2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
- Mikey1583
6 years 7 months ago #33300
by Mikey1583
2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring was created by Mikey1583
I replaced the plugs and got rid of 2 cylinder misfires. Found a bad coil to fix the 3rd. Found 12 ohms on 4 fuel injectors and 10 on the last 2. Replaced the 2 fuel injectors still open circuit on all 6. Found a couple of cuts in the wiring harness and repaired them. Now only showing p0206 code. With a test light and the key in the off position I checked 2 connectors at the fuel injectors. I have a ground on the hot wire and nothing on wire going to the pcm or on pin #12 where the wire goes to the pcm has no ground. On the bad connector I'm showing a ground on the hot wire as well as the wiring going to the pcm. I checked the pcm pin #4 and it shows ground as well. So do I have a bad pcm? Any suggestions?
- cheryl hartkorn
- Thank you received: 130
6 years 7 months ago #33301
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
how are you getting a ground on the hot side?
- Mikey1583
6 years 7 months ago #33303
by Mikey1583
Replied by Mikey1583 on topic 2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
Too much sun today... hot wire was showing power communication wire showing ground on working injector connector. On the one I'm having issues with I'm showing power on both hot wire and communication wire
- Thank you received: 730
6 years 7 months ago #33304
Replied by Chad on topic 2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
Can you describe your testing a little more? Are you testing with the injectors connected, or disconnected? Is your test-light connected to Battery +, or battery - ? Are you testing KOEO, or is the engine running? Do you have a volt meter?
- Mikey1583
6 years 7 months ago #33306
by Mikey1583
Chryslers battery are in the trunk so I hooked a power probe to a ground wire on the chassis. Injectors unplugged. Yes I have a multimeter
- Cheryl
- Thank you received: 215
6 years 7 months ago #33308
by Cheryl
Replied by Cheryl on topic 2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
Sounds like your backprobing the pcm at the #6 injector driver and it’s staying at 12 volts?? If so move on from the wiring as it’s good. Try clearing the codes and recheck as Chrysler’s like intentional shutdown of drivers. If still stuck at 12 volts pcm driver is toast
- John Curtis
- Thank you received: 111
6 years 7 months ago - 6 years 7 months ago #33310
by John Curtis
Replied by John Curtis on topic 2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
I’m not 100% sure if I’m understanding where you’re at so far. Are you saying you’re not getting 12V to the injectors?
Instead of 12V on the power wire it’s saying it’s a ground?
Also, I love power probe however I find that it isn’t always the best tool for the job. if you can, I’d recommend a test light for this one. Power probe sometimes leads you in bad directions.
Last edit: 6 years 7 months ago by John Curtis.
- Mikey1583
6 years 7 months ago #33311
by Mikey1583
So I started by checking ohms for each injector. I'm now getting 12 on every injector. I've used a noid light and it lights up on all connections except number 6. I replaced the connector and control wire and still cant get the injector to do anything. I will try to clear the code and try to see if I'm still getting the same 12v
- rpd1125
- Thank you received: 10
6 years 6 months ago #33667
by rpd1125
Replied by rpd1125 on topic 2007 Chrysler 300 2.7 l open circuit on 6 injectors and 3 cylinders misfiring
I had one recently on a 2007 Chrysler that the PCM stopped grounding the injector on the control wire. These injectors are powered at all times on a common Voltage feed wire and the PCM grounds each injector individually. Get a lab scope or a test light connected to battery voltage and tap into control wire for injector 6 at the PCM. If the test light blinks at the PCM then you have an open in the wire where you can either find it or run a new wire for the control side. Or if its not blinking at the PCM then you have a bad PCM that lost ability to control the driver for injector 6 fuel injector
Should be simple to test.
