OTC Genisys Modifed as Windows 7 Tablet / Diagnostic Scanner
- eric_generic
- Thank you received: 9
Or, making a NANdroid backup of your genisys then running that to a pc with an android emulator in a windows os, or directly with an android os on a pc. That option works on an android phone, cloning the os then placing it in a same type of phone. Again, I'm not quite sure if it will work on your genisys.
Maybe some of the members here that are more computer-inclined could add/share more information. What you did to your genisys breathes a new life to it and that was pretty slick.
Regarding that ALT+TAB problem of yours, you could try to create a batch file that contains the ALT+TAB command then pin that file to your taskbar in windows so that it will be a one-click maneuver. But that would work only if you're in windows going to diagnostic hub. Going vice versa, I'm afraid I don't have a solution for that because even though you lock the taskbar, it will not show once the diagnostic hub is in fullscreen mode.
- graywave
- Thank you received: 80
If you open/disassemble your genisys, you might find a hard disk just like the verus. Then try cloning it and go from there. There was a guy on youtube that installed a windows 7 on his verus that did that cloning the hard disk stuff. But that was bringing windows to the scan tool not the other way around. You can, after cloning the hard disk, try booting it on a pc although I'm not quite sure that it will work but the idea is there.
Already did. Removing the MSata SSD, putting it into an adaptor and hooking it up to my PC was the only way I could edit the registry off line and make the changes required to get into explorer. After I was able to gain access to it I then had to reset the group policies for all accounts, even administrator because they had windows locked down hard.
I made a block level disk image of the original setup just in case I screwed it up. I also did a file level copy so I could play around with the files and registry before editing everything on the ssd.
OTC (aka Bosch) used Windows 7 Embedded Standard so no need for android emulatorsOr, making a NANdroid backup of your genisys then running that to a pc with an android emulator in a windows os, or directly with an android os on a pc. That option works on an android phone, cloning the os then placing it in a same type of phone. Again, I'm not quite sure if it will work on your genisys.
I also have all the updates saved so anyone who has the OTC Genisys Touch can grab the updates for free. They would need to remove the SSD though, copy the files and some how execute the exe files to update their device.
I don't have an issue with the ALT+TAB anymore. Now that I use DexPot Virtual Desktop software I can easily switch back and forth with the mouse arrow. Once DIAG HUB is loaded, its in kiosk mode and you could not gain access to the taskbar or explorer previously. Now I can with Dexpot software.Regarding that ALT+TAB problem of yours, you could try to create a batch file that contains the ALT+TAB command then pin that file to your taskbar in windows so that it will be a one-click maneuver. But that would work only if you're in windows going to diagnostic hub. Going vice versa, I'm afraid I don't have a solution for that because even though you lock the taskbar, it will not show once the diagnostic hub is in fullscreen mode.
- graywave
- eric_generic
- graywave
- graywave
This is still a work in progress as I am wondering how far I can go with it just out of curiosity. Thinking of either getting the software to run on a laptop or getting a bigger M-SATA drive and partitioning it so I can run OE programming software from it.
It was updated to the latest and last update v3.8 so its has up to some 2017 and most if not all 2016 now.
Original Video - OTC Genisys Touch 3895 Modified Windows 7 Tablet / Diag Scanner (Part 1)
Original Video - OTC Genisys Touch 3895 Modified Windows 7 Tablet / Diag Scanner (Part 2)
Purchased a RII Bluetooth Portable Keyboard for it.
- Mkpirulo
Thanks
- graywave
I was trying to help another guy remotely but its proving to be difficult.
- Mkpirulo
Do you have any documentation on how to get the OTC shell installed into win 7 ?
Thanks
- graywave
Basically there is a lot of registry edits and changes to many security policies that allow me to use it how it is now.
- Mkpirulo
Have another question. I'm trying to clone my spinning drive to an ssd. This way I will always have the original drive if anything goes wrong with the ssd. Have you had success doing this? I tried with no luck, is there something that I'm missing? The ssd boots initially into Windows but then sends an error code. It seems as if not all files were cloned.
Thanks
- graywave
- Mkpirulo
- graywave
1. I have not been able to create a 100% successful bootable image of my drive. I thought I did in the beginning but the image is not a bootable image. Even after creating a new image of how it is now won't boot completely, it wouldn't load into windows desktop. Hung up at the windows loading screen. This was probably due to the recovery partition I created using AOMEI Backupper. I was in contact with another user who managed to create a bootable image and was able to boot into windows but the OTC Diagnostics software would crash when loading and was unsuccessful at getting it working. Luckily he did this on a spare drive which is smart.
Some members have not had success with even my MODIS images either. Maybe it was the AOMEI software I used to create the images that is creating the problem.
If others have suggestions I am open.
2. I won't modify the hard drives structure of windows registry remotely or send files for you to use. I only did this once and there were MANY MANY steps involved and can't remember all of them. I had thought about saving the registry changes only but I don't want to be responsible if a batch file or registry file doesn't work out since you still need to make all the changes offline as in, removing the drive and hooking it up to another PC. I would only do this if I was thoroughly convinced to and you would have to send your Genisys Touch Scanner to me. Reason is due to Windows being activated with a serial number in the BIOS and its possible the diagnostic hub reads hardware IDs too.
4. Unfortunately all these changes take a LONG time and I wouldn't be able to do it for free. I think one guy I was going to charge $75 but between him and I we couldn't make it happen remotely so I ended up not charging him for obvious reasons.
I am all for helping others but I want to be reasonable too.
Just to make others jealous... I use my Hantek 6074BE 4ch scope on my Genisys Touch
- graywave
- Mclaren1234
i have perfect connection to the internet.
Any idea what may be causing this?
- pedroanacondra
- Lostinthis89
Thanks
Zach
- Lostinthis89
please some body help me out this has turned into over a year issue and i really need it up and running.
- pimpidj
thanksssss
