Lean condition
  • Z3 trouble
  • Z3 trouble's Avatar Topic Author
5 years 11 months ago #39658 by Z3 trouble
Lean condition was created by Z3 trouble
Hello sir, love your videos and have been a sub since day 1.
Had a question for you. I have a bmw z3 with lean codes. Car has extensive service history. Had it for 12 years.
To diagnose the problem i smoked it, no leaks.
I watched your video on fuel trims and my situation is very odd.
Trouble codes are p071 p074-lean bank 1 and 2.
Short term FT are 10 -12 for bank 1 and 2
Long term fuel trims are 11.7 for both banks. And they stay 11.7 with rpm at 2.5k.
Interesting thing is short term fuel trims go up to bank 1/2 to + 12/17 respectively with rpms going up to 2.5k
O2 sensors. I’m getting normal reading for both bank 1 pre and post cat sensors.
Bank 2 o2 sensors stay at .8 value no matter the rpm
I’m really confused.
I smoked the car with professional smoke machine, no leaks
I was getting negative short term fuel trims but cleaned MAF and now I’m getting positive as per explained above
In conclusion LTFT are stuck at 11.7
STFT are positive at idle and climbing with throttle opening and high RPM.
When I’m driving in 4-5th gear as I accelerate fuel trims climb up and when I let go of the gas pedal they abruptly go to 0.
Both of my bank 2 o2 sensors are .7-.8
Thank you!
5 years 11 months ago #39659 by juergen.scholl
Replied by juergen.scholl on topic Lean condition
Worsening fuel trims with higher rpm suggest a fuel delivery probplem. Check fuel pressure and fuel volume? You may want to observe the front O2 readings while full throttling the engine while in gear. The readings should go full rich with an appropriate fuel supply. If ithey don't go full rich you have an issue.
Stepping completely off the gas pedal will enter the decelaration mode, no fuel is supplied hence a 0 reading.
  • Z3 trouble
5 years 11 months ago #39660 by Z3 trouble
Replied by Z3 trouble on topic Lean condition
Thank you for the reply.
Why would you make out of both bank 2 o2 sensors reading constantly high voltage of approximately.7 to .8?
Would that suggest that the fuel delivery problem is in the second bank?
What re the likely findings of the fuel system test.
Loss of pressure so bad fuel pump or fuel pressure regulator or clogged injector.
Would you think it is a good idea to switch the o2 sensors around and see if the high voltage read in bank 2 sensors follows? In my opinion it is unlikely both bank 2 sensors be faulty at the same time.
I
  • Z3 trouble
5 years 11 months ago #39662 by Z3 trouble
Thank you!
Thank you for the reply. And this is a revision of the unclear previous message.
What would you make out of my finding that includes both bank 2 o2 sensors reading constantly high voltage of approximately.7 to .8 regardless of the speed.
Would the abnormal O2 sensor readings in Bank 2 suggest that the fuel delivery problem is in the second bank of my engine?
Also, I have in mind that the STFT and LTFT are the same for both banks. This is a straight 6 cyl engine.
What do you think are the likely findings of the fuel system test that I will find?
Do you think it will be bad fuel pump or fuel pressure regulator or clogged injector.
Would you think it is a good idea to switch the o2 sensors around and see if the high voltage read in bank 2 sensors follows in bank 1? In my opinion it is unlikely both bank 2 sensors be faulty at the same time.
5 years 11 months ago #39664 by tech25
Replied by tech25 on topic Lean condition
whats the year and engine in your e36/7. or better yet, last 7 of the vin
  • Z3 trouble
5 years 11 months ago #39665 by Z3 trouble
1LK47343
It’s 2001; 2.5l n52 engine in line 6cylinder
  • Z3 trouble
5 years 11 months ago #39666 by Z3 trouble
Sounds good, of course however I’ll find out whether the sensors are faulty. One discouraging fact is that both bank 2 sensors gives high voltage.
However, could you go into the pcm comment more in-depth?
5 years 11 months ago - 5 years 11 months ago #39667 by tech25
Hello, your engine is in fact a M54 engine.
common problem with crankcase vent valve, when engine is warm and at idle you should have a slight crankcase vacuum of 16 mBar. also, the cyclone oil separator had a hose that connects to the oil dipstick tube, that would rot and cause leaks also.
normally you check vacuum with special oil cap, or you could remove the oil dip stick and measure from the pipe.
measure vacuum please and report back,
Last edit: 5 years 11 months ago by tech25.
5 years 11 months ago #39668 by tech25
common problem with crankcase vent valve, when engine is warm and at idle you should have a crankcase vacuum of 16 mBar. also, the cyclone oil separator had a hose that connects to the oil dipstick tube, that would rot and cause leaks also.
  • Z3 trouble
5 years 11 months ago #39671 by Z3 trouble
The manifold has been removed, resealed and smoked with no vacuum leaks. The oil separator Ccv pcv valve has been replaced along with the hoses.
The STFT go up with acceleration
O2 sensors for bank 2 are recording .7 and .8
I do not have the special vacuum measuring oil cap but I did the test where you try to remove the oil cap while the engine is running and there is some vacuum but not a lot where it is difficult to remove the oil cap.
5 years 11 months ago #39672 by juergen.scholl
Do you experience any driveability issues or higher than normal fuel consumption? Do both downstream O2 sensors read .7 - .8 volts. Do these reading drop when stepping off the pedal? Do the upstream O2 sensors react to an introduced vacuum leak?
Please provide data.
  • Z3 trouble
5 years 11 months ago #39673 by Z3 trouble
There are no drive ability issues. Car pulls hard and does not hesitate in idle or acceleration in gear.
Fuel consumption could be a bit high yet but I wouldn’t have any way to measure.
Failed to mention that the car has been sitting for 6 months since I moved and had it transported from the East to the west coast. All the extensive maintenance has been performed in the past and the car was fine since until it sat.
To be clear both bank 2 o2 sensors ( upstream and downstream) are the ones that are giving the .7 to .8 volt reading under any condition. Idle or acceleration and cruise speed.
The bank 1 pre and post cat sensors are acting normally fluctuating from .1 to .9
I will report on the last question whether the bank 2 o2 sensors react to a vacuum leak.
  • Z3 trouble
5 years 11 months ago #39678 by Z3 trouble
I just drove home and I got some data with introduced vacuum leak pcv hose unplugged. Big changes
Idle
STFT 1 6
STFT 2 7
LTFT 1 and 2 11.7
O2S11 from .09 to .8
O2S12 from .7
O2S21 from .06 to .76
O2S22 .725
Cruising speed
STFT 1 0
STFT 2 0
LTFT 1 10.7
LTFT 2 11.7
O2S12 from .2
O2S22 .1.5
5 years 11 months ago #39681 by juergen.scholl
The data suggest your O2 are working....
You really may want to look into the fuel system, checking pressure, volume and do an injector balance test.
  • Z3 trouble
5 years 11 months ago #39684 by Z3 trouble
Thank you for the reply! Yes will do, got a fuel system pressure tester from autozone but doesn’t fit my application. So I have to wait. I will report my findings!
Time to create page: 0.372 seconds
