Engine cranks but does not start - Holden Colorado
- Hardtopdr2
- Thank you received: 150
- 4JJTroopie
My appologies for re-opening this thread but it is the closest I have found that describes my problem. If the issue was resolved then I'd love to hear what the final outcome was. My conversion is a Colorado/Dmax 4JJ1 motor, Mtr harness and ECM into 1996 HZJ75 Toyota troop carrier. ECM has had all immobiliser functions disabled so as to run as an engine only installation. So the problem I have is "Engine cranks but does not start". I have been through the service manual fault processes both section 1 and 2. The only thing I have been able to find is the ECM pulse and power to the injectors is missing. This tread covers the injector wiring and power question in detail and I have done checks as well. Injectors are -ve switched so I power is on at injector once ign is on. Wiring diagram confirms this. Power is provided from 2 internal sources to Inj 1 & 3 and 2 & 4. Each injector is then wired back to an individual -ve ECM switching terminal.
1. No power to injector when ignition is on or during cranking
2. No -ve pulse (ie Test lamp from bat +ve to injector -ve wire) with ign on or during cranking.
3. Continuity tested wiring harness from Inj plug to ECM plug. All good.
I don't have the ability to internally try to pulse the injector with a scanning tool. But intend to do this to prove the ECM was Ok or faulty.
I don't know what conditions need to be met for the ECM power and pulse to be provided to the injectors so am open to any thoughts and feedback.
- Saverauto
To this day I don't think it was ever fixed.
- 4JJTroopie
So it seems we now have 3 ECU's displaying the same symptoms. I appreciate my ECU is not the same as the Colorado but it suggests the condition that needs to exist for power and pulse to occur at the injectors is likely/possibly to be the same.
I will pickup the fault finding at the CKP sensor, something I haven't done yet and also get a tech with a scanner that can manually pulse the injectors to confirm the ECU is ok. If anyone knows what conditions need to exist for the ECU to pulse the injectors then would appreciate your input.
It is worth commenting that because this is a motor conversion, I also did an intake and EGR clean so all the fuel lines were removed and required bleeding.
This was a considerable effort but I did get the engine to run for short periods (2-3 sec) quite consistently but wouldn't continue to run. The car then sat for a few days and here I am today. So something has changed or the fault has developed further.
- juergen.scholl
- Active partschanger
- Thank you received: 462
Cut out/missing injector pulse is a prominent mean to immobilize the engine on many MMY.
- 4JJTroopie
- 4JJTroopie
- 4JJTroopie
If anyone has any thoughts on what I'm missing then please jump in.
- 4JJTroopie
1. Removed the return flow from the low pressure lift pump. No return bubbles.
2. Cracked open the HP supply to injectors at fuel rail. Each showed fuel present.
3. Checked FRP reading. 162540kpa
4. Removed the leak-off pipe from each injector. Leak-off from each was the same.
So from what I can see there is fuel at the injectors, fuel pressure and ECM injector pulse 4.53v DC and injector coils all 0.5 ohms. Only thing left that I can think of is to do a "Force Trigger" from the ECM to see if the injector is actually operating via the pulse from the ECM. Unfortunately I don't have a SCAN tool I can use but do have a regulated power supply so can manually trigger them. Not quite the same but will prove the injectors are not stuck.
- 4JJTroopie
- Bas7
- 4JJTroopie
- 4JJTroopie
- 4JJTroopie
- 4JJTroopie
- 4JJTroopie
