Ignition fuse blows during cranking
- Thank you received: 1117
- Fred975
- Thank you received: 4
- Fred975
Any other tips why I see the short in fuse 40 is seen when I place a test bulb instead of fuse 40. What else should i Look at?
Possibly because there is a path to ground through the control side of the oxygen sensor heater relay.
You can remove that relay and see if the bulb doesn't quit.
If there was a true short to ground in that circuit, the fuse would open with the just the key on. It wouldn't matter if the engine was cranking.
- Fred975
PCM
O2 sensor relay
Ignition coil
Alternator
Fuel pump relay
I agree O2 sensor has solid ground but I did remove the O2 relay and I even cut the Blaclk and white wire ( power wire from F40) to isolate the short. Also I have cut the black /White wire feeds the ignition coils to isolate the short so Right now I have only power going to fuel pump relay and Pcm left connected, but still the bulb illuminates. I tested the wire to PCM and it is not grounded but still the bulb stays lit. Talking to you helps me think out of the box.Please keep suggesting other tips and hopefully with your guidance I isolate the short. Thanks agian.
And with this wire cut, does the fuse also open while cranking the engine?
I'm having trouble finding a detailed power distribution diagram. The color one from Mitchell just has an arrow that says "engine controls, starting/charging".
- Fred975
The short is still evident anb the light bulb is still lit. The answer is yes. How did you paste the diagram?I have the power distribution diagram I use Alldata they hve all diagrams for 2004 Suzuki grand vitara 2 wheel drive ( rear wheel drive). May goal to is shut off the that bulb light becaues it show the short still active. Do you agree?
The goal should be to get the car running, I honestly don't care much about what the bulb thinks if the fuse doesn't blow...
You will have to save the diagram as a .png .bmp format, then click the tab that says attachment, find the file you want to upload, then click insert.
- Fred975
I have already lost one PCM and I am on my econd computer because of this short issue and fuse blowing. That is why my priority is to take care of the short and get the light bulb to turn off first otherwise I will burn the second PCM. As you may know for Suzuki since nolonger is made in USA it is hard to find parts. But I do appreciate you are providing tips to guide me through to find a resolution for the short. do you have the ignition circuit what else could be causing the short? thank you so much. Do you need tme o send you the power distribution.
- Fred975
I found it with an ohm meter in the fuse box on the leg of the fuse that feeds the PCM
You can see here it's a dead short to ground.
Not sure what a good circuit would look like, I did the same test on the TCM fuse that did not have a problem.
I then reset the min max values and began wiggling the harness.
You can see the max value changed when I was close to the short.
This test may or may not be helpful. While I agree the bulb should not be lit during your testing, I'm still very confused as to why the fuse only blows while cranking...
- Fred975
- Rickyrick
- Rickyrick
think about running a thick bead on a board 2 feet .introduce current to the bead , now run many bead off of main bead to different circuits , it will send current to those circuits electrical properties of the silicone !!!
- Fred975
- Rickyrick
- Fred975
While silicon used on computer boards is a semiconductor, I'm quite sure dielectric silicone grease is an insulator. It is used on electrical connections for it's water repellent abilities....i have seen problems where too much DIE -ELECTRIC SILICONE GREASE bleeds over to another nearby slot , connection , wire etc. thats another reason why you always use this stuff minimally and sparingly ! lol
Try a dab on the brushes of a DC brush type electric motor, like a blower motor.
