2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
4 years 3 weeks ago #51814 by Cheryl
If it were me I’d still find a known good cam crank relationship on iatn check anyway to rule it out for good. Will the sensor bolt on from intake to exhaust? Maybe try swapping them?
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
4 years 3 weeks ago #51815 by ScannerDanner
agree 100%
Don't be a parts changer!
  • ScannerDanner
  • Administrator
  • Administrator
4 years 3 weeks ago #51816 by ScannerDanner
When you clear codes, does it continue to set the exhaust cam sensor fault?
  • Hardtopdr2
  • Hardtopdr2's Avatar Topic Author
4 years 3 weeks ago - 4 years 3 weeks ago #51824 by Hardtopdr2
Alrighty then after going through 20 plus waveform files I caught it messing up once
Last edit: 4 years 3 weeks ago by Hardtopdr2.
4 years 3 weeks ago #51825 by Cheryl
What’s it look like when it messes up? Drop out? Stuck high?
  • Hardtopdr2
4 years 3 weeks ago #51826 by Hardtopdr2
Sticks high and low tried posting a pic but keeps bringing up mimi file error it's a jpg file
4 years 3 weeks ago #51827 by Cheryl
Make sure your not dropping the 5 volts or ground. Use 3 channels on the scope or just 2. One hooked to 5 volt ref and ground and other to signal
4 years 3 weeks ago #51830 by Tyler
Hardtopdr2, the whole mimi error has been cropping up recently. I've found that using PNG instead of JPG gets around it. Sorry for the hassle. :(
  • Hardtopdr2
4 years 2 weeks ago #51838 by Hardtopdr2
i even reduced it in size below 5 mb (4.52 mb) in png and still no go on upload lol
  • Hardtopdr2
4 years 2 weeks ago #51840 by Hardtopdr2
ok managed to put it as a pdf finally it is zoom out to show the whole capture
File Attachment:
File Name: 2014chevycruze.pdf
File Size:98 KB
4 years 2 weeks ago #51841 by Cheryl
Make sure you ain’t losing 5 volt ref and low reference. If it’s that intermittent I’d be half tempted to throw a new gm sensor in
4 years 2 weeks ago #51842 by Cheryl
Is the intake and exhaust cam sensors the same part number? Maybe try swapping them
  • Hardtopdr2
4 years 2 weeks ago #51843 by Hardtopdr2
I looked that up today and it looks like it is the same part number
  • ScannerDanner
  • Administrator
  • Administrator
4 years 2 weeks ago #51846 by ScannerDanner
I have Luke on this!
The following user(s) said Thank You: Hardtopdr2
4 years 2 weeks ago #51848 by Tyler
Well I don't know any more, then. :silly: Just as soon as I've got it figured out...
Definitely swap the sensors, as long as it's halfway accessible. I got $5 that says you'll find a Dorman sensor in there. ;)
  • Hardtopdr2
4 years 1 week ago #51967 by Hardtopdr2
Well I put a new one in and still threw the code and it was not a Dorman sensor in it and it still did not start with it plugged in. I also pulled the valve cover off to verify timing ( which miraculously it stopped perfectly lined up ) as well as center oiler plate to make sure it's tight and all was good in that respect. It did reset code p0365 as well after clearing them and trying to start it with new sensor plugged in. May try a crank cam relearn on it when I get back in town for grins. But not confident on it working given how everything else played out. Will let you know more when I get back to it.
4 years 1 week ago #51969 by Cheryl
The only other thing I can think of is are the wiring terminals in the correct order? I had a Ford alternator where someone was messing around swapped pins in the connector. Bug it very well could be a pcm
2 years 11 months ago - 2 years 11 months ago #58834 by Jasondragon
When you have your cams on top dead center with the crank make sure the back of the cams are facing each other the cam lobes because if they're facing away on top dead center that means the cams are flipped because mine is doing the same thing it runs with the exhaust cam sensor unplug but when it's plugged in it does not run
Last edit: 2 years 11 months ago by Jasondragon.
2 years 11 months ago #58840 by Jasondragon
  • Hardtopdr2
2 years 11 months ago #58848 by Hardtopdr2
Thanks for the info. The motor was swapped out from what I was told before I looked at it. Granted I don't remember which way the cams were facing as this was a year or two ago. But will keep in mind the next time I run into this. Most appreciated thank you
