Won't start 97 Buick 3.8L
- Willy Cooke
8 years 8 months ago #11516
by Willy Cooke
Won't start 97 Buick 3.8L was created by Willy Cooke
Need some trouble shooting tips where to look.
My 262500 miles 1997 Buick Park Avenue 3.8L engine won't start checked
spark (great),
checked compression (good), oil pressure (great),
fuel rail pressure ignition on engine off (over 45 psi) turning engine over (55psi) great
Checked injector pulse with light (good on all 6 cylinders)
Checked injectors (good)
Put fuel directly into intake engine starts then quits engines not getting enough fuel but don't know why
spark (great),
- Thank you received: 1116
8 years 8 months ago - 8 years 8 months ago #11521
Replied by Noah on topic Won't start 97 Buick 3.8L
Hi Willy,
I moved your question to your own thread in the repair questions section.
More people will see it here and give you some ideas.
If the car has been sitting, I would suspect fuel quality and possibly gummed up injectors.
You would think it unlikely that 6 injectors would be clogged, but I've seen it.
If you've got a scan tool with bidirectional controls, you should be able to perform an injector flow test to prove it.
I know you said you checked the injectors, but you could've meant with an ohm meter, so I figured it was worth bringing up.
The pressure sounds good, does it hold steady when you shut the engine off?
Last edit: 8 years 8 months ago by Noah.
8 years 8 months ago - 8 years 8 months ago #11523
Oh, and I forgot about anti theft!
Does the security lamp illuminate momentarily when you turn the key on then go out like it should?
You'll have injector pulse momentarily even with an anti theft issue on some GM cars of that vintage.
Last edit: 8 years 8 months ago by Noah. Reason: Big thumbs, little keyboard
- Thank you received: 1539
8 years 8 months ago #11534
Replied by Tyler on topic Won't start 97 Buick 3.8L
So this one is still stuck as a sticky, but I can't figure out how to unsticky it. :lol:
8 years 8 months ago - 8 years 8 months ago #11535
Oops! Didn't notice I made the new topic a sticky!Tyler wrote: So this one is still stuck as a sticky, but I can't figure out how to unsticky it. :lol:
