2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
- Hardtopdr2
- Thank you received: 148
I was half awake with the last response so yes that is a valid point and I will check that out.
- Hardtopdr2
code was a p0365 so I will look into that as a precaution.
- Grouchyoldman
- Hardtopdr2
- ScannerDanner
- Administrator
- Thank you received: 498
Now on to the problem, it is a no start unless the exhaust cam is unplugged. What codes did you have before you started unplugging and testing sensors?
When I have seen a problem like this, it was a correlation problem with the cam/crank sensors. As in jumped timing belt/chain or as Cheryl said, a slipped tone ring. I would think you would have had some correlation codes but maybe not.
Don't be a parts changer!
- Hardtopdr2
Engine
P0137 | HO2S Circuit Low Voltage Sensor 2 (Symptom 00) - Test Failed Since DTC Clear, Test Not Passed Since Power Up.
P015B | HO2S Delayed Response Rich To Lean Sensor 2 (Symptom 00) - Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up.
P0299 | Engine Under Boost (Symptom 00) - Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up.
P0365 | Exhaust Camshaft Position Sensor Circuit (Symptom 00) - Current DTC, Test Not Passed Since DTC Cleared, Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up, Warning Indicator Requested.
Airbag
B1325 | Control Module Power Circuit Voltage Below Threshold (Symptom 03) - History DTC.
U0184 | Lost Communication With Radio (Symptom 00) - History DTC, Test Not Passed Since Power Up.
Body Control Module
B1517 | Battery Voltage Voltage Below Threshold (Symptom 03) - Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up.
B3883 | License Plate Lamp Circuit Short To Battery (Symptom 01) - Test Failed Since DTC Clear, History DTC.
B3883 | License Plate Lamp Circuit Short To Ground (Symptom 02) - Test Failed Since DTC Clear, History DTC.
B3883 | License Plate Lamp Circuit Open Circuit (Symptom 04) - Test Failed Since DTC Clear, History DTC.
C0755 | Right Front Tire Pressure Sensor Too Few Pulses (Symptom 29) - Current DTC, Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up, Current DTC Since Power Up.
U0168 | Lost Communication With Keyless Entry Control Module (Symptom 00) - Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up.
Keyless Entry
B3120 | Keyless Entry Antenna 2 Short To Battery Or Open (Symptom 05) - Current DTC, Test Not Passed Since DTC Cleared, Test Failed Since DTC Clear, History DTC, Test Not Passed Since Power Up.
Tire Pressure Monitor
B1517 | Battery Voltage Voltage Below Threshold (Symptom 03) - Test Failed Since DTC Clear, History DTC.
As you can see no correlation codes etc even though it has a laundry list of issues though most were from owner trying to figure out what was preventing the car from starting.
current reviewing waveforms as I took quite a few so hopefully I find something will post a pic in the morning.
- Cheryl
- Thank you received: 215
- ScannerDanner
- Administrator
agree 100%If it were me I’d still find a known good cam crank relationship on iatn check anyway to rule it out for good. Will the sensor bolt on from intake to exhaust? Maybe try swapping them?
- ScannerDanner
- Administrator
- Hardtopdr2
- Cheryl
- Hardtopdr2
- Cheryl
- Thank you received: 1519
- Hardtopdr2
- Hardtopdr2
- Cheryl
- Cheryl
- Hardtopdr2
- ScannerDanner
- Administrator
I have Luke on this!Hardtopdr2, the whole mimi error has been cropping up recently. I've found that using PNG instead of JPG gets around it. Sorry for the hassle.
