Re:Re:Re:APT-100 Pressure Transducer
- Thank you received: 1542
APT is showing right at 116 PSI. Again. But the PV350 says otherwise:
Flukie says 166 PSI, which I find to be much more reasonable. Interestingly, if you take 1.16V, change that to 1160 mV and figure 1mV/kPa, you get to 168 PSI. :silly: Not sure if that's a coincidence or not.
Anyway, I tried some running compression waveforms as well. Turned the scales down for more detail.
#1 definitely doesn't look right.
So maybe there's leakage in the hose or adapter, right? Nope, I got it to hold vacuum with a hand pump. Maybe that cylinder really is leaking? Moved the PV350 to #1 and got good waveforms. What the hell. :blink:
Tried the same setup on my '15 Equinox and the problem got even worse:
You don't have to be an expert to know something's wrong here. Aside from the transducer itself, the only thing I can figure is there's something wrong with the provided compression hose. :huh: The APT-100 uses a different style (Foster? Honestly don't know) connection than most compression testers (Milton M-style). That means I can't use any of my existing compression hoses, or swap hoses between transducers for test purposes.
Maybe the included hose just sucks? :lol: Juergen had mentioned the APT-100 benefitting from a stiffer hose. As always, any thoughts you have are welcome!
- juergen.scholl
- Active partschanger
- Thank you received: 462
when I got my APT 100 the passage within the brass portion of provided hose was bad/clogged and caused erratic results. After drilling it out it performed much better.
Nevertheless I changed the interface/coupler on the transducer itself so I can work now with any standard compression hose.
- Matt T
- Thank you received: 276
I was thinking it looked like a restriction/snubber between the cylinder and transducer was at least part of the problem.
Regards the kPa looking peak pressures see what the thing reads with a known shop air pressure. Then you'll know whether you've got a kPa unit or not.
Interesting. :huh: I'll have a look at mine tomorrow.
Definitely going to do that. Do you happen to have a link to the coupler you're using? While I'm at it, I'll probably buy a sacrificial compression hose to use for intake pulse testing.
Another excellent idea.
Back in #1 on the Sentra, the cranking compression is closer to what I was seeing with the PV350:
My whole kPa scale idea is out - 1,550 kPa converts to 224 PSI. :lol: 155 PSI is much closer to the 166 the PV350 was reporting. The running compression still isn't perfect...
I'd do another direct comparison capture, but I scavenged the coupler off the PV350 to make the APT work. :silly: I'll get another coupler and follow up later.
- Thank you received: 1122
Looks like a quality tool.
I'm looking to up my transducer game, but I think that also is going to me uppingy scope game, lol.
Coming from the guy that makes his own transducers? I think your scope and transducer game is fine just fine.
I got around to comparing the adapted APT-100 and the PV350 in another known good engine. This time it's an '11 Kia Sportage 2.4L. Cranking first:
The rulers show these two reading within a few PSI of each other. Good enough for me.
The APT compression tower still seems to be leaning/asymmetric.
I also had the chance to try the APT on a known blown head gasket. '08 Equinox 3.4L. APT in red on the coolant bottle, sync on #6 in green:
The way this sensor behaves is noticeably different than other head gasket captures I've taken with normal pressure pulse sensors . There's the building of pressure (which is a red flag by itself), AND there's enough detail to tell which cylinder is blown:
Firing order is 1-2-3-4-5-6. The pressure rises in the cooling system immediately after #2 compression.
All in all, I'm pretty satisfied. For the price. :silly: It's not perfect, and it needs some modification out of the box to make it useable. But the capabilities are there, and the price is right.
- Ben
- Thank you received: 215
- Ben
Well I was having a hard time deciding on the apt-100 or the wps500x... my cheap side won and I ordered the apt-100. I'll let you know how mine works out of the box when it makes its trip from china.
Congrats! Mine took about two weeks to arrive from the mainland. Let me know how it treats you.
Also way off topic for this thread but I see your still using the autel, I bought there newest 1 last year (without scope module as I already had there mp408 scope)(turns out not compatible) but I don't love there data vs snapon... what erks me the most is some pids can't be graphed.... and there graphs aren't all that good... anyways all this to say how has your transition gone?
Overall? I'm still very happy with mine. Going on two years now. Wouldn't hesitate to buy one again. Well, maybe I'd wait a year for the price to go down. :blush: Definitely took the place of my Snap-On as the go-to tool.
Maybe I'll start another thread? I love the Ultra, but it's far from perfect. :lol: I'd love to hear your thoughts.
- juergen.scholl
- juergen.scholl
- Ben
- juergen.scholl
Well it showed up yesterday! Without a battery...
So came mine, official reason being lithium battery transport is soooooo dangerous :dry: Nevertheless you can testdrive it with just the usb charger connected.
BTW did you need any special fittings to connect air coupler?
No, I did not. Straight forward job.
Well it showed up yesterday! Without a battery.... so I jumped on Amazon to order a button less 18650 because my regular 18650s didn't fit (who knew there were different length 18650s....) anyway it theyvarrived today so straight to the charger it goes!
Ah yeah, it's like Juergen said with battery shipping. For anyone else considering an APT-100, I bought this set on Amazon:
www.amazon.com/dp/B06ZZ8Y89F
In the mean time I looked at the hose and decided it did in fact need drilled out so into the lath to get a nice centered drill hole and about 3/4 inch in the brass fitting broke off.... soooo time to replace the stupid coupler they come with and switch to automotive style..
:lol: Figures.
I'll let you know how that goes when I get there. BTW did you need any special fittings to connect air coupler?
I'll see if I can figure out which fitting I used... Stole it out of my oil pressure test set.
EDIT: Pretty sure that's a 3/8-18 NPT male to 1/8-27 NPT female fitting.
- Ben
Haven't had a chance to use it yet, I did get it changed to some nice high flow connectors though. I've been working on a tailpipe adapter without much luck, im looking to do something like ATS tailpipe venturi but apparently that is harder to design without seeing the insides of 1 then I guessed because my test today was a fail
The tailpipe venturi from the E-Misfire kit? Never thought about trying to duplicate that. :huh: I was thinking about trying to do something like the Jarhead Diagnostics exhaust adapter for pressure pulse sensors:
www.jarheaddiag.com/shop/p/jarhead-diagnostics-exhaust-hose
- Ben
- Matt T
The patents will help you copy it :lol: I've attached the first one. There are two more but they don't add much besides a screen for laminar flow.
Judging by the "prior art" Bernie had to invent this thing because he couldn't figure out how to use a piezo :lol: :silly: :lol:
I did make 1 of the spring hoses last year but I've never cared for the tailpipe pulse sensor with engine running
My piezo did a lot better sitting on the ground instead of hanging off the tailpipe. 1/4" brake line and 3/16" thinwall rubber tubing. IIRC Chad uses a mic stand for his
