2006 Pontiac G6 GTP with Auto Hvac, no blower motor function.
  • Chuck69
  • Chuck69's Avatar Topic Author
5 years 6 months ago #43371 by Chuck69
Mr. Danner and I were testing this on YouTube. He then sent a message to move it here while he looked up some service info.
For those not in the loop, basically, I have my voltage where needed. If I supply a ground to that side of the motor, it spins on high. There is not
any speed control from the head unit.
5 years 6 months ago #43372 by Matt T
Looks like you've got a 5 wire blower control module. You'll have power and ground to the module, the two motor wires, and a thinner PWM control wire from the HVAC controls. Sounds like the module has power. Have you checked it has a good ground yet? If that checks out go after the PWM signal wire. Best to check it with a 'scope. If you only have a DMM you can see if the voltage on the wire changes when you adjust blower speed.
  • Chuck69
5 years 6 months ago #43380 by Chuck69
There is a good ground, all power looks good too. The PWM stays about 4.7v not matter the control position.
5 years 6 months ago #43384 by Chad
File Attachment:
File Name: 2006pontia...hvac.pdf
File Size:630 KB
The following user(s) said Thank You: Chuck69
5 years 6 months ago - 5 years 6 months ago #43395 by Tyler
Courtesy of Chad, we have the wiring diagram. :woohoo:
If you wouldn't mind? Key on, blower motor on high, backprobed at each pin, what are the voltages on each pin at the blower motor control module?
Last edit: 5 years 6 months ago by Tyler. Reason: DON'T WORRY ABOUT IT
  • Chuck69
5 years 6 months ago #43405 by Chuck69
A- Ground
B- 4.72
C- D-E all have Bat V, dependent on state of charge
5 years 6 months ago #43480 by Matt T
Chuck69 wrote: The PWM stays about 4.7v not matter the control position.
That was unexpected!!!!! It's usually the blower module.
Retest the PWM control wire unplugged just to rule out the blower module. If you still don't have PWM control work towards the HVAC controller in the dash.
