Opel fuel trims is Fixed
- spit64
- Thank you received: 22
- spit64
- Wightscope
- Thank you received: 30
Will be interesting to see what the CMP has to say at the time.
Would Cyl 4 be the first injection event after the ECU sees the ckp/cmp match that tells it where the engine is (TDC on 1?)
- spit64
- Wightscope
Not as if there is going to be huge traffic for it !
This is your original for example www.picoauto.com/support/download/file.php?id=33572
- spit64
Push the blue box I think it will be in Swedish the word ladda ner means download
www.dropbox.com/sh/y4bntnjb89sbodk/AADqV...i5h2cHvr1Wn87Za?dl=0
- Matt T
- Thank you received: 276
Wightscope wrote: I note also that about 4 crank revolutions before the event the voltage starts to drop from 14.2v down to 12.24v at the time of the out of turn firing, that could be a clue as it comes first.
It's not just voltage that is dropping. RPM is also getting pulled down. Almost 900 RPM when voltage starts falling on down to under 500 RPM right before the event. Then RPM flares up over 1,300 right after the event. Can also see the injector pulses getting fatter. If this did happen in gear it should've been very noticeable unless the clutch is spanked.....
Also found this after a fuel cut where #4 is the last injector to turn back on. Might be deliberate but there are other fuel cuts where it doesn't happen??
- spit64
- Wightscope
- spit64
www.dropbox.com/s/yiya4ie1cul51wt/3.psdata?dl=0
www.dropbox.com/s/8yi8j5i11yd8t4l/Opel_i...4%20good.psdata?dl=0
- Wightscope
I'm having scope withdrawal so happy to look at your waveforms!
- spit64
www.dropbox.com/s/0tl3iha3t67iipb/cam%20...0cyl%204.psdata?dl=0
www.dropbox.com/s/eni28qtgdrfmisu/cam_cyl%204%20ign.psdata?dl=0
www.dropbox.com/s/jyf0ivcxwk3xzur/under%20misfire.psdata?dl=0
www.dropbox.com/s/mduyhb5sc21kdbr/after%...0misfire.psdata?dl=0
- Wightscope
Well to state the obvious the primary or secondary voltage is leaking into the 5v ref, this is spiking the cam sensor - at some points off the +/-10v scale so no wonder the ECU is confused as to where it is.
There is also a 300-500mv ripple on the 5v ref at 30-180kHz, which I think is too high to be a solenoid or alternator.
You mentioned the cassette had been replaced - is it genuine and do you have the original. I am wondering if the actual problem was the CKP sensor that you replaced and this is an induced problem.
I notice that the primary spike is dropping from 350 to 250v which indicates a short and the cam sensor voltage spikes as the coil discharges across the plug. You can see when misfiring that the same but much smaller spikes happen in the 5v ref when the other plugs fire. Take a look at the plug in 4 as well, even when not misfiring I can see the spark escaping, maybe swap the plug over.
I don't know the arrangement of the engine but look for anywhere the 5v ref and primary/secondary are in close contact - ECU plug, a 5v wire clipped to the top of the coil pack for example. Is Cyl 4 next to the cam sensor by any chance? Also it maybe 5v to something only switched on at certain times
Under misfire CMP at +/- 10V! looks like it causes an extra firing
No misfire but spark escaping
- Wightscope
Demo :
HOWEVER - as you may have a coil leak I would wrap that coin in some rubber or layers of electrical tape just in case there is a crack in the insulation
- spit64
It is an NGK coil pack and the owner bought an NGK coil pack but with the same problem I switched to the old one but I think the new one was never tested after a new crank sensor.
This is a picture of the ground wire to the coil pack the owner of the car or the dealership did this repair it was not a nice one and it did a loop around the other wires you never know if that could interfere with it is a picture before and after repair.
- spit64
www.dropbox.com/s/490g18aed3uzn4s/shotdown.psdata?dl=0
www.dropbox.com/s/y6kavbw2r7x482r/opel%2...0cyl%204.psdata?dl=0
- Wightscope
Pull the pack and take a look for carbon tracking on the plug or inside the boot.
Good idea to switch the pack back now you have fixed the crank sensor, if that does not fix it then maybe switch the plugs around and see if the problem moves.
That spark is going somewhere as you can see by the waveform. The leakage leaks into the 5v ref on the cam, confuses the ECU about where it is in the firing cycle causing the injector to fire twice.
At least that's the theory so far. Fix the spark leakage and you will have fixed it. Probably!
- spit64
Fuel trim first before engine warm-up great at idle and showed correction at cruising at 2200 rpm long term 17 short term -15 warm engine longterm 20 and short-term 12 total +30 but is with steady throttle around 2000 rpm if I accelerate the fuel trim is 0 and also at idle. It is only steady throttle 50 mph
MAP sensor is around 2 volts at partial load 200 rpm. 02 sensor working. No code so far or check engine light.
www.dropbox.com/s/6mgtnzll7mo7i0z/fuel%20pressure.mp4?dl=0
- spit64
- Wightscope
