Cam vs crank waveform
6 years 10 months ago #30190 by Ste
Cam vs crank waveform was created by Ste
Hey I’m just wondering if anyone can help me out on here
I’ve got a 2005 Audi A3 3.2 engine code BMJ in for repair
No start vehicle
Good fuel pressure -
Crank sensor - ok
Cam sensors - ok
Injector are pulsing
Coils are firing
I’m looking for a cam vs crank waveform to check the valve timing. I’ll upload what I have shortly.
If anyone has a know good I’d really appreciate
Thanks
6 years 10 months ago #30191 by Ste
Replied by Ste on topic Cam vs crank waveform
1st capture both sides of the crank sensor. I thought this was a bad sensor so replaced it.
To be honest it may of been a badly connected test pin. It was hard to get access to the CKP plug
2nd pic is new sensor fitted
6 years 10 months ago #30192 by Ste
6 years 10 months ago #30223 by guafa
Replied by guafa on topic Cam vs crank waveform
Hi Ste,
So you have spark and fuel?
Have you tried any starter fluid or gas?
Tried the engine to start at least for a second or fraction or second?
Try to capture when cranking, battery voltage drops (mechanical TDC) and ignition time.
6 years 10 months ago #30226 by Ste
guafa wrote: Hi Ste,
yes, confirmed via scope and the wet spark plugs
no not tried this yet
ill do a relative compression with number 1 ignition primary and Injevtor control capture in the morning
6 years 10 months ago - 6 years 10 months ago #30333 by Ste
can anyone shed any light on why I would see this reading from the maf signal whilst cranking
[IMG
And not like this known good off a 4 cylinder Honda engine
[IMG
I’m confused at the 6 sets of 3 staggered peaks from the maf signal
Second image
Yellow trace - low amps clamp starter current
Red trace maf signal
Blue trace no 1 injector control
Last edit: 6 years 10 months ago by Ste.
6 years 10 months ago #30345 by John Curtis
Replied by John Curtis on topic Cam vs crank waveform
I believe Keith from L1 Auto diagnostics has a library of known good and known bad captures. Maybe something you may want to look into.
Time to create page: 0.345 seconds
