Dodge Nitro diesel
5 years 3 months ago #45511 by Hardtopdr2
Replied by Hardtopdr2 on topic Dodge Nitro diesel
What year and size engine do you have?
  • mashili
  • mashili's Avatar Topic Author
5 years 3 months ago #45512 by mashili
Replied by mashili on topic Dodge Nitro diesel
It's a 2008 2.8 litre diesel
5 years 3 months ago #45515 by Hardtopdr2
According to the not so helpfull owners manual i looked up it only has the under hood fuse box. (I personally dont believe this as there should be one for interior items and options. Have you looked up under dash , under drivers/passenger seat, under back seat?
The down side i am seeing is the tipm. These are notorious for relay issues for the permanently mounted (soldered on) relays having issues / failing. (This would cause no power to injectors via the auto shutdown relay or a related circuit issue)
www.eautorepair.net . this will have your info needed for diagrams and any possible fuse box locations for your vehicle. As well as recalls, tsb's, and maintenance info for any trouble codes you may have as well as wiring diagrams.
  • mashili
5 years 3 months ago #45518 by mashili
Morning! Thanks for the information will check
  • mashili
5 years 3 months ago #45526 by mashili
I have removed all the seats but no fuse box in the interior
5 years 3 months ago - 5 years 3 months ago #45537 by Hardtopdr2
Ok let me look some stuff up for it. I did find maint info for a 07 nitro diesel. I will post the link to it in a little bit.
Last edit: 5 years 3 months ago by Hardtopdr2.
  • mashili
5 years 3 months ago #45539 by mashili
Thank you! I think even something for 07 can assist
5 years 3 months ago - 5 years 3 months ago #45540 by Hardtopdr2
No eBay APP ID and/or Cert ID defined in Kunena configuration
here's a link to the ebay page for the manual on cd just make sure to ask seller if it includes the 2.8 liter diesel in the cd otherwise the 2007 should have it. the other source I found was a sketchy website that when i revisited it made me believe it was a fake site to scam cc numbers.
hope this helps
5 years 3 months ago #45543 by Matt T
Replied by Matt T on topic Dodge Nitro diesel
If the injectors are two wire I wouldn't expect to see 5V on them.
www.autonerdz.com/yabbfiles/Attachments/CRD.pdf
I haven't been able to find a wiring diagram for the diesel Nitro or Jeep KK. The '07 gas shows a 5V supply to APP1, CKP and TPS on a brown/orange wire. Do you have 5V on the CKP now?
  • mashili
5 years 3 months ago #45544 by mashili
I have 4.9V on brown and blue /yellow CKP. The injectors are two wire
5 years 3 months ago #45545 by Matt T
mashili wrote: I have 4.9V on brown and blue /yellow CKP. The injectors are two wire
If that's unplugged it'll likely be Vref and a pull down signal wire.
Is P0698 still setting? And what other symptoms do you have?
The following user(s) said Thank You: mashili
5 years 3 months ago #45546 by ivoalaska
Replied by ivoalaska on topic Dodge Nitro diesel
Autodata have Chrysler Grand Voyager diagram for 2.8 diesel, its the same engine.
  • mashili
5 years 3 months ago #45549 by mashili
It is not!
  • mashili
5 years 3 months ago #45552 by mashili
I have found it bad it's not its not giving me a detailed report on injectors. The one I have is a 3.40 version
  • mashili
5 years 3 months ago #45591 by mashili
Morning! The P0698 is not coming back anymore. The engine is able to crank and fuel is able to the diesel pipes
5 years 3 months ago #45604 by shootingchimp
Replied by shootingchimp on topic Dodge Nitro diesel
CRD injectors are typically controlled by the pcm directly via internal capacitors, (both power and ground) and may show up to 80v when in operation. If all other pcm functionality is normal, very unlikely to be a fuse.
KOEO testing at injector plug may show a nominal low voltage, used by the pcm for circuit integrity testing.
  • mashili
5 years 3 months ago #45644 by mashili
Morning! You are very correct because both the power and ground come direct from the ECM to the injectors. I did a voltage test on the powers of the injectors and cylinder 1 and 2 its giving me 0.055v and on cylinder 3 and 4 0.110v.
5 years 3 months ago #45664 by BreakerPoints
Replied by BreakerPoints on topic Dodge Nitro diesel
Hi,
are those injectors Bosch with a fuel line from top? Any chance they are piezo injectors and not a solenoid?? How did you check for power and ground at the injectors? I guess you are aware that you shouldn't disconnect piezo during operation.
  • mashili
5 years 3 months ago #45671 by mashili
Yes the are piezo bosch injectors. I used a multimeter to do the measurements and I disconnected them when measuring the voltage
5 years 3 months ago #45672 by BreakerPoints
If you disconnect piezoelectric injector during engine operation you might end up with a injector stuck in open position and possible made your engine hydrolock. Even poking around with a backprobes leads can do the same, happened to me but no hydrolock luckily.
I think you will need oscilloscope to test them, there is short pulse of voltage on them and it goes up to 200v, but basically you need a amp clamp probe to check them. Approximately amp draw is up to 10A. Dvom can not be used to pick up that fast pulse of a voltage. I am talking generally not about your specific car.
