2007 Dodge Nitro electrical issue
  • TOMMITYTOMTOM
  • TOMMITYTOMTOM's Avatar Topic Author
7 years 1 month ago #26861 by TOMMITYTOMTOM
2007 Dodge Nitro electrical issue was created by TOMMITYTOMTOM
2007 Nitro , 3.7L . Daughter's car. She called to tell me that the alternator was smoking. She knows her way around tools so I had her quickly disconnect the battery. I determined that the alternator was bad and installed a new one. After making all connections, I have a dead key. Battery is charged but no gauges, no start. Was told by a mechanic problem was likely the TIPM. (Totally integrated power module). I sent the unit off and the repair facility shipped it back at no charge stating that the problem I'm having isn't covered in their repair procedure. I've tried jumping it, nothing. Dome light work IF you manually turn them on but not through door switches. Door locks dead. Nothing comes on inside or outside the vehicle. Any thoughts ? I fix 99% of all of my car issues. Alternator was easy with 3 bolts, belt 1 plug and the charge lead. I get 12v+ to the TIPM, no blown fuses.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
7 years 1 month ago #26862 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2007 Dodge Nitro electrical issue
have you checked the body to engine grounds?? if not clip light on the body strut bolt etc then use testing end probe engine block. you shouldnt see it light if you do you have a bad ground.
  • cheryl hartkorn
7 years 1 month ago #26863 by cheryl hartkorn
also check fuses m16 m15 and m33 with the key on. should have power the diagram says there in the tipm
  • TOMMITYTOMTOM
7 years 1 month ago #26938 by TOMMITYTOMTOM
Replied by TOMMITYTOMTOM on topic 2007 Dodge Nitro electrical issue
Hi, All grounds good that I can find. Getting 12.2-ish volts to TIPM. No power inside car at all.
  • TOMMITYTOMTOM
7 years 1 month ago #26939 by TOMMITYTOMTOM
All fuses in TIPM are good. No Communication to Scan tool as well. Tool gets power from data port but will not communicate. I'm suspecting ECM.
  • TOMMITYTOMTOM
7 years 1 month ago #27441 by TOMMITYTOMTOM
Hi, M15, M16 and M33 have no voltage with key on. thoughts ?
7 years 1 month ago #27489 by Tyler
Replied by Tyler on topic 2007 Dodge Nitro electrical issue
TOMMITYTOMTOM wrote: Hi, M15, M16 and M33 have no voltage with key on. thoughts ?
How about M37? Because according to the diagram, M15, M16, M33 and M37 all get power from the Run/Start relay (likely integrated into the TIPM).
M15, M16 and M33 power other accessories, but M37 goes to the PCM. That'd very neatly explain your lack of communication.
  • TOMMITYTOMTOM
7 years 4 weeks ago #27497 by TOMMITYTOMTOM
I'll check that ASAP. Thanks for the tip. I have the wiring diagram but it's a bit overwhelming.
  • cheryl hartkorn
7 years 4 weeks ago #27501 by cheryl hartkorn
post the diagramif you could
7 years 4 weeks ago #27502 by Tyler
cheryl hartkorn wrote: post the diagramif you could
The entire power distribution diagram is too big for the forums. :angry: So I cut it down to the two pages with the relevant fuses:
File Attachment:
File Name: nitrodiagram.pdf
File Size:664 KB
Not your fault - it's a big diagram. :lol: And the relationship between the four fuses isn't very clearly indicated.
7 years 4 weeks ago - 7 years 4 weeks ago #27505 by wacoeagle
Replied by wacoeagle on topic 2007 Dodge Nitro electrical issue
was the car jumped off and possibly the jumper cable installed backwards on the battery, that will fry the computer.
what was smoking was it the winding inside the alternator? the wiring going to the alternator? start backtracking from the alternator back. is the alternator fused with a fusible link? did it short out the battery? did it burn ground lugs off of anything? smoking usually means DIRECT SHORT!
Last edit: 7 years 4 weeks ago by wacoeagle.
  • TOMMITYTOMTOM
7 years 4 weeks ago #27545 by TOMMITYTOMTOM
Car wasn't jumped off. She noticed smoking and sent me a small video. Lucky for me that she knows her way around my tool box and I had her disconnect the battery quickly. The smoke was from inside the alternator case. I've verified all user-replacable fuses and relays in the TIPM are good. Fuses were checked with a meter for continuity when removed from TIPM. Relays, the same way but with a 12V power supply to check coils in relay and DVM for continuity as well. I may take the TIPM apart again and check the small relays as well. There isn't a fuseable link anywhere that I can find.
7 years 4 weeks ago #27554 by Tyler
TOMMITYTOMTOM wrote: Car wasn't jumped off. She noticed smoking and sent me a small video. Lucky for me that she knows her way around my tool box and I had her disconnect the battery quickly. The smoke was from inside the alternator case. I've verified all user-replacable fuses and relays in the TIPM are good. Fuses were checked with a meter for continuity when removed from TIPM. Relays, the same way but with a 12V power supply to check coils in relay and DVM for continuity as well. I may take the TIPM apart again and check the small relays as well. There isn't a fuseable link anywhere that I can find.
Do you recall if fuse M37 had power KOEO?
  • TOMMITYTOMTOM
7 years 2 weeks ago #27874 by TOMMITYTOMTOM
Sorry for the delay, I've been in the hospital. M37 is ABS/ESP/STP/LP SW/FUEL PUMP RELAY HI CONTROL. No voltage (KOEO)
  • TOMMITYTOMTOM
7 years 2 weeks ago #27875 by TOMMITYTOMTOM
Actron CP9180 scanner gets power from OBD port but NO communication with any modules.
7 years 2 weeks ago #27888 by Tyler
TOMMITYTOMTOM wrote: Sorry for the delay, I've been in the hospital. M37 is ABS/ESP/STP/LP SW/FUEL PUMP RELAY HI CONTROL. No voltage (KOEO)
Sorry to hear that. :( Hoping all is well.
Definitely sounds like the Run/Start relay isn't getting energized, OR there's an issue on the load side of the relay.
  • TOMMITYTOMTOM
7 years 1 week ago #28084 by TOMMITYTOMTOM
As I was unable to physically work on the car, I gave in and let my daughter's boyfriend's friend tow it. He asked for all of things i've tried. I told him my gut feeling was the TIPM as it would freak out overtime I would pull it and reinstall after checking relays soldered to the board. He immediately bought a used TIPM for same make and upon installing, it fired right up. I really wanted to diagnose rather than just throw a part at it. Thanks for all of the tips though.
Time to create page: 0.501 seconds
