Oxygen sensor wire harness test
8 years 10 months ago #9681 by Tyler
Replied by Tyler on topic Oxygen sensor wire harness test
Hey sir! Looking at your fuel trims, and they appear reasonable to me. :huh: The warmed engine at 3500 RPM shows a slight rich condition, with the total trim on bank 2 around -12%, but this really isn't that bad overall.
What'd really be valuable would be trims and a few other inputs during the low power condition. Short and long term trims on both banks, the TPS, MAF, Engine Load and both upstream O2's would be the ones to watch. Those will spell out if there truly is a fuel problem or not.
Ideally, you want to see the upstream O2's go below 3.3V (or less than 1.00 lambda) during wide open throttle acceleration. The Engine Load should exceed 85% when accelerating from a dead stop through first gear and into second. The MAF should go over 4V, and the TPS should reflect the throttle going all the way to the floor.
  • babajis2010
  • babajis2010's Avatar Topic Author
8 years 10 months ago #9699 by babajis2010
Replied by babajis2010 on topic Oxygen sensor wire harness test
I adjusted my throttle cable myself by giving it some free play and I don't have any jerking anymore. The rich condition of -8.59 at 35000RPM was done when the car was sitting in the car park. I hooked up an OBD2 and went on a drive after fixing throttle cable and my eyes were on short term fuel trims on both banks and they stayed for the most part around 97% of the time on highway 1.56 to -2.34. So it looks like my car is fixed but I will fill up my tank next week and check my MPG.
Will update, but if anyone is reading this please check your throttle cable first because it's function is the same as TPS and all oxygen sensors, if not properly adjusted it can destroy your CAT.
Time to create page: 0.261 seconds
