Power probe 3 question
- scopeman
- Thank you received: 3
With starters and alternators a high resistance connection will usual very rapidly become hot to the touch.
- Thank you received: 1539
It's possible? But it definitely wouldn't be my first choice. :lol:
- scopeman
Yeah i agree i prefer to use dvom for volt drops .Just got hold of a power probe 3 with gold kit and extra extension.Is there a way to use any of the extension leads with a dvom as one side of the lead is keyed so will not fit into a dvom (be handy if it could )?Tyler wrote: I'm not sure that you could connect it in the same way as a DVOM and get the same results.
You could theoretically use the voltage reading feature on the B+ and solenoid circuits, as long as the reading doesn't disappear from the display below a certain voltage.
- Thank you received: 1116
I really like the little yellow fuse blade attachments
- scopeman
Is there a way to use the 20ft spare extension lead that i got with my kit to hook up to my dvom ? can use the probes and other leads as they are standard but the extension lead is keyed?Noah wrote: I use the gold series leads with my scope and meter all the time!
- scopeman
Sorry for the giant link...
www.tooltopia.com/lisle-69250.aspx?utm_s...LxClg7BoCqZ4QAvD_BwE
- scopeman
Thank you .Noah wrote: The yellow and black is the one that came with my Verus, and the other two are out of the Lisle Relay test kit. They were just the first two I found that fit in there from my bag-o-test leads.
