Key Programming Tool
Any information would be greatly appreciated. Thanks.
- Thank you received: 961
- jutinkatherne
- MarinaGomez
So,if you just want to program keys,it is better that you ask local auto locksmith to do it.Save you time,time is money!
www.chinacardiags.com/wholesale/lonsdor-...eries-smart-key.html
it's lonsdor brand
- Gazmendhajra
- Thank you received: 8
- JustinWinslow
- JamesMichael
Well, it is still that way. But with aftermarket guys, things have changed, in fact you get more reliable repairs with professional aftermarket techs, and thanks to the movement by Paul.
Now local locksmith are aftermarket guys, and anyone can. If you can provide such service where you are, then that's a plus. You must commit time to it.
Programming has much been big points for dealers, and that has changed. I understand time, but if it is what you want to do, then it is possible.
Toyota happens to be one of the easiest cars to program keys for, especially via obd.
Like you said, you own a techstream already. Well, that's all you need. Yes you can add keys, and you can do all key lost with the techstream. The only difference is, for all key lost reset, you are given a seed, which you will use to calculate a passkey.
A lot of platform offer this service for a token between 10 to 15usd
One is weboctopus.nl.
The lonsdor K518, Autel maxis 908 are great programming and key programming tool.
Key Programming is car Security, the information is not what you just stumble upon on Google. But there are loads of them and hands on training you can get.
To become more conversant if you are on a budget, you can get the x300 pro3, or x100 Pro2. They are key programmers, for adding keys and all key lost on a wide range of models
If you have any other specific questions, I will answer
Toyota Camry 2.5Q 2018 smart key All Key Lost programming
DAB wrote: I would like to know if anybody has had any luck with any of the key programmers out on the internet. I have had two instances where I needed to program keys on a Lexus/Toyota with a Smart Key System. One customer lost there keys to there vehicle and the other customer needed a new Certification ECU to be programmed. Unfortunately I had to sublet the vehicles out to the local dealer, but would like to do this myself. I have a Solus Pro and a Mongoose to use the Toyota/Lexus platform to add keys, but not reprogram. To do this on the Toyota/Lexus platform you must have a Locksmith ID number. I have tried using a local Locksmith in the past, but the person created more issues for me and left me with having a bad experience. Not willing to use them again. Tried an SKP-900 Key Programmer, but it did not help me out either.
Where are you located? There's alot of options out there. Just depends on how deep you want to get into it.
.talk with a few shops in your area and see who they use for programming, etc.
Give Carlos @AESwave.com a call. You may have to leave a message or speak with one of the other guys.
Do you have enough of this work around to keep one of your guys busy alot? IF so then maybe that's a path you could look at offering this type of service.
Check out the IM-608
Speak with Keith Perkins from L1 Automotive and Diagnostics as he does alot of keys he's got a nice setup last I saw and has his wife in the business now I think. He can take a picture with his phone and send it via Bluetooth to his Key Cutter.
To do this work go to Nastf.org I believe it is as they're a non-profit .
Also one needs to be bonded which you'll have to submit your certificate of liability insurance. This allows you to get key codes for cutting, programming, etc.
I will say I have a IM-608 and they constantly update the software almost weekly. Autel is very responsive.
They have scan tool guys in support, they have immobilizer support guys as well.
My suggestion is get ahold of Carlos and if he don't know it he can get the answer for you.
I had a issue with my IM-608 and emailed Carlos and within a hour I had a call from Autel. AES will support you even if the mfr has support as they want to help bridge that gap.
Check out flash performance on YouTube. Also Autel recently released a video of the IM-608 pro which is the former 608 with the kit.
I have the G-Box for pulling codes from Mercedes Benz on a all keys lost. Cuts the time in more than half. I did get the Toyota adapter as well and the tool alone from what I recall will support 98% of the North American market..
It's a little on the $3-4k side last I recall give or take but remember you've got to spend money to make money. IF you get into one make sure you're adsorbing information all the timeo, advertise the services and if you're doing it for customers by all means do it legally in regards to the bond as there's information that as a locksmith/programmer you have to retain by law. It's on the NASTF website.
There's alo a good thread where they talk about some of the bad actors. The article if on DN or as some call it Diagnostic Network.
What's the year make and model of vehicle you're trying to program for? I can look and see what options the tool can do for that specific vehicle.
You can private message me as well.
