2006 Kia Sportage, Crank but no start, no spark...ECM wont ground main relay
8 years 1 month ago #18349 by Tutti57
Trod wrote: I did do that test with the logic probe with it connected to positive and probing the ground that the computer supplies while someone cranked the engine over and got no ground light up on probe. This was after the jumper wires but car would still start with jumpers so ive complicated the possiblities obviously. Ive learned my lesson Im praying the driver in the ecm is the problem.
Did you try test #1 too?
8 years 1 month ago #18350 by Ben
Wow I haven't seen Paul take a repair question in a while ! You are getting the best diagnostic advice available and you want to throw an ecm at it? You better perform the tests he asked you to do the way he asked you to do it before you burn up another ecm! Also if your not comfortable being the computer here's a great example (also one of my favorites)
8 years 1 month ago #18351 by Trod
Hi Ben, Ive got nowhere else to go Ive done the tests to see if the ecm was grounding the circuit using the led test light, etc. Since Paul confirmed there are no other inputs that signal the ecm to ground the main relay then Im finished, new ecm it is. Anyone recommend a good repair service so I dont have to have the vin reprogrammed? Or even a service that enters in the vin ahead of time? Thanks again Paul for the responses you made my day!
8 years 1 month ago #18352 by Ben
Did you ground pin 67 at the ecm ? Did relay activate?
8 years 1 month ago #18353 by Ben
Not sure of services to enter vin besides dealer. Often times a used ecm will work with the wrong vin number programmed
8 years 1 month ago #18354 by steve
Trod wrote: I disconnected the ECM and tested the black/orange wire by sending voltage through it and its fine.
Was this checked with just a voltmeter or was a load added as well?
8 years 1 month ago #18359 by Trod
I will do the tests as per your instructions Paul and report back. Thanks for taking the time to give me all this info.
8 years 1 month ago #18360 by Trod
I will try grounding it when I get back to the shop later in the week, thanks.
8 years 1 month ago #18361 by Trod
I will definitely take him up on it, I've got nothing to lose...
8 years 1 month ago #18362 by Trod
It was loaded with current
8 years 1 month ago #18363 by Trod
Thanks again Paul, I've had sometime to think about your tests and they do make sense as usual. I will do them as per your instructions and get back to you by the end of the week. Someone else mentioned that of course the circuit would work because I was jumping the switch side but the vehicle wouldn't start and run without me jumping the control side also at the same time. Again, I appreciate all the good advice and will follow it.
8 years 1 month ago #18535 by Trod
HI Paul, sorry for the late response. I did the two tests you told me to do. The one test I used incandescent bulb and connected one end to the battery and other end to Pin 67 at the ecm connector and the light didnt light up. The second test I grounded the circuit at the ecm pin 67 with T pin and jumper wire to ground and the main relay did click but vehicle wouldnt start. I think that this test says that the integrity of the circuit and fuse box is good however the driver for the ECM is cooked, right?
8 years 4 weeks ago #18620 by Ben
Didn't the vehicle run when you activated relay at fuse box earlier in your testing?
  • ScannerDanner
  • ScannerDanner's Avatar
  • Away
  • Administrator
  • Administrator
8 years 4 weeks ago #18642 by ScannerDanner
Trod wrote: HI Paul, sorry for the late response. I did the two tests you told me to do. The one test I used incandescent bulb and connected one end to the battery and other end to Pin 67 at the ecm connector and the light didnt light up. The second test I grounded the circuit at the ecm pin 67 with T pin and jumper wire to ground and the main relay did click but vehicle wouldnt start. I think that this test says that the integrity of the circuit and fuse box is good however the driver for the ECM is cooked, right?
No sir. If the main relay activated when you grounded that circuit and the car still didn't start, then you are most likely missing a power feed or ground to the PCM .
If you only had a faulty driver for the main relay, the car would have started. You have another problem.
Don't be a parts changer!
  • TheTechWhisperer
  • TheTechWhisperer's Avatar
8 years 4 weeks ago #18643 by TheTechWhisperer
This is obviously an old post by now, but did you figure anything out?
BTW...
#1. That makes zero sense that "the vehicle wouldn't run unless it had both sides jumped". Aside from the fact it would cook the driver before it blew the 30A fuse... even if the ECM hypothetically was monitoring the control ground wire for a fault or any potential starting inhibit via the other drivers, it would want to see 0v during Key On, on the B/O wire. Jumping the control side would only take away the only load in the circuit- shooting 12v straight into the driver. Since the transistor is now an open circuit due to being cooked, there will always be 12v on that wire anyway, since the driver can't ground anything anymore. Now, this is all hypothetical, just to help you understand why that statement is not possible. If you still think that both had to be jumped to start it, you probably weren't jumping the terminals that you thought you were.
#2. Paul is telling you not to put an ECM in yet because, although you will now need one, he doesn't want you to potentially damage the new ECM. Need to figure out the original problem first.
#3. Paul didn't say to use a logic probe, he told you to use an incandescent test light (which draw little amperage) for a reason. using the test light puts a safe load on the circuit. Logic probes do not draw an amperage on the circuit, as they have their own power and ground. I honestly view logic probes as completely useless if you already own a DMM.
"You will always find the greatest fulfillment in life when you are operating in the gifts God gave you"- Dad
National Director of Technical Training & Mechanical Operations - Express Oil Change & Tire Engineers
ASE Master L1 Tech
BMW Master Tech
Ford FACT Advanced Electronics Instructor
  • ScannerDanner
  • Away
  • Administrator
  • Administrator
8 years 4 weeks ago #18645 by ScannerDanner
And I will add to your #2 statement and say, replacing the ECM will NOT get this car running based on the fact that grounding the main relay control didn't get it running either. You will need an ECM if you jumped the control side of the relay but this is only A problem, not THE problem. You added this one, maybe. I say maybe, because you may have gotten lucky if the ECM was missing a power feed and never had that circuit active when you jumped the relay. Not sure.
Also agree with #3 statement, logic probes are useless for troubleshooting in 95% of applications. It only takes a few volts to light an LED light in a logic probe and the amperage draw is in the micro-amp range. Get yourself a nice 200-300ma draw incandescent test light like the one I use.
8 years 3 weeks ago #18712 by Trod
First of all techwhisperer I didnt use a logic probe in the test that Paul told me to do, re-read my post, I used something that draws more amps....secondly paul is saying there is another input issue most likely a bad ground he never said anything about causing more damage...you appear to be one of those who likes to just antagonize...I now know why Paul probably doesnt post here anymore. I know the results of my tests, initially jumping the switch side had no effect to starting only after control saw voltage did it start and started multiple times. Ive since received Pauls book and obviously wont be rushing to get results anymore. If Im missing a power feed altogether how would that damage a said good known computer?
8 years 3 weeks ago #18713 by Trod
Thank you again Paul, I will start checking all my power feeds. I already checked many of the main grounds and they were fine. Im under a lot of pressure to get this vehicle up and running and a long list of other cars with dtcs and issues. Your book arrived last Saturday and I read the section on transistor drivers. Again I appreciate your approach to my dilemma while not all here have been so courteous in there words.
  • TheTechWhisperer
8 years 3 weeks ago #18714 by TheTechWhisperer
Trod,
I sincerely apologize if i came across antagonistic. Unfortunately, my verbal tone cannot be conveyed in text, but I assure you that I am the complete opposite of antagonistic. Paul can vouch for me, that my heart is only to help. As an instructor, my instinct was trying to break it down in different lingo to help you understand what Paul was saying, but I'm sorry that it came off as condescending instead and made you upset.
To answer your question: Jumping the switch side that was potentially missing the power feed would be one instance that no damage is done to ECM. However, we don't know... I think the power likely is not missing, since grounding the relay control made the relay click as you said. I just don't want to see you get burned by replacing the ECM and having the original pre-existing problem damage the new ECM... I have been there and made that expensive mistake, it really sucks.
ASE Master L1 Tech
BMW Master Tech
  • ScannerDanner
  • Away
  • Administrator
  • Administrator
8 years 2 weeks ago #18968 by ScannerDanner
Trod wrote: Thank you again Paul, I will start checking all my power feeds. I already checked many of the main grounds and they were fine. Im under a lot of pressure to get this vehicle up and running and a long list of other cars with dtcs and issues. Your book arrived last Saturday and I read the section on transistor drivers. Again I appreciate your approach to my dilemma while not all here have been so courteous in there words.
It is hard to gauge intent with text on a screen. Did you see TheTechWisperer's last comment to you? I think it was an awesome reply to you and I know he is reading this too and I want to give a personal thank you to him.
THIS is exactly why my community is so much better than others. It is in the heart of my people. I am honored to call you all friends.
With this community there is no bashing, respect of others and kindness are required. I got to see it first hand here.
Thank you guys.
And Trod, thank you for not getting too riled up, I could sense your frustration and you didn't let it get the best of you.
The following user(s) said Thank You: Tutti57, Columbus450
Time to create page: 0.476 seconds
