Misfire from valve seal ?
- Carstuff
- Thank you received: 19
there is good spark from spark tester . I see that the ecu stops firing the fuel injector it start to misfire.
vehicle came in from 2 different shops with new plugs coil and injector however the misfire stays on the cylinder same cylinder
good even compression on all cylinders. I only notice the oily exhaust port from the missing cylinder.
- simclardy
- Thank you received: 7
Sent from my SM-G930V using Tapatalk
- Carstuff
- simclardy
- PDM
- Thank you received: 56
Anyone feel free to correct me, but wouldn't a low compression miss typically be worse on a cold engine.
- Carstuff
- Carstuff
- Carstuff
- simclardy
Im baffled, if you have good spark, good fuel/air, and good compression, you have good combustion.
The rough idle is definitely before the computer shuts down the injector. But not when the engine is cold. You also notice fluid droplets in the exhaust manifold that you suspect are water.
Im thinking cylinder issue. I guess temperature rise could cause the spark to change or the injector, but you graphed the injector and it looks good until it goes flat. Did you graph the spark?
Did you try looking for hydrocarbons in your water? I saw this a while back but never tried it myself.
Good luck.
Edit. I don't see the link i shared?
youtu.be/MCo0SLeMEfk
- Carstuff
I preset the leak down gauge and connected the hose and Im showing 40psi on both gauges seems like less than 1 percent leakage , however you could hear it from the crankcase.
- simclardy
If it went from 100 down to 40 that's a big leak. When you go to the other cylinders what do you get? 10-15% leak would be normal and it should be similar accross all postons
- Carstuff
The other was about the same . You could still hear it from the oil cap. But only that one cylinder is misfiring.
- simclardy
- Carstuff
- Carstuff
- simclardy
- Carstuff
- simclardy
- Carstuff
- simclardy
