Siennna 2000 high fuel trims error p0171
- seraj2000
- John Curtis
- Thank you received: 111
What does freeze frame show?
What is afr values during throttle snap?
- juergen.scholl
- Active partschanger
- Thank you received: 462
The data and description you provided suggests that the computer is (still) in fuel control.....
If not done already you might want to check fuel volume, apart from pressure. Did you check alcohol content of the fuel?
- seraj2000
I just replaced the B1S1 to genuine Denso 234-9007
no difference. and seems like ltft jumped to almost 40%
I'll post some graphs soon on both sensors.
how do I test fuel quality? and videos or links?
- juergen.scholl
youtube.com/watch?v=d8pV-x9uLiE
- seraj2000
I checked some videos for checking fuel volume.
for the sienna say for example 30 sec or 1 minute. how much fuel should it use in that time frame?
I have the fuel pressure gauge already hooked up so Ill try to test today.
- seraj2000
did fuel volume test with pressure gauge. had duralast fuel filter on.
noticed I had low volume of fuel. only like 1-2 ounces in 30 secs.
put new oem fuel filter and redid volume test thinking fuel filter was issue. seems like little to no change.
here is video.
please advise.
- Thank you received: 1116
John Curtis wrote: What happens to the fuel trims when you raise the rpms to 2500 and 3000? If they get better then you have a vacuum leak.
- Matt T
- Thank you received: 276
seraj2000 wrote: update:
please advise.
That low flow is probably due to restrictions in your gauge. Guessing you're using the vent button on a generic fuel pressure gauge.
Since you say the van drives fine I doubt you've got a fuel volume problem. They usually cause problems under acceleration first.
- seraj2000
- seraj2000
- juergen.scholl
Your videos show high LTFT under all conditions so this points to a true fuel delivery problem. The new injectors do have the correct flow rate? Can you measure pump current, voltage under load and pump speed?
- seraj2000
when I check the fuel pressure gauge it reads 0
now when I turn key on engine on then I get 50 psi pressure on the gauge and it holds at for a while after I turn engine off
another thing I tried is I used techstream to manually turn pump on/off.
this does increase pressure to 50 psi instantly when engine is still off with key on
why is it not giving me pressure with key on? in hanes manual it says I should see pressure.
why only is pressure coming on when engine is on?
even if it does not give pressure when key on but does when engine on why are my fuel trims still high. if pressure is working when engine on should that not make fuel trims normal but it does not.
how do I measure pump current, voltage under load and pump speed?
do I have to do this at the pump itself?
I can do some things but I am still learning. I don't know a lot of this stuff so please post how to do these things.
- juergen.scholl
There is a voltage feed and a ground wire connected to the pump, usually the two thicker wires if there are more than two in the connecter. Put your multimeter - we'll call it DMM (digital multimeter) from now on - to volts DC and connect the positve (red) probe to the feed wire of the pump while the car is running and connect the negative (black) probe to a good chassis ground . With the pump/car running you should read system voltage which would be around 13 to 14.5 volts. If the voltage reading is lower, lets say 10 volts then you have a problem with the power supply to the pump.
Next, still with the pump/engine running, put the positive (red) probe to the ground wire of the pump while the negative (black) probe remains on a good chassis ground. You should get a low reading of a couple of hundreds milivolts. If the reading is significantly higher then you have a high resistance problem on the ground side of the pump, between the ground wire and chassis ground.
Next put your DMM to the DC ampere function in the highest range (typically 10 A or 20A) and connect the probes accordingly to the jacks( do not forget to change them back after this test or you may blow the fuse if you later want to measure something different than current. Then you'll need to connect in series to the fuel pump circuit. You can do so on the feed side or on the ground side, it does not matter. You will have to open the circuit, let's say diconnect the ground wire out of the connector and then connect the red probe to the pin on the pump and the black probe to the ground wire you disconnected from the connector. Then start the engine and you will get a current reading in amps. A general rule of thumb is about 1 ampere per 10 psi, so you know what to expect at 50 psi, more or less. A significant higher amperage/current draw like 8 or 9 amperes would point o a restriction or the pump mechanically binding. A too low of a current draw like 3 amperes or less points to a week pump. A good DMM will allow you to measure peak values that could allow to detect blind/shorted spots on the armature.
If you find a dedicated fuel pump fuse it might be easier to put the probes of your dmm in its place, but then you should use the fuse connected to your probes. DO NOT FORGET to pull the red probe out of the ampere jack after finishing this test!
- seraj2000
has anyone tried cutting a hole inside the Sienna to get to the fuel pump?
- seraj2000
b1s1
b2s1
- seraj2000
okay finally got chance to run the fuel pump tests. made access panel inside car. LOL
meter set to DC V
with KOEO, red probe to fuel pump postive. black probe to chassis ground I am getting 12.99V to 13.03V
with KOEO, red probe to fuel pump ground, black probe to chassis ground I am getting 200mV
meter set to 20A setting with red wire in 20A spot on meter
with KOEO, red and black probes hooked up to EFI 15 amp fuse connector in engine compartment I am getting 1.8A at Key on and 5.5 amps at KOEO
Please let me know what I should try next? thx
- The_Floss
- Unwaxed with a hint of peppermint
You'll have to jump the pump if you need to run tests on the fuel system with the engine off.
- The_Floss
For some reason, I keep coming back to the MAF.
Did you replace the MAF with an OEM Denso model? Or is it a 3rd party manufacturer? I find that the aftermarket MAFs often don't give the proper readings, and can keep a lean condition going. Even if the sensor itself is good, it may be that the wiring is compromised.
I might be able to get MAF readings for different RPM values from a known good '06 Sienna.
- seraj2000
The_Floss wrote: Just a quick FYI: Toyota does not use a KOEO pump prime like a lot of other manufacturers. Instead they use a "Circuit Opening Relay" to activate the pump when the key is turned to ignition.
That is good to know. that was my main worry. I was not getting any fuel pressure with KO.
fuel pressure only with engine on and also if I jumped the fuel pump with engine off.
