Will the Hantek 1008C show 4 spark traces at once?
  • pickle
  • pickle's Avatar Topic Author
8 years 8 months ago #12708 by pickle
Will the Hantek 6022BE do what I want? It appears to have vastly superior specs to the 1008C in regards to Mhz and sample rate. I can buy one in Canada which would make returning it more of a possibility if I got another dud.
8 years 8 months ago - 8 years 8 months ago #12709 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Will the Hantek 1008C show 4 spark traces at once?
The spec is much better on the 6022BE the only thing I haven't been able to verify is the maximum input voltage it can survive without an attenuator. That isn't a major issue you would just have to use a cheap x10 or x20 attenuator when connected to fuel injectors and coils. Being a not a specialist automotive scope it will probably lack the x20 scale but it is just a case of using the x10 scale and multiplying by 2 . Link Attenuator Thread
The 6022 software will also lack the scale for the ignition HT but that shouldn't be a problem.
If you buy 6022be from Amazon and don't like it a refund should be pretty easy.
Last edit: 8 years 8 months ago by Andy.MacFadyen.
  • pickle
8 years 8 months ago #12714 by pickle
Thanks Andy. I ordered the 6022. I have a 20:1 Attenuator already. Hopefully this one works properly. The last one couldn't even read its own self generated square wave without hanging up.
If it doesn't work out Amazon is good about returning things.
8 years 6 months ago - 6 years 5 months ago #14178 by 1971rscamaro
Replied by 1971rscamaro on topic Will the Hantek 1008C show 4 spark traces at once?
I have the 6022be scope. By the BNC jacks on the scope it says 35 volts ac/dc max.
Last edit: 6 years 5 months ago by 1971rscamaro.
8 years 6 months ago - 8 years 6 months ago #14179 by Andy.MacFadyen
I ocured to me the other day that the cause of the 1008 crash might be USB 5V supply voltage drop due to computers USB port being over loaded.
Last edit: 8 years 6 months ago by Andy.MacFadyen.
8 years 6 months ago #14181 by 1971rscamaro
The 6022be USB cord has a y connection for the computer. You can use 2 USB ports if you need extra power.
8 years 6 months ago - 8 years 6 months ago #14182 by 1971rscamaro
The cable looks similar to this one.
USB cable
Last edit: 8 years 6 months ago by 1971rscamaro.
7 years 3 weeks ago #28844 by ARJAY
Hello. Did you get the Hantek 6022 and if so does it work OK for auto diagnostics?
You indicated you are in Canada, I live near Victoria BC. Thanks.
7 years 3 weeks ago - 7 years 3 weeks ago #28845 by Andy.MacFadyen
Even the improved Hantek software is horrible to use. The Hantek will show a train of secondary ignition traces on a single channel although the detail isn't great because of the way the Hanntek 1008 works. On the 1008 if you use 4 channels the sampling frequency for each channel is divided by 4.
With coil on plug or wasted spark there isn't really any need to look at multiple secondary traces although you may often want to use another channel(s) for say an injector or cam or crank signals.
With old style distributor ignition looking at the secondary trace from the coil (king) lead and one individual cylinder at time for synch is the normal way of working.
Last edit: 7 years 3 weeks ago by Andy.MacFadyen.
6 years 5 months ago #35411 by Batiscafo
Hi, I agree that Hantek have lots of things that leave a lot of more work.
The manual in my opinion is almost useless,
I got it to shoe the complete set of cylinder's sparks in one screen by using the two inductive Hi voltage/secondary ignition set up on 10,000 on Scope and the leads one in CH-1 as a trigger placed around cylinder number one in the spark plug wire to that cylinder. It is set up as the trigger.
The second Hi voltage probe (exactly same as on number one cylinder is HT-25) I set it around the Hi ignition wire from the Ignition coil to the distributor.
Get the proper and same time sweeping on the Hantek and you can get a full parade of spikes with the first one being number one and the other just follow the ignition order of that engine.
The HT-25 is about $18 in eBay or amazon.
Now I have several issues with the software, e,g, the recording so you can stop the motion and see in detail the problem with the firing voltage.
Anyone that can help with that?
it is a shame Hantek cannot spend the time to fix the software and the manual, excellent product if you can get it to run at all.
6 years 5 months ago #35417 by 1971rscamaro
By the bnc connectors on my Hantek 6022BE is labled max input 35 volts.
6 years 3 months ago #37007 by Grunter
Just wondering if those still struggling with Hantek software have seen this? I believe this is a great improvement.
The following user(s) said Thank You: Dylan, Batiscafo
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
6 years 3 months ago #37017 by Dylan
I also saw this a few days ago. You beat me to it :) Maybe you should've started a new thread. Thanks for sharing. Guess we need some feedback now from the guys that use Hantek. I think it's also compatible with some other scopes but I don't know which ones.
The following user(s) said Thank You: Grunter
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
6 years 3 months ago #37018 by Dylan
HScope Android
play.google.com/store/apps/details?id=com.martinloren.hscope
Supported hardware:
- HS10X (DIY Oscilloscope www.martinloren.com/hs10x-diy-oscilloscopes )
- Hantek 6022BE/BL
- SainSmart DDS120 / Rocktech BM102
- Voltcraft DSO2020
- ARMFLY AX-Pro
- Hantek PSO2020
- Hantek 1008
- Hantek iDSO1070 / Saluki MO1072
- Instrustar ISDS205A
- Owon VDS1022
- Loto OSC482
- Loto OSC802
6 years 3 months ago #37027 by Andy.MacFadyen
1971rscamaro wrote: By the bnc connectors on my Hantek 6022BE is labled max input 35 volts.
With normal non-automotive labscopes when looking at injector or coil primary wave forms using an attenuator is needed to be sure you don't spike the input circuits of the scope. This especially true with common rail diesel injectors.
Time to create page: 0.546 seconds
