Relative compression
Mike T wrote: That is good information! Thanks for it but this is an older model there is no wires going to the injectors the injectors are fired off of pressure.
Oh yeah right second gen... SMH
It all look right but I could have filtered it and inverted my coil but it’s right. Right? Lol I have done a few different tests this was my first one with amp clamp and and it was on backwards I thought. And I didn’t ac couple this one. So should I ac couple? Sorry For so many questions
AJeep18 wrote: not that it is really any easier than using the invert function, but could one just switch the test leads around also?
Yes, you can reverse the leads to invert the waveform. That is how I do it with the Pico. But, know your scope. If your scope shares a common ground with all channels, (and Snap-on does), then you may run into some unexpected results. :woohoo: With Snap-on, I would recommend using the Invert function.
It looks as if you did use a voltage scale on your 2002 Dodge and that is how it should look normally. As the starter is cranked, the voltage load on the battery drops as a cylinder hits it's compression stroke and then comes back up until the next cylinder hits compression when it will drop again and so on until you stop cranking. There is actually no need to invert your pattern because that WOULD make the result confusing. Also, unless there is an uneven cranking rhythm (like in your capture of the other Dodge), I would not be too concerned with trying to find a way to synch your capture with something. At some point in the past, I thought Snap-on had a way to synch a diesel by means of clamping some device connected to your scope to a diesel injector tube.
I hope this helps. Take care,
DougS
DougS wrote: At some point in the past, I thought Snap-on had a way to synch a diesel by means of clamping some device connected to your scope to a diesel injector tube.
There are several companies that make diesel pulse adapters for use with 'scopes and timing lights. They detect the injector pressure pulse in the line going to an injector. So they probably won't work for a relative compression sync with fuel disabled.
Could pull a glow plug and use an in cylinder transducer if you want a sync badly enough...
If you were able to connect some sort of Piezo sensor to the #1 Injector tube and your lab scope, could that solve this issue?
DougS
A pressure transducer would work (as long as it's rated high enough for diesel compression pressures).
DougS.
Matt T wrote:
Yeah but this is a Cummins, intake heater only.
