Cannot fix Single cylinder misfire under load.
- JoshuaK
- Thank you received: 5
You'll probably need to hook up a scope to your ignition and fuel injector controls and use long wires so you can see it while replicating the fault condition. See if either are cutting out.
- Hardtopdr2
- Thank you received: 148
- type3sqr
It's looking like you have a no-spark misfire, because if it were no-fuel, the fuel trims on Bank 1 would likely be more positive than they are.
What are your fuel trims during a heavy misfire?
I appreciate you pointing that out. Like I mentioned, I’m not familiar with what to look for with this type of system. Is there any way to see secondary ignition with backprobes, or do I need to get an amp clamp? I’m using a picoscope 2204a.
- type3sqr
What you should do is unplug the 2 fuel injectors for cyl #3 and go for a test drive and see what the fuel trims are while going up a hill, and compare that to what they are when everything is plugged in (if the same, it would suggest a no-fuel misfire, and like I said before, I think the direct injector is what would be used under load like this). Next, you can disconnect the connector for #3 ignition coil, and see what the fuel trims are. This should give you direction.
I’m not sure I can do that without de-pinning the connectors. Direct injectors are under the intake and each bank has one plug into the main harness. Port are easier to get to but still just the single plug per bank for the injectors. Coil pack is fairly easy to get to.
How would I go about testing with a scope?
- JoshuaK
As for spark: Since you've swapped/replaced coils and spark plugs, you shouldn't be concerned with secondary ignition, but rather ignition control coming from the ECM/PCM. You can test both control as well as current to see if the primary side is working. Current is tested via a current clamp, and often the best way is to install a fuse buddy at the fuse that powers the ignition coils (and you can do the same for fuel injectors), and use your current clamp on that wire that goes between the 2 terminals on the fuse.
- type3sqr
You may have to de-pin wires at the PCM/ECM or any connector along the way that you can access.
Ok, I’ll have to order an amp clamp.
Can I also measure resistance in the trigger wires from the ecm to the coil? It’s an intermittent problem, so if the wires are the issue, im guessing I’d see a slightly higher resistance than the other trigger wires?
- JoshuaK
FYI: My Hantek current clamp is a copy of the Pico and it works well, for $60-80.
- type3sqr
Do you have a 3- or 4-wire coil? If so, the trigger wire is very low current -- it's just a 4-5v signal firing a transistor in the coil, so resistance isn't going cause this kind of a fault.
I’m making assumptions honestly. If I have an intermittent issue with a misfire with only one cylinder and I’ve tested the coils, plugs, ecm, valves and compression, then I’m looking at a wiring issue right?
That why I asked about testing resistance. I figured I’d see a difference between that cylinders trigger wire vs the others.
To be realistic, I’m not sure what to actually test. I don’t mind ordering another tool if need be, I just haven’t had a chance. My wife’s parents died last year and we just got back from their estate where we had to clean it up and have a sale. Luckily that went well and we’re now back at home where I can concentrate on fixing this thing. But again, I just don’t know where to look. I’ll order the hantek clamp today, I just want to make sure the connection is correct.
Btw, it’s a 4 wire cop
- JoshuaK
- type3sqr
I think looking at the ignition and injector current patterns during your fault condition is the next step. If those both look good, then it must be a compression problem. Have you swapped or replaced the #3 direct injector? Another thought is you could unplug all the direct injectors - perhaps the car will run on the port injectors as a back-up, and if you don't have a problem, then that tells you it's injector #3 or the control to it (unlikely).
Ok. I got the amp clamp today. I gotta make a loop for it since i didn’t want to spend $20 on a piece of wire and then I should be able to test the current on the injector circuits as well as the coils. I am assuming I’m looking for cylinder 3 to mot match the other 5?
As far as compression is concerned, I did a compression test and got 150 psi. To confirm good compression, I also did a leak down on all three of bank one cylinders and they were all the same with a leak percentage of about 3-4 percent.
- JoshuaK
Testing compression isn't useful because this problem only happens under load / i.e. high cylinder pressure. My guess is the problem is not compression. If you can't find the problem with spark or fuel, perhaps then you'll be replacing rocker arms, valves, and valve springs.
- type3sqr
Correct, during your fault condition, you're looking for the current ramp pattern to to match the other 5 injectors.
- type3sqr
This threw me off because I was expecting to see an issue on 3, so I kept retracing wiring to make sure my trigger was on the right injector.
I will to to do the other idling tests today to make sure I have it all hooked up correctly and then I will drive it and get it to do it’s thing.
- juergen.scholl
- Active partschanger
- Thank you received: 462
You may have to account for that the injection event does not take place anywhere near TDC compression, especially on port injection but often time also on GDI, depending on the operation mode. So make sure your sync event really happens when it it should in order to get the cylinders identified corecctly.
Eventually you may want to sync on a specific coil using the trigger signal or a secondary wand/probe, just to avoid possible confusion.
- type3sqr
- type3sqr
- type3sqr
After restarting, I drove home just a few miles away. When I pulled into the drive, I could feel the miss at idle. I watched the scope and could see there was no spark on 3. I blipped the throttle and the spark came back. Why would it do this?
I haven't done the tests on the injectors, but will try to do that today.
- juergen.scholl
Or there is a problem = voltage drop or on the positive or ground side leg of these specific #1 coil circuits or it's the coil itself that got higher primary resistance than the other coils thus limiting current flow. Voltage drop testing will be your friend....
I didn't follow this thread from the beginning so I have a couple of questions:
Is the #1 coil same brand as the others?
When swapping coils will this #1 coil while put in another cylinder draw less current as well?
Will another coil put into #1 cylinder now draw less current than it did in the cylinder where it came from?
- juergen.scholl
The coil may be shut down intentionally, you may want to check/verify that the injector is also shut down at the same time.
- type3sqr
The coil in question is a denso coil. I have replaced the coil on 5 and that is the only one that is aftermarket. I have swapped coils and plugs previously and the problam has always stayed on 3.
