'08 Ram 2500 6.7 No Comm to O2 Module U011A
  • ephotrod
  • ephotrod's Avatar Topic Author
9 years 2 months ago #2936 by ephotrod
Replied by ephotrod on topic '08 Ram 2500 6.7 No Comm to O2 Module U011A
Tyler,
Thank you I'll get a couple more videos (so i can learn) before we replace the module and one after. I'm doing alot of this to learn, I never went to a formal school or was taught how to work on cars, this is a great opportunity for me. Your and Pauls efforts are greatly appreciated. I've bought both books and have a years subscription to his channel, but guidance like your giving me is worth more than it all. Thank you.
Josh
The following user(s) said Thank You: Tyler, aboudi.naddaf
9 years 2 months ago #2949 by Tyler
No problem, sir! I'm happy that you brought this issue here, as I've never had to get my hands dirty on one of these sensing module systems. We've gotten questions about them previously , but I didn't have a ton of advice to offer at the time...
Speaking of, could I talk you into doing some more experimenting? I'd love to have voltage readings on the six NOx sensor wires at the sensing module :cheer: Looking at the pin designations on the wiring diagram makes me think it's wired like an air/fuel ratio sensor, but I'm not certain. No worries at all if you don't have the opportunity! Just trying to expand my knowledge of these systems.
  • ephotrod
9 years 2 months ago #2965 by ephotrod
I'll do testing but it would be so much easier to email you the videos and info this uploading to photobucket to fail ten times kicks my ass and makes me not want to participate.
9 years 2 months ago #2966 by Tyler
No problem! wrenchturnsyou@gmail.com
No need to video the sensor voltages, just static measurements will work perfectly.
9 years 2 months ago #3003 by Tyler
I had a glance at Mitchell today, and we're right on in our diagnosis and testing. Really strange, the OE flowchart wants you to check power, but not ground :huh: And only wants to know if the power feed is over six volts... Weak flow chart, IMO.
  • ephotrod
9 years 2 months ago #3012 by ephotrod
Tyler I'll get to the measurement this weekend as its in the back and won't be touched for a bit. Give me a list of test you'd like to run and I'll go through them, posting the results.
9 years 2 months ago #3053 by Tyler
No worries, this is a backburner idea of mine.
Also, how many wires total are there at this module? The BBB Industries diagram I posted earlier showed 10, with one sensor connected. But the Mitchell diagram I found showed 16 wires, with two sensors connected.
IF the diagram I posted earlier corresponds to your truck, then I'm looking for voltage readings on pins 1, 6, 7, 14, 15, and 16. I'm gonna take a shot in the dark and say:
Pin 1 + 16: Pulsed power and steady ground
Pin 14: 2.5V steady
Pin 7: 3V steady
Pin 6: 2.5V, varying
Pin 15: same as pin 6
Could be WAY off :lol:
  • ephotrod
9 years 2 months ago #3154 by ephotrod
Tyler the vehicle follows the on demand wiring diagram and is 16 wires I will try to follow through with what you want as far as I can with my limited abilities.
  • Chriscoy
  • Chriscoy's Avatar
  • Heavy duty truck technician / foreman/ parts guy/
9 years 2 months ago #3156 by Chriscoy
Replied by Chriscoy on topic '08 Ram 2500 6.7 No Comm to O2 Module U011A
61 ohms sounds correct. The ECM has a termination resistor and the variable geometry turbo actuator has the second.
If you have clean data square waves at the module it's probably a failed NOx sensor.
Prior to replacing it check for TSB's, If you have the Engine Serial Number I can try and check QuickServe for anything on cummins side.
Changing parts is easy, Troubleshooting is an art
  • ephotrod
9 years 2 months ago #3157 by ephotrod
The following are all my readings based on the on demand diagram. A vantage Pro was used on a 20 volt scale 5 ms time base. There are 16 pins all together.
Pin 1: 12.31 volts
Pin 2: 12.31 volts
Pin 3: 2.95 volts
Pin 4: 2.94 volts
Pin 5: 2.86 volts
Pin 6: 2.94 volts
Pin 7: 2.84 volts
Pin 8: 12.35 volts
Pin 9: 12.35 volts
Pin 10: .69 volts
Pin 11: .68 volts
Pin 12: .68 volts
Pin 13: 2.52 volts
Pin 14: 2.52 volts
Pin 15: 2.86 volts
Pin 16: 12.30 volts
I don't have clean data square waves based on either pin 3 (white) the low data link or pin 11(white and orange) high data link.
  • ephotrod
9 years 2 months ago #3158 by ephotrod
I do not have the serial number all I could find was the group number which is 8CEXK06.7TXW. If you guide me to where it maybe I'll look. This motor is not like the 5.9 with the plate visible near the radiator.
  • ephotrod
9 years 2 months ago #3159 by ephotrod
  • Noah
  • Noah's Avatar
9 years 2 months ago #3165 by Noah
ephotrod wrote: The following are all my readings based on the on demand diagram. A vantage Pro was used on a 20 volt scale 5 ms time base. There are 16 pins all together.
Pin 1: 12.31 volts
Pin 2: 12.31 volts
Pin 3: 2.95 volts
Pin 4: 2.94 volts
Pin 5: 2.86 volts
Pin 6: 2.94 volts
Pin 7: 2.84 volts
Pin 8: 12.35 volts
Pin 9: 12.35 volts
Pin 10: .69 volts
Pin 11: .68 volts
Pin 12: .68 volts
Pin 13: 2.52 volts
Pin 14: 2.52 volts
Pin 15: 2.86 volts
Pin 16: 12.30 volts
Forgive me if I'm missing something, but there's not a good ground on any of those pins. I'd think at least one would be (much) lower than half a volt.
The diagram looks bad on my phone, gonna have to fire up the PC, but that's my initial impression.
9 years 2 months ago - 9 years 2 months ago #3167 by Tyler
Pin 1: 12.31 volts
Yay! :woohoo: Thanks a ton, sir! This is exactly what I was looking for.
Floating ground ;) Usually 2.5V, but some Fords use 3.6V (for whatever reason :unsure:). That's why pins 13 and 14 show 2.52V.
The predictions I made for those pin voltages were hit and miss. I had this pegged for a power-side switched heater, but I think it's actually ground-side switched. Oh well :(
It does? :huh: Looking at the diagram again, and it doesn't show the turbo involved:
Could be the diagram is wrong?
Last edit: 9 years 2 months ago by Tyler.
  • Noah
  • Noah's Avatar
9 years 2 months ago #3169 by Noah
The module itself uses a floating ground? I thought that was a signal circuit strategy? :(
9 years 2 months ago #3170 by Tyler
Noah wrote: The module itself uses a floating ground? I thought that was a signal circuit strategy? :(
Sorry, I coulda been more specific there :blush: The sensor circuits use a floating ground. Actually, I see what you mean now... Pin 10 is the module ground, with .68V :blink: I didn't look too closely at that one, 'cause ephotrod said he checked module power and ground in the first post.
Maybe it's time to revisit the module ground? :huh:
  • Noah
  • Noah's Avatar
9 years 2 months ago #3171 by Noah
Thanks for clearing that up. That's pretty much what I was thinking too.
  • ephotrod
9 years 2 months ago #3172 by ephotrod
Would it be alright to use a jumper wire back probe on pin 10 to a chasis ground and see if I have signal then? WHat would be the right way to go about it?
9 years 2 months ago #3174 by Tyler
ephotrod wrote: Would it be alright to use a jumper wire back probe on pin 10 to a chasis ground and see if I have signal then? WHat would be the right way to go about it?
That would work! You could even keep your meter hooked up to the same backprobe and watch the voltage drop down when you add the jumper in. You could also use a test light connected to B+ and touch on the same pin, looking for the light to burn bright. Key on, either way.
If you end up adding a ground, just make sure that the ground your adding is a good ground itself. Then, you can clear the codes and see if anything comes back. If the code doesn't return, then you've found the problem B)
  • Noah
  • Noah's Avatar
9 years 2 months ago #3175 by Noah
I would try that.
Time to create page: 0.362 seconds
