Test light + banana jacks?
9 years 2 months ago #5213 by matt.white
Replied by matt.white on topic Test light + banana jacks?
I saw that too. Great looking piece of kit. I'm curious to know about the otc kit. I've had a few hit and miss results with otc quality over the years.
  • Tyler's Avatar Topic Author
9 years 2 months ago #5214 by Tyler
Replied by Tyler on topic Test light + banana jacks?
Noah wrote: Wow, a quick search revealed NOTHING!
Looks like you're gonna have to build one... or two :whistle:
:lol: If I figure it out, consider it done!
Was toying with some ideas this afternoon. Something like this Pomona banana jack adapter would work on the 'rope' part, for alligator clips and such. The pointy end... I'm not sure how to go about that. I considered something like this:
www.pomonaelectronics.com/pdf/d72918_002.pdf
I could cut the point off the tester and thread it to accept this M3 stud. Or tack weld it? I'm trying to come up with something that won't be ugly as sin. :blush: I know the electronics gurus around here can come up with something better.
bruce.oliver wrote: OTC 3569
Jackpot! :woohoo: Nice find, sir.
matt.white wrote: I saw that too. Great looking piece of kit. I'm curious to know about the otc kit. I've had a few hit and miss results with otc quality over the years.
Yeah, the reviews I find for this talk about some quality issues... :unsure: Plus, the cheapest I could find was $124. Quite a bit for a scope on a rope!
  • Noah
  • Noah's Avatar
9 years 2 months ago #5217 by Noah
Replied by Noah on topic Test light + banana jacks?
That's approaching Power Probe IV money...
You could probably get a PP3 for $125
9 years 2 months ago #5220 by bruce.oliver
Replied by bruce.oliver on topic Test light + banana jacks?
Found this one. Never ordered from carid
Otc 3969
9 years 2 months ago #5222 by matt.white
Yeah as covered the two otc numbers are in the comments on Eric's video.
I'm keen on making something up if it looks and works well.
9 years 2 months ago #5225 by Tyler
matt.white wrote: Yeah as covered the two otc numbers are in the comments on Eric's video.
Ugh, I should've thought to look there first. :angry:
Same! I think I'll take a shot at this.
Noah wrote: That's approaching Power Probe IV money...
Seriously. :unsure: Or you'd be well on your way to a PP4.
I don't even really need the terminal connectors, I just want the light itself!
  • Noah
  • Noah's Avatar
9 years 2 months ago #5226 by Noah
bruce.oliver wrote: Found this one. Never ordered from carid
Otc 3969
For a hundred I guess it's not THAT bad. It does come in a nice case with all kind of little probe tips and alligator clips...
I might make a trip to the old Harbor Freight and see what they've got to cannibalize.
9 years 2 months ago #5233 by Tyler
Ordered some parts, let's see if I can screw this up! :lol: I plan on modifying an older OTC light that I hardly use any more. We'll see how it turns out. ;)
9 years 2 months ago #5260 by matt.white
I googled banana plugs and came up with stereo equipment. Not sure if they're the same style plug or just the name sake.
I'm sure you'll get it working Tyler.
9 years 2 months ago #5261 by Tyler
I'll try, anyway. :lol: Might be a week before parts show up, but I'll post pics when I put one together.
9 years 2 months ago #5412 by Tyler
Welp, I did it! Buuuuuttttt, it didn't go as planned. :whistle:
For reference, this is what I started out with:
My original idea was to drill and tap the pointy end for one of these . As it turns out, the shank is stainless steel, and (spoiler alert) SS does NOT like to be drilled or tapped. :blush: Solder didn't work, either. We have a MIG welder at work, but the wire won't stick to SS. So, this is where I ended up:
"Tyler, is that two zip ties covered with electrical tape?" Yes, yes it is! :lol: I was really hoping some something more elegant, but it works. With some accessories:
If this ends up working the way I want, then I'll either buy some better drill bits, or some SS welding wire.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 2 months ago #5427 by Dylan
Replied by Dylan on topic Test light + banana jacks?
Cool. Been following this. Also saw that video from SMA using the original Snap On one. Very handy.
Ok your design is still a bit rough :P but it's work in progress right :)
9 years 2 months ago #5430 by Tyler
Dylan wrote: Cool. Been following this. Also saw that video from SMA using the original Snap On one. Very handy.
Awwwww Dylan, you're too kind! :lol:
One big advantage of having the banana jack on the rope end is being able to use it with my AESwave Power/Ground adapter . Before, I'd have to stick my pocket screwdriver into the red port, and clip my light to it. Frustrating. :angry: But now, I can just plug it in and test away!
9 years 2 months ago - 9 years 2 months ago #5442 by User5437
Replied by User5437 on topic Test light + banana jacks?
Here you go. I own one of these. The downside is all the included terminals come as one male and one female, so if you want to jump across a solenoid connector with 2 female pins you have to improvise. I tried twice to paste a link but keeps getting screwed up- there is one on ebay right now titled SNAP ON CIRCUIT TESTER KIT EECT313A00
Last edit: 9 years 2 months ago by User5437. Reason: link error
9 years 2 months ago #5479 by Knoxtech
Replied by Knoxtech on topic Test light + banana jacks?
Otc 3525 and otc 3569 are the same based as what he used but I tried to buy and 3525 and all the sites I purchased from emailed back that it was out of stock. you might be able to get the 3569 but I wasnt willing to give over $200 for a kit with 14 adapters. hoe that helps
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 2 months ago #5485 by Dylan
Tyler wrote:
One big advantage of having the banana jack on the rope end is being able to use it with my AESwave Power/Ground adapter.
Wow I like your adapter!
9 years 2 months ago - 9 years 2 months ago #5488 by Tyler
Knoxtech wrote: Otc 3525 and otc 3569 are the same based as what he used but I tried to buy and 3525 and all the sites I purchased from emailed back that it was out of stock. you might be able to get the 3569 but I wasnt willing to give over $200 for a kit with 14 adapters. hoe that helps
Same here, sir. I bought one of the digital Snap-On lights a few years ago, and that's about the most I'll spend on a light. :lol:
Thanks, sir! It's a game changer when working under the dash. I've also got this Lisle data link connector adapter for similar purposes.
Last edit: 9 years 2 months ago by Tyler.
9 years 2 months ago #5490 by SniperDan
Replied by SniperDan on topic Test light + banana jacks?
The OBD splitter is AMAZING. Any troubleshooting in car is made a million times easier with these badboys, especially since everything is plastic nowadays.
~W. Edwards Deming
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 2 months ago #5512 by Dylan
Man, I am not even aware of great tools like these. :woohoo:
  • Noah
  • Noah's Avatar
9 years 2 months ago #5519 by Noah
Sorry I'm late :oops:
Not bad man, not pretty, but not bad at all! I believe in function over form any day.
I wonder if a cheaper test light wouldn't have been so resistant to modification.
Time to create page: 0.450 seconds
