Testing fuel injectors with a knock sensor
9 years 10 months ago - 9 years 10 months ago #4607 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Testing fuel injectors with a knock sensor
To get any further forward I am going to wait until I get a more suitable cables to reliably connect a 3.5mm audio jack to BNC I have also ordered a new USB Sound Adapter as the one I was using fell apart. The idea of using a headphone jack splitter also occured to me and I have one on order.
The frequency range of the injectors pintel movement "click" is roughly in the range 2.5khz to 10khz. I have experimented with various software filters but the back ground noise on the trace on a running engine has the same frequency so I suspect the noise on the trace is actually due to echoes within the fuel rail.
Last edit: 9 years 10 months ago by Andy.MacFadyen.
9 years 10 months ago #4608 by Andy.MacFadyen
Clearly shows non-firing injector -- but no way to identify cylinder without another channel to give synch to firing order.
I would preffer this test over a FirstLook sensor on the fuel rail pulse damper..
  • Tyler's Avatar Topic Author
9 years 10 months ago #4611 by Tyler
Replied by Tyler on topic Testing fuel injectors with a knock sensor
Andy.MacFadyen wrote: would preffer this test over a FirstLook sensor on the fuel rail pulse damper..
Totally agree here. I find this method to be much easier to interpret, with less work required. But, like you said, we then get into noise and background interference :unsure:
9 years 9 months ago - 9 years 9 months ago #4726 by Tyler
Anyone sick of this yet? 'Cause I'm not! :cheer:
Got the chance to play with this on a Chrysler Sebring, 2.7L. Customer complaining of a misfire, and it actually had a #5 injector code stored. Really, the diagnosis was pretty straightforward, but I wanted to have a look anyway.
The trick here is that this engine uses plastic fuel rails (one for each bank), with a metal tube connecting between them. This ended up changing the quality of the waveform quite a bit.
Here's what I ended up with during the misfire. The knock sensor is up against the metal pipe in this capture, triggered off #2, firing order 1-2-3-4-5-6.
Admittedly, this one is very tough to call useable. :( After having looked at these a few times, I can say that #5 is definitely not opening, but what's up with #1? I can barely distinguish it from #5. If I didn't have the injector code to guide me, I might be tempted to say there's a problem with #1, too.
So, it doesn't work perfectly in every scenario. Variables, always variables. :lol:
Last edit: 9 years 9 months ago by Tyler.
9 years 9 months ago - 9 years 9 months ago #4730 by Andy.MacFadyen
The new USB Soundcard and cables arrived yesterday the soundcard cost a whole £1.50 including postage :-) I did a quick test using the soundcard oscilloscope program and the electronic stethoscope, The program let me save as a wav audio file. I then analyzed the frequencies using the Audacity sound program.
Most of the sound lies between 1500 and 8000hz which probably explains why most of the knock sensors wouldn't work for Tyler as from info on the web it seems most older style knock sensors are tuned to narow frequency band around 10,000 to 11,000 hz.
Last edit: 9 years 9 months ago by Andy.MacFadyen.
9 years 9 months ago #4731 by Andy.MacFadyen
Difficult call Tyler but a really good one. I was also sometimes getting results that showed a weaker signal on one injector that I couldn't explain but using the electronic stethoscope seems better.
Also even with Owon which is the fastest of my I have noticed that having the scope time base too long can cause loss of detail. I have tried my little DSO201 Nano and found while it was just about Ok on a single injector pulse it really isn't up to the job of looking a a parade of signals. I also dusted off my Hantek and found it surprisingly good.
9 years 9 months ago #4743 by Tyler
Andy.MacFadyen wrote: Most of the sound lies between 1500 and 8000hz which probably explains why most of the knock sensors wouldn't work for Tyler as from info on the web it seems most older style knock sensors are tuned to narow frequency band around 10,000 to 11,000 hz.
Nice! :ohmy: I just figured they were failed knock sensors, but this explanation makes much more sense. :lol:
Would the frequency of the knock sensor required vary based on the engine application? Wondering if the knock sensor I'm using is from a smaller Honda I4, and thus tuned differently than the others that likely came off Nissan and Ford V6's.
I'm glad you said that, 'cause I've had the same issues with getting a good parade pattern. I've found that, on my Modis, the trick is to use a fast timebase (50ms-ish) then zoom out for a good picture. I think the 200ms timebase I had on that Chrysler capture was too slow, and I lost detail because of it. :(
9 years 9 months ago #4798 by jose.alers
Replied by jose.alers on topic Testing fuel injectors with a knock sensor
Is the wire from the knock sensor installed somewhere?
9 years 9 months ago #4839 by Tyler
jose.alers wrote: Is the wire from the knock sensor installed somewhere?
You mean, the single wire from the knock sensor itself? That's where the yellow trace in my captures is connected. No other connections for the knock sensor were used.
The following user(s) said Thank You: jose.alers
9 years 9 months ago - 9 years 9 months ago #4923 by Andy.MacFadyen
I had an hour or so spare yesterday to continue playing around with this on a bench test, using the £20 electronic stethoscope.
The yellow channel is by capacitive coupling a simple using metal clip round the plastic body of the injector.
Looking at the two signals together is interesting and makes the trace from the electronic stethoscope easier to understand.
9 years 9 months ago #4929 by Tyler
That's beautiful, Andy! :woohoo: It's interesting how this capture seems to show more noise from the injector opening, than from the injector closing. Wondering if injector design plays into this?
Also noticed that the commanded injector on time is around 8ms in this capture, but between the cursors on the stethoscope seems to be closer to 10ms. Great example of how the commanded on time you'll see on the scanner doesn't directly translate to injector open time.
We've been able to see pintle humps in current and voltage waveforms, but this method really illustrates what the pintle is doing when the injector is commanded to open.
9 years 9 months ago - 9 years 9 months ago #4993 by Andy.MacFadyen
I think I have more or less gone as far as I need to go with this method for anything I am likely to have to deal with.
The scope set up that seems to work is;
Horizontal Time base 20mS/div -- screen time = 0.3 seconds.
Channel 1 (red) Connected to the Gunson Electronic Stethoscope 200mV/divsion
Channel 2 (Yellow) 200mV/div connected indirectly to injector by a capacitive clip this works well with plastic bodied Bosch pencil injector
Trigger from Channel 2 set at 600mV rising.
The Gunson Electronic Stethoscope
Simple t
Tool clip used for capacitive coupling to injector for trigger
9 years 9 months ago - 9 years 9 months ago #4994 by Andy.MacFadyen
Electronic Stethoscope Held Firmly Against Fuel Rail Pressure Pulse Damper
