09 Mini Cooper S No start with crank
- Bchez71
- Thank you received: 732
Bchez71 wrote: I checked voltage while cranking the engine I see battery voltage.
At what location was this check made? At the fuel pump?
- Bchez71
1. The pump does NOT get power, and does NOT run for a couple seconds of prime when the key is turned to the "ON" position.
2. If you give power to the WHT/BLU wire with a power probe, the pump runs.
3. Cranking the engine, you have power on the WHT/BLU wire, and a good ground on the BRN wire but, the pump does not run.
Is this correct?
- Bchez71
I am curious of the voltage on BOTH wires.
With the connector connected, engine cranking,...What voltage do you read on the WHT/BLU wire? What voltage do you read on the BRN wire, while cranking?
- cheryl hartkorn
- Thank you received: 130
- Bchez71
Then, back-probe the power side of the fuel pump connector (WHT/BLU) with the positive lead of the meter. CRANK the engine and read the voltage.
Now, move the Back-Probe/positive test-lead to the GROUND side (BRN) of the fuel pump connector, leaving the negative test-lead connected to a good ground. CRANK the engine and read the voltage.
- Bchez71
You can use a jumper wire (or PowerProbe) to provide a temporary GOOD ground for testing purposes to confirm.
- SamM
- Thank you received: 3
- Ful4ce
