ford pats waveforms
- cheryl hartkorn
- Thank you received: 130
9 years 1 month ago #5578
by cheryl hartkorn
ford pats waveforms was created by cheryl hartkorn
does anybody have a waveform of what the signal looks like the pats tranciever sends to the pcm? rx and tx lines. some use the cluster
- cheryl hartkorn
9 years 1 month ago #5579
by cheryl hartkorn
Replied by cheryl hartkorn on topic ford pats waveforms
no issues. not even working on a car for an issue. just always wondered what the signal looks like.
- Thank you received: 1539
9 years 1 month ago #5992
Replied by Tyler on topic ford pats waveforms
Ask and you shall receive! (I actually had a Ford to play with today, and remembered this request
Here's the signals while backprobing at the sensor ring. Tx is green, Rx is yellow. Cursor one is when the key goes into the lock cylinder, cursor two is key on.
Did some unplugged testing, too. Same signals, same colors. Cursor one is with the sensor ring unplugged, cursor two is with it plugged in. Key on.
- cheryl hartkorn
9 years 1 month ago #5993
by cheryl hartkorn
pretty sweet. actually seeing what goes on with the key in the ignition. the flow chart only has checking for continuity of the wires. etc I wish these flow charts would start putting scope waveforms in there diagnostics itd make it way quicker!! kia does sometimes. thanks tyler for getting these
9 years 1 month ago #6000
No problem! You mentioned it last week, and I thought, "Good idea!" :lol:
- mafmax97
2 years 8 months ago #62469
by mafmax97
Replied by mafmax97 on topic ford pats waveforms
This wave sign legit helped me diagnose my pats system. Unfortunately it is the pcm, but at least I know I'm not buying a new one for nothing. My Rx line is not getting any power and from the sign above it looks like it should have 12 v. It does not move at all in any key position, while the tx does act normally. I tested continuity of the rx cable between the pcm and the ring plug and the wire is good.
Time to create page: 0.367 seconds
