[FIXED] 2004 Subaru Forester no spark on #4 cylinder.
- Climber
5 years 1 week ago - 5 years 23 hours ago #43110
by Climber
[FIXED] 2004 Subaru Forester no spark on #4 cylinder. was created by Climber
2004 Subaru Forester has about .9 volts at connector while running backprobed at ECU about half that on #4 which is not firing. Replaced original ECU because car died progressively and finally wouldn’t start. Installed a used ECU and now it seems that there is an issue with it also. I’m not sure what the voltage is supposed to be but 1,2 and 4 are all similar so I’m assuming there is a problem with the ECU. Am I wrong?
Last edit: 5 years 23 hours ago by Tyler.
- Climber
5 years 1 week ago #43111
by Climber
Replied by Climber on topic 2004 Subaru Forester no spark on #4 cylinder.
Actually 1,2 & 3 are all similar
- Hardtopdr2
- Thank you received: 148
5 years 6 days ago #43138
by Hardtopdr2
Replied by Hardtopdr2 on topic 2004 Subaru Forester no spark on #4 cylinder.
Check your wiring ohm test each wire going to #4 and load test it with a test light. Something tells me you will have high resistance on them or possible a open in the harness.
- Climber
5 years 23 hours ago #43308
by Climber
Problem solved! Bad pin connection at ECU. COP ignition. #4 (B15) had sloppy fit causing high resistance. Son is VERY happy now lol. I’m working 7-10’s and some 12’s and haven’t had much time to diagnose it. He’s an aspiring tech and though I am not I’m trying to teach him not to be a parts replacer. Fuel pump, relays, temp sensor, cps, cam ps, timing belt were all suggested to be bad by his friend/mechanics lol. Told him we’re not replacing so much as a fuse until there’s proof of failure. This site et al is the best! Would’ve pursued this as a career when I was a kid If there was a Scanner Danner 45 yrs ago and a site like this. Thanks for the input!
- Hardtopdr2
5 years 20 hours ago #43312
by Hardtopdr2
No problem glad to hear it was a cheap fix
