Battery drain on Audi
  • CHolhosV
  • CHolhosV's Avatar Topic Author
2 days 6 hours ago #93371 by CHolhosV
Battery drain on Audi was created by CHolhosV
Hey everyone! I have an Audi A4 B9 2020 and something drains my battery (0.3A). I checked all the fuses ( pulled them out one by one and after that I checked the mV on all the fuses hoping to see something different on one of them) and I found that the drain is on the fuse B7 ( Gateway Control Module - from 0.3A it goes to 0.08A). The only two fuses that have current on them ( current that I could measure were B7 with 1.12mV and the NFC fuse with 4-5mV on it- I'm not sure if the NFC is supposed to enter in to sleep mode or not) I checked the GWM and it's perfectly fine. I unplugged the BMS, I checked the ripple at the B+ on the alternator, I unplugged the MMI unit ( just things that I read to be the most common to fail like this). And I'm not sure what to do next...unplug some more modules like the SOS etc., start a heavy duty wire investigation? Whatever I do, the drain stays and when I unplug the gateway it goes away. I would highly appreciate some help. THANK YOU!!
2 days 1 hour ago - 2 days 1 hour ago #93372 by Noah
Replied by Noah on topic Battery drain on Audi
Sounds like you managed to get quite a way down the road on this problem, nice work isolating it to the gateway module.
Now the real fun is going to be isolating all the circuits and modules that connect to the gateway module. Which is probably all of them unfortunately...
I assume you have a good diagram? The gateway module probably has multiple different network protocols, such as HSCAN, LIN and probably some other Audi only network names.
Once you have waited long enough for the networks to have timed out, I would scope all the network wires at the gateway module to see if there is any activity, then chase modules on that network to see if removing one of them removes the draw.
I don't doubt your process, but be 100% certain that you are waiting at least 45min to an hour before deciding you have a draw, and make sure any door, trunk or hood latches or switches are manually closed and the doors are locked, preferably with the alarm set to reliable put the vehicle into "sleep mode".
Edit: a couple more thoughts,
What does your draw test set up look like? Are you using an amp meter between the battery post and cable? I recently started using a power probe draw meter that plugs into the obd port. It works great, but there are some caveats such as unplugging the ind fuse (and in the case of Fords the gateway module).removes the draw because that is now where the voltage is being supplied.
Also, if there is an aftermarket remote start, radio or other non factory accessory remove that first and see if the draw is gone before going too crazy.
Last edit: 2 days 1 hour ago by Noah.
  • CHolhosV
2 days 42 minutes ago #93373 by CHolhosV
Replied by CHolhosV on topic Battery drain on Audi
Thank you! I have the original Audi diagrams but unfortunately they don't help a lot ( they are very fragmented). I will do what you suggest. Meanwhile I unplugged the ConBox, the NFC module and the MMI ( known to be problematic on audi cars) and still nothing. I really think I don't have many modules left so I think it makes it easier when I scope the wires. I'm 100% sure that there is a drain cause I left it over night with the multimeter connected in series to the negative battery terminal and still 0.3A. You said to look for any activity on the network wires. So there is not supposed to be any network signals on the GWM even when it's in sleep mode? ( Just want to know what to look for). Thank you!
1 day 23 hours ago #93374 by Noah
Correct, I would expect there to be no messages on the networks when the vehicle is completely powered down.
