Alternator "voltage booster" for AGM battery retrofit
- czgunner
4 years 10 months ago - 4 years 10 months ago #50474
by czgunner
Alternator "voltage booster" for AGM battery retrofit was created by czgunner
Not a diag question, just something I'm curious about and wanted to know if anybody has an answer.
I just started hearing about people installing these in vehicles that have had an AGM battery retrofitted. Specifically I was reading about a guy that replaced the lead acid battery in his 2016 4Runner with an aftermarket AGM battery. The battery requires 14.6 volts to charge properly and the stock Toyota ECM limits charge voltage to 13.6 volts. Apparently guys are installing the GM charging circuit diode HERE . I am curious if this is actually sending any more voltage to the battery? If alternator output voltage is going up due to higher resistance, what is the voltage change at the battery? How does this diode affect charging voltage? Does it have a resistor? If so, wouldn't the resistance be dropping the voltage after the diode? I don't believe Toyota is monitoring amperage use of the vehicle at the battery. Maybe I'm overthinking this. If I have this all wrong, can somebody please explain to me what is going on?
Last edit: 4 years 10 months ago by czgunner.
- Matt T
- Thank you received: 276
4 years 10 months ago #50479
by Matt T
Replied by Matt T on topic Alternator "voltage booster" for AGM battery retrofit
They appear to be putting the diode in the PCMs voltage sensing circuit. What the diode is doing is dropping the voltage sensed by the PCM by the diodes forward voltage. Probably about 0.7Vish. That'll trick the PCM into commanding higher charging voltage.
4 years 10 months ago #50510
Replied by Andy.MacFadyen on topic Alternator "voltage booster" for AGM battery retrofit
13.6 v seems low I suspect the.ECM is controlling charging voltage by PWM. If it is using PWM I can't see a diode working.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 10 months ago #50511
by juergen.scholl
Replied by juergen.scholl on topic Alternator "voltage booster" for AGM battery retrofit
If the charging voltage is pwm controlled by the ecm based on a voltage sense circuit, a diode with its voltage drop would make the ecm see a slightly lower system voltage and in return crank up the pulse width in order to reach the desired charging voltage, wouldn´t it?13.6 v seems low I suspect the.ECM is controlling charging voltage by PWM. If it is using PWM I can't see a diode working.
