1997 Honda Civic DX d16y7 engine
- Mechanic 350
- Thank you received: 15
8 years 1 day ago #19562
by Mechanic 350
1997 Honda Civic DX d16y7 engine was created by Mechanic 350
I just replaced timing belt etc...
No 1 on tdc.
Cam marks at 9 and 3
Everything looking good. But after bolting everything back. The car is cranking abnormally long. What have I done wrong. I’m stuck like chuck. I need some guidance. Thank you in advance fellows.
No 1 on tdc.
- Thank you received: 1539
8 years 1 day ago #19571
Replied by Tyler on topic 1997 Honda Civic DX d16y7 engine
Do you have a vacuum gauge? A quick check at idle with no loads can tell us if timing is off or not.
No offense meant here, but are you positive you got the cam lined up correctly? As I recall, there's some pointers on the back timing cover, which sit very close to the upper edge of the cylinder head. Does this sound familiar?
- Mechanic 350
8 years 1 day ago #19573
by Mechanic 350
Replied by Mechanic 350 on topic 1997 Honda Civic DX d16y7 engine
Man Tyler I just lost my entire post that I wrote you. It said something error.and did not send my reply to you. Anyway I will do exactly as you have instructed me thanks buddy
8 years 1 day ago #19574
Sorry you lost your post.
Frustrating, I know.
Pretty sure you're supposed to align the cam marks with the top of the cylinder head, NOT the pointers.
- Mechanic 350
8 years 1 day ago #19583
by Mechanic 350
Ok then. I have to re-check everything after I perform the vacuum test. By the way, what reading am I looking at idle Tyler? Thanks buddy
8 years 12 hours ago #19601
At hot idle with no loads, I'd expect at least 19" Hg. Less would suggest a vacuum leak, or a timing problem.
- Mechanic 350
8 years 11 hours ago #19616
by Mechanic 350
Ok
Time to create page: 0.251 seconds
