(Fixed) 2015 Silverado 1500 Reverse works but forward doesn’t
- John Curtis
- Thank you received: 111
I think checking the input speed chart vs output speed shaft sensors may be the answer depending on if it goes that direction.
- Matt T
- Thank you received: 276
Guessing it's got a 6L80 in it so this might help.
atracom.blob.core.windows.net/webinars/gm/6l80_introduction.pdf
- ScannerDanner
- Administrator
- Thank you received: 500
Don't be a parts changer!
- Matt T
ScannerDanner wrote: no forward gears at all? I wouldn't be worried about input and output speed sensors. I can't think of any electrical faults that would cause no forward gears at all. Get a scan tool on that thing and see what you have in the TCM to start with
Electrical faults outside the transmission probably not. An internal fault with shift solenoid # 2 looks like it could cause no forward gears if the truck does have a 6L80. If that is the problem hopefully it will have set a code in the TCM. Or if it hasn't 'scoping current draw into the TCM might show it. Looks like you should be able to see its current ramps shifting back & forth between P & R.
- Thank you received: 1541
- John Curtis
That PDF that Matt T posted is fantastic.
- Matt T
Tyler wrote: That PDF that Matt T posted is fantastic.
ATRA/Gears magazine have a lot of good stuff on electronically controlled transmissions. They're where I look first when I've got a tranny problem that might be fixable. And I usually end up reading other articles while I've got the site pulled up.
- John Curtis
Do you recall which solenoid, exactly? Any concern that the solenoid smoked the driver?
