. It's also conveniently testable from the underhood fuse box.
With the off/on symptom present, pull the fuel pump relay slightly out of it's socket. Not enough to disconnect the relay from the fuse box, just enough to get to the relay terminals with your multimeter.
Take voltage readings at all four terminals, long enough to witness at least one off/on cycle. Take note of the readings and report back. At least one is going to be changing. ;) Use the relay diagram on the top or bottom of the relay itself to tell you which terminal is which. Do not use a test light.
If getting to the relay terminals isn't possible, you can use the old trick of removing the relay and tying individual copper wire strands around each of the relay terminals before reinstalling. Just make darn sure not to let the strands touch each other or anything metal. ;)
There are also kits like this that make relay testing a breeze:
www.amazon.com/Lisle-56810-Relay-Test-Jumper/dp/B002MCX6LY/
Last edit: 5 years 1 week ago by Tyler. Reason: clarity and stuff
5 years 1 week ago #47827 by Matt T
Replied by Matt T on topic Could this be root cause?
Sopey52 wrote: This Chevy venture has error codes that I will attach and it has evidence of patchwork done by previous owner within the wire loom.
Those four codes are all 5 volt reference related. It's possible they've been set by testing so first thing I'd do is clear them out and see if they come back.
SI for P0122 and P0452 says if P1635 is also set troubleshoot it. Found this "diagnostic aid" for P1635/9.
If any sensor using a 5-volt bias voltage, such as the intake air temperature (IAT) sensor or fuel level sensor, is shorted to voltage, DTC P1635 may set in addition to DTC P1639.
This might be a rabbit hole but it'd be worth checking the 5V and low reference circuits.
  • Sopey52
5 years 1 week ago - 5 years 1 week ago #47837 by Sopey52
Possibly Solved....I need help identifying 2 breakers under passenger side of dash. When I flipped them after my test drive one of them was pretty hot. I think this could be involved in a 5v issue if they aren't plugged in correctly. Years ago, after the "electrical expert" had it, the module these two breakers was plugged into was hanging and I plugged it into the clips that hold the module in place. I also put black tape around the relays to keep them from coming loose. However, I never took them out and flipped them around until the other day and then I put them back the way they were because I figured I didn't solve the problem. Today I flipped them and my gauges did not go nuts since and I don't hear any fuel pump and relays and injectors flipping out while the key is in run. They did when I was shutting off before I flipped them.
I cleaned up and made grounds better through all of this but I do not think the grounds were my problem. I think my original problem its related to this. Thank you to everyone who has responded to my posts to help me think this through and not give up even though I was ready to throw in the towel.
Last edit: 5 years 1 week ago by Sopey52.
  • Sopey52
5 years 1 week ago #47848 by Sopey52
I didn't realize that changing the subject in a reply, makes it a new thread. I thought I was just making a subject of my reply to the original thread.
  • Sopey52
5 years 1 week ago - 5 years 1 week ago #47849 by Sopey52
So yesterday, DRY DAY, I made great progress and was able to drive the van for 12 miles but it did shut off a few times and I thought I tackled that with those two relay modules under the right corner dash because it seemed to make the guages stop acting up.
WELL TODAY IS A WET SOGGY DAY. I decided to start the van. I started right up on first key turn. I decided to let it sit and idle. That lasted about 5 minutes and it shut of. I did not see the message center "battery/low fuel/security" but the fuel pump was acting up. I started it again. I decided to take it for a ride. I went a bit further than I should have and it stalled out at least 4 times where I thought I might end up having to tow it. Same behavior as always for at least 10 years....won't crank, will crank, won't start, won't crank. Move the gear shift...won't crank, started in neutral...drove about 50 feet and stalled, got it turned aropund....got it back home with stalling and coasting....started in neutral....hard shifting some times.
Should I be using wet weather as a clue? I think made improvements but root cause of problem still remains. I also suspect I have a slightly greasy serpentine belt from changing power steering pump and accidentally spilling a bit of fluid. I also know I may have added to the problems by pulling a power stearing pump from a junk yard but I didn't want to put $140 into a new pump if this is going to go to the junk yard. The pump whines but it is gradually getting quieter.
I am really tired of revisiting those same grounds but I really made them as best as they could be. I think I have to get underneath and look for things to clean up. Wet weather has to be considered a clue as to the way it acted today because yesterday once I got it running, even if it stalled, it cranked right up with barely turning the key.
I will have to refrain from bugging you guys unless I can ask specific questions. For now I would really appreciate it if anyone can tell me what those two modules are under right corner of dash as shown behind the BCM in that previous video. I do not know if it matters how those relays are in (what is upside down or not)because only four of the 5 pins are being used. There are only 4 contacts for each of those 2 relays. Also, it is possible to plug both of those relays into the module and one could think they are properly plugged in the contacts could be completely missed plugging the relays into slots without contacts.
THIS IS IMPORTANT. Sometimes, when I start the van, the guages work. Sometimes when I start the van the fuel and temp stays floored. Sometimes the gear you are in does not light up. When I am able to start the van and all the guages work...I can drive it much further than when the guages arenm't acting correctly. Now the darn gauges sometimes don't work but the BATTERY/LOW FUEL/SECURITY, isn't happening.
  • Sopey52
5 years 1 week ago - 5 years 1 week ago #47879 by Sopey52
First off, thanks to Chad and Tyler for taking time to read and offer advice. Tyler, I want to get to the testing you describe but I think I need to buy a new multimeter. Also, I have spotted some issues I need to consider first.I managed to keep van running long enough to get the front right wheel up on 3 2x8s so that I can get a look at starter and the junction box under van behind driver seat where there is a module that accepts 3 plugs. 1 plug goes to fuel tank. 1 plug splits to fuel and then to rear brake (I assume its abs sensor) another plub has a single light green wire (possibly security, possibly ground that goes into the conduit that contains the one that split.1. The receptacle box looks fine. However, two clips or pins inside one of the plugs are pushed in and I cannot get the plug back into the receptacle without those 2 pins pushing in. I suspect this to be possibly part of the problem.2. This may also be a big part of the problem. I finally got to where I could get a look at the starter and the connections to it. It all rusty, corroded and green.I need to resolve these two issues before I go any further.
Last edit: 5 years 1 week ago by Sopey52. Reason: Attaching 3 photos.
  • Sopey52
5 years 8 hours ago #48062 by Sopey52
@Tyler
I am a bit intimidated by the fuel pump relay test you described. You said it was simple. I refrained from doing it until I just now bought another mutimeter because I think the one I have has issues. However, it does not seem simple. I need to ask, is this just to verify that the fuel pump relay is good? I replaced it with another one and it does the same thing. Honestly, i am a bit stupid on some things until I physically experience doing it at least one time. Also, I corrected permissions on my videos so that the ones I shared here show up here. I had marked them private for a while because I feel defeated and stupid.
Some of what I have done so far, I did not follow a step by step procedure that a mechanic may have followed due to weather and van being outside and I did not have a jack or did not have certain tools, etc or I was waiting for a part or tool to arrive and meanwhile decided to test some other things because I had time to do it.
So far I have gone in a circle. I had a day where I got the van to run and I drove it for 12 miles thinking I had it fixed and the darn thing stalled on a back road curve with the battery/low fuel/security happening and it was a dangerous situation where I was lucky to get it started, get it out of that location and drive it home stalling 4 times on the way.
Here is what I "think"..I don't want to say I know. Consistientlly there is the P0122 TPS low circuit a. and there si the P0452 fuel pressure low voltage. I am wondering if this is a separate issue from the security system shutting me down or I am imagining that the security system shuts me down. I have revisisted ground 113 and ground 111 and ground 117 several times. I am certain the ground 113 and ground 111 are the same location. I wonder why there needs to be an earth strap from ground 117 to the body ground on the left side of the vehicle when ground 117 is only about 4 inches away grom ground 113 that the battery negative is connected to.
Also, I replaced the power stearing pump during all of this because it was leaking. I replaced the cam position sensor because it was under the power stearing pump so I figured just do it. I replaced the starter because it was a rusty bolt and wire mess on the positive connections...I replaced the oil pressure switch because I could and I believe it looked like it was leaing....still no change HOWEVER, I suspect that every time I have the battery disconnected for a long time (more than one day) I end up having to put the vehicle through a relearn process because on that day that I was able to actually move the van and take a 12 mile trip I did what i thought to be a idle relearn process with the van connected to a jump via another vehicle after going through the entire key relearn process while connected to that jump. i only did this because I met a mechanic where I pulled the power stearing pump and told him of my ordeal and he told me that the relearn process a GM dealer might end up doing because maybe I screwed up my computer with a jump (had negative cable connected to battery instead of engine) or because battery was disconnected so long....he told me it takes a lot of power for relearn and he does his with a jump connected. Some of this may sound stupid or silly to you because you are a pro..but I am just telling you what I have done so far and well....I still can't get it to run for more than maybe 3 minutes right now and then I can't start it at all until I let it sit. When I did get it running for that 12 mile trip I tested the alternator with lights on, radio on, and Air Conditioning on and it read 14.59 volts on my multimeter. Also, I have observed a couple of pins inside the PCM harness that are not out to the edge as far as they should be and the rest are but I can't get inside the back of them to adjust them or I don't know how. Also, there is a set of 3 plugs under the van behind the driver seat where 2 plugs go over the fuel tank to pump and I believe pressure sensor and then one of them splits to where I believe may be the rear ABS sensor or maybe something with fuel pressure above that rear wheel because the gas tanks cap is above that wheel. One of those plugs has 2 pins that will not stay at the end of the plug and are getting pushed back when the plug is plugged in. Hopefully this all makes sense and does not read like rambling. Thanks for your time.
  • Sopey52
5 years 8 hours ago - 5 years 7 hours ago #48063 by Sopey52
I just want to let everyone know that I thought it was a good idea to make youtube videos but I marked them private for a while because 1. someone is posting strange looking links in my comments and those links go to what looks like under age porn. I reported it to youtube and they do nothing about it. 2. I kind of sound mean or cocky (because I am frustrated with this) and most of all I am pretty stupid and or making videos is not as easy as one would think once you push record. I sometimes end up saying the wrong words like "breaker" instead of "relay". I made those video links work again by marking them unlisted. Please ignore the links that someone is posting in my comments. I cannot delete them and reporting them does nothing.
Last edit: 5 years 7 hours ago by Sopey52.
  • Sopey52
5 years 7 hours ago - 5 years 7 hours ago #48066 by Sopey52
I feel that I need to crack open the PCM before I do anything else and try to do a video showing the two pins (inside one of the plugs not on the PCM) that I see are pushed back. I think one of them may actually be pin 1&2 that If I understand correctly is ground on this attachement. I feel like I need to correct those pins but I do not know how to get in to do that correctly without screwing up other pins. I am not sure pins are the correct term. If I remember correctly they are inside the clear terminal plug as there is a big terminal plug that is clear and one that is blue.
4 years 11 months ago #48147 by 70monte
Replied by 70monte on topic Could this be root cause?
If those pins are pushed in, they are probably not making contact and will cause problems. Whether they are related to your running issues will be determined by which circuit those pins are for.
Have you checked all of your power and grounds at the PCM?
A bad ignition switch can also cause a vehicle to stall. You need to check power and grounds going to and from this switch as well.
You have to be systematic when tackling this problem. Look at scan data and if there are trouble codes, could they relate to your starting and stay running problem? Look at wiring diagrams to see if any of the codes could affect your symptoms.
When it dies is it dying like power is shut off or more like a fuel problem?
Study voltage drop testing in Paul's book and elsewhere and do these tests on all of the power and grounds related to the starter system.
How old is your starter? You could have some internal electrical problems with it that could prevent the vehicle from starting.
Remember to do all of the voltage drop testing with the circuit loaded which means key on, engine off.
Do some studying on relay circuit testing. Paul has info on that in his book and on YT.
  • Sopey52
4 years 11 months ago - 4 years 11 months ago #48150 by Sopey52
I have visited every ground in this van except for any at the very rear. I have vistited the main grounds in the engine cabin several times. I do not believe it is grounds anymore. I have replaced the starter. It is not an expensive GM. It is a much cheaper new aftermarket starter I picked up on Verizon for under $50. It looks identical to the starter I pulled. Results have not changed.I am ready to give up once again. I BELIEVE IT IS THE SECURITY SYSTEM SHUTTING OFF MY VAN.Can anyone please help me identify these two relay modules?
Last edit: 4 years 11 months ago by Sopey52.
4 years 11 months ago #48157 by 70monte
Have you tested the power and grounds to and from the ignition switch? A bad one can cause intermittent start and dying problems.
Transmission range switch can also cause these problems.
At this point I highly doubt it's any of those grounds that you have continually messed with. You probably need to go away from that and focus on doing some testing at the components I mentioned. You need a good wiring diagram of the starting system.
  • Sopey52
4 years 11 months ago - 4 years 11 months ago #48273 by Sopey52
@70Monte ....Funny you mentioned Transmission Range Sensor. I had to deal with that on our Focus this week. So I was wondering if I could have an issue there...however I can read that many sensors can cause my issues I am experiencing with this van. On the Focus, I just cleaned it up and reseated it and so far so good. It may have been banged up a bit from fender bender, included a cv axel break, a year ago and there was sludge all over it.
UPDATE UPDATE UPDATE.....I managed to get rid of 1/2 of the codes and still have the P0122 Throttle positions sensor low voltage and the P0452 fuel pressure circuit low. I also found a way to get my security light to stop being part of the rotating Battery Security Low Fuel by pulling the PCM Program fuse and moving the key to the accessory position and then plug that fuse back in. It was just something I decided to try on a hunch because the manual says to pull that fuse with key in accessory to customize settings which include the alarm and or disarming the alarm. So then all I see is battery low fuel battery low fuel...I can get the van to start but it only runs for a couple of minutes and then shuts off. Then it is difficult to start but then shuts off. Eventually the Security light comes back to that sequence but does not stick around. It eventually goes away until I can finally get the van to start and run a bit and if it stalls Security is there with Battery and low fuel until I turn the key off..but then if I put it to run I only see battery / low fuel/battery/low fuel. So now Security only shows up after the van shuts off instead of being there all the time.
GROUND WIRE DISCOVERY....as far as G117, G113....I visited a Pontiac Montana and noted how those wires were compared to my van and I made mine identical WHICH INCLUDES that the earth strap from block to body I had replaced with a heavy duty ground wire is not even present on the montana...thus someone (previous owner) added that earth strap from G117 to body ground on my van. I removed it for now. Nothing has changed except that I did get rid of those PCM 5v type codes.
I need to find where G103 and G104 is located on my van because I seen a chart that says those ground locations are fuel relay and fuel pump related. I cannot find them on any chart anywhere. Can anyone access any information as to where these ground locations are at on a 2003 Chevy Venture Warner Bros edition?
  • Sopey52
4 years 11 months ago #48370 by Sopey52
I don't even know if there is a G103 and G104 on this van. If there is one I cannot find it. I want to stop playing with grounds but I keep coming back to them and especially after an experience I just had with my wife's Jeep where it would not start and absolutely nothing, including the electric locks would work. She had someone try to jump it before I got there and they must have had a bad jump cable. First i tested the battery and it read 12.59 volts. It should have hit me but it did not hit me until later. I was able to jump it because I had a good jump cable. I could have simply taken my battery negative to body ground on the jeep and realized the problem...the battery to body ground on the jeep was bad.
This is not the problem with my Chevy Venture HOWEVER, It leads me to realize that I neglected to check the entire battery negative cable because it is burried inside conduit and runs down deep and along the bottom of radiator area to the block on the right side of the starter. Both ends seem fine but.....my van will only achieve spark when a jump from another vehicle is connected. THERE IS A LONG STORY HERE as to all the things I have done in the past 2 weeks. I will need to make another video....today I got the van to run for 10 minutes and was going to drive it but.....it overheated....and for some reason it will move but not fully in gear and very rough shifting like very hard shifting because I am stuck in fast idle....I decided to replace the TPS....I need to make a video and explain it all better as I am not a good book writer.
Time to create page: 0.562 seconds
