SOS. Stranded...with serious Ford 6.8 Misfire mystery
  • Ocelot
  • Ocelot's Avatar Topic Author
3 years 2 months ago #59608 by Ocelot
Stuck in Baja, Mexico and my departure clock is running out. Any help would be appreciated beyond measure..I am dealing with a 1999 F250 super duty 4x4, 6.8, V-10 nightmare. I flew down from Massachusetts during the holiday blizzard (and ended up living for three days in an airport with half of America) due to that damned storm. Already a bad start to the rescue mission. I came down to solve a serious misfire problem that kept me from getting the truck home to USA (and trade a few weeks of palm trees instead of the 6 foot snow drifts I have been wallowing in). I came armed with 10 new coil packs, 10 new Motorcraft plugs, a new pcv hose (under throttle body) and new PCV valve hoping to solve the issue.
Engine compression checked out A-OK before I left her stranded so figured it was worth the effort to diagnose and bring her home..
BUT!!!!!
I arrived to find someone decided to hack my engine wiring harness. All connectors for coil packs and injectors were gone! That's bad omen #2. I managed to score a full wiring diagram and I did manage to get some generic ends to solder into the engine harness for coils and injectors, but had to do some serious guessing as to which side of the coils and injectors the common feed and signal wires went to. The diagrams I have do not specify.
Help question # 1.
Does anyone have a Triton V10 that could take a quick peek at their harness and tell me which wire is which on the coils and injectors. Right now I have signal wires (different color for each coil) going to left side of the coil connector and power wire (all the same color for all coils) on right side. For injector connectors I have signal wires going to right side of injector plug (different color for each injector ) and power wire (all same color) going to left side of connector). Maybe it does not matter, but I want it done right. The truck does run now, but with the same bad miss it had before the harness hack. I pulled connectors off the coils and injectors one at a time while running and some give an obvious added misfire.... but with a couple cylinders the engine reaction is barely noticeable (if at all). With V-10 I know it can be tricky. I am getting power to all injectors and all coils, and I am getting pulse signals to all coils and injectors from PCM when I check with a test light while running.
Sadly, I only have a basic hand held code reader with me. I am getting code 0113 (high voltage) but so far that's it. It shakes bad at idle far more than I would expect for one bad coil. Per the code, I tested the IAT on the bench (it does have expected voltage drop with a temp change and ohms seem ok cold) but once again, I had to rewire the sensor connector as that was hacked off too. GRRRRRR... I need to know if it matters which side of the sensor the wires go to and which wire goes where on that two pin plug. It's a guessing game for me.
Thats help question #2 Can someone tell me what color wire goes where on that IAT sensor? On 1999 F250 It's easy to see for a quick peek. Referencing color of wire in relation to the clip on the connector would tell me how to orient my wires.
Last question. If I have good compression and have all new coils, all new plugs, good vacuum hoses and new PCV valve (a known issues with this year truck) and I still get bad misfires, what else do I look for? I am running out of time and would sure like to get this truck across the border before it ends up totally stripped. The only thing left I can think of is injectors. Today I paid $75 for the one and only injector this side of the border (took a week to get it) and installed it in the cylinder that showed the least reaction when pulling coil connection to see if that helped. It didn't seem to make any difference at all. I pulled all injectors and bench tested them and they did open and close when energized and they did spray well when pressurized with a simple spray can / adapter and then energized.
If you have a Triton V-10 and managed to subdue your own engine misfire demons in the past I would love to hear from you. I have to get this truck home and I have a week left to sort it out with limited tools. 7 mules and a lot of rope is looking really nice right about now.
3 years 2 months ago - 3 years 2 months ago #59613 by Tyler
Help question # 1.
I don't have a V10 around to take a peek at, but I was able to dig up some service info that might help. '99 service info doesn't have pictures of the ignition coil connectors, but '05 does (which has better service info). '99 also doesn't note pin location in connectors smaller than six pins. :angry: RockAuto says they both use the same replacement connectors, so I'm gonna say this is a good reference:
And here's one for the fuel injector:
Both pictures are viewed with the female connector terminals facing you, like so:
In the case of the ignition coils, at least, it truly does matter. I've seen backwards wired coils produce just enough spark at idle, but can't keep up under load. Injectors, I don't think it would matter, but best not to find out. ;)
Depending on the replacement ignition coil, you might find a convenient 'B+' marking on the coil itself:
I couldn't find a fancy connector photo in service info, unfortunately. Newer 6.8's switched to an integrated MAF/IAT combo.
But I can say pretty confidently that pin location does NOT matter on thermistors like this IAT. Go eenie-meenie-minie-mo, hook it up and send it. Or, just leave the sensor disconnected and fix it when you get across the border. The IAT doesn't have that much weight in the fuel control calculation, and won't cause a severe misfire like you're experiencing.
I'd back up a bit and repeat your cylinder balance test. Do it a few times if you have to - picking out a single cylinder miss on a V10 can definitely be a bit tricky.
Once you're sure which cylinders have contribution problems, look for common denominators. All on the same bank? Ends of the fuel rails? Speaking of, can you test for fuel pressure or take a fuel sample?
Will your code reader show scan data? That'd allow you to see fuel trims, and verify your IAT is working correctly.
Last edit: 3 years 2 months ago by Tyler.
  • Ocelot
3 years 2 months ago #59615 by Ocelot
Hello Tyler,
This is great.. Thanks so much for your effort and time. Just what I was looking for. I spent hours looking over videos and photos for anything that would give me a clue as to wire positions. I'm going to get at it again today by double checking all connections to make sure wiring is correct, then I'm going to clear all codes and start fresh. Let it run a while to collect any codes and see what comes up.
When I arrived tank was on empty so I put in 60 liters of fresh fuel so I know thats good to go. It's a plastic tank so hopefully no rust /crud. I will pump out some fuel through the rails and look for any water as well. Although the miss was there even before I had to leave it, so probably not a water issue. Can't hurt to check. Sadly, I have no way to check fuel pressure. I will say that once I shut it down and let it sit 10-15 minutes before lifting fuel rail there is still plenty of fuel which is under some pressure. So not likely an injector hanging open.
Using a test light I do seem to get consistent trigger pulses to injectors and coils but I am wondering, could the PCU be faulty and sending a weak or randomly missing signal that could create the constant heavy miss? Without a full scan tool I don't know how else I could check each coil / injector for performance under compression or load. I have not worked on many Fords and this is my first V10 deep diagnosis, though I suppose V8 and V 10 is not any different aside from two more of everything to go wrong. I sure am learning a lot so not all is lost. Thanks for the tips. I will get at at and see how it goes.
3 years 2 months ago #59616 by Tyler
Good enough for now. :cheer:
Incandescent or LED test light?
If you've got power and control at each coil/injector with a test light, then I'd suspect you're not fighting a PCM problem. Generally, the PCM drivers either work, or they don't.
For ignition coils, you can always pull a coil out of the cylinder head, leave it connected electrically and start the engine. Connect your test light to B- and use the tip on the spark plug boot to check for spark strength. Change the air gap to get the longest spark possible out of the coil. 1/2" minimum, 3/4" is better.
  • Ocelot
3 years 2 months ago #59617 by Ocelot
I just took it for a short drive around town and plenty of power even with the misfire. It started fine after some stops and new starts. Got it back to the home fort and checked some of the coils for spark as you suggested. I have good blue spark reaching out over an inch. I have not checked every coil yet because they are a bear to get off the plugs even with the dielectric grease I applied before I installed the new plugs and coil packs. I decided to do another test. I revved the motor to 3k and held it for 30 seconds and the yard filled up with serious amounts of smoke. Blackish.... not blue. It even left a splotch of blackish soot/wetness on ground at end of tailpipe. Looks like raw fuel / soot to me. Misfire got real bad too. Popping through exhaust. Cylinders seem to be dumping raw fuel for sure. But why? Since the injectors are the only thing not changed yet I'm guessing some are stuck open. But then again, if coils are failing I get the same result. UHG....I sure wish I could find a decent scanner for checking fuel trims etc. I'm going to take it for a longer drive hoping I don't get stranded and see how it does on the main road where I can get some speed and revs up. See what codes I get.
BTW.. I am using an incandescent test light. Looked for noid light but not going to happen down here.
  • Noah
  • Noah's Avatar
3 years 2 months ago #59904 by Noah
I got tangled up in one of those late last year. Pretty bad miss on #5, aka:The Hardest One to Reach, lol.
(This is a company vehicle on site if you need and comparative data.)
Compression test and leak down proved exhaust valve.
A compression test may be worth while before going too deep.
If you suspect injectors leaking, with a fuel pressure gauge on the test port, cycle the fuel pump, then turn the key off and see how long pressure holds.
It will drop, but a rapid, near instant drop points to something leaking.
The
