Car turns over but won’t start no spark no fuel and no check engine light
- kentrell.joseph
6 years 9 months ago #30706
by kentrell.joseph
Car turns over but won’t start no spark no fuel and no check engine light was created by kentrell.joseph
I got into an accident and rear-ended someone.at the impact my car stalled and wouldn’t start.so when I looked at my wrecked front end the wires in the harness,on the passenger side were split. it was maybe 30 wires that split apartment.before finding this I tried to crank it up to get on the side of the road but it would not start.i have put all of the broken wires back together,swapped the ignition module,pcm,and crankshaft sensor.i also have new ignition coils,spark plug wires,and a new fuel pump.I tried swapping relays no change,all fuses are good,and all connections have fire coming to them,but nothing is happening when I go to start.i don’t hear the fuel pump.i have swapped out the fuel inertia switch.i don’t know what else could be the issue,we tried connecting a computer scanner tool but no luck
1993 Lincoln Town Car
4.6L v8
4.6L v8
- jreardon
- Thank you received: 198
6 years 9 months ago #30707
by jreardon
Replied by jreardon on topic Car turns over but won’t start no spark no fuel and no check engine light
Does check engine light work at key ON and turn off while cranking? Do you have 5V reference at the TPS?
Can you make a signal on the CKP wires and make the ICM fire the coils?
Start/Run power and grounds map, what's missing on your car? i.imgur.com/35WXS8i.jpg
- kentrell.joseph
6 years 9 months ago #30708
by kentrell.joseph
Replied by kentrell.joseph on topic Car turns over but won’t start no spark no fuel and no check engine light
No check engine light at all.right after the impact there was no more check engine light,I used a test light on all wires and connections and there is power.there is no fire to the coils
- kentrell.joseph
6 years 9 months ago #30709
by kentrell.joseph
I removed the inertia switch and crossed the wires together.when I turn the key on some relays click and I also here a tick sound from the gas tank.i replaced the fuel pump
- jreardon
6 years 9 months ago #30710
by jreardon
Check for coil negative control. If you still don't have control, try unplugging the spout.
- kentrell.joseph
6 years 9 months ago #30711
by kentrell.joseph
What would be the spout?
- jreardon
6 years 9 months ago #30712
by jreardon
Spark output (spout) signal comes from the computer but if this signal is bad it can affect the ICM even though it's not used during cranking:
Code:
https://www.youtube.com/watch?v=6UPe5f1s2ak&t=1012
- Dtnel
- Thank you received: 67
6 years 9 months ago #30828
by Dtnel
Replied by Dtnel on topic Car turns over but won’t start no spark no fuel and no check engine light
Why did you replace the pcm? Did someone tell you it was fault, did troubleshooting and figured it was bad? What was done to determine that beyond fixing the 30 wires you mentioned being broke that determined other things you said you replaced were bad? Was the pcm programmed? Are you getting the proper power and grounds where you're supposed to be getting them?
You're saying when you turn the key from off to the accessory position before run that the check engine light don't come on?
Does any lights come on? Do you have a phone you could take a video and load it up to youtube and list it as unlisted video but you can still share it here in the forums within the body of the message.
There's something that's not right. Probably going to have to go 1 step at a time and trace wires, verify grounds or power along with switched stuff as well. Don't give up as it takes time.
- PDM
- Thank you received: 56
6 years 9 months ago #30866
by PDM
Does this mean that nothing showed up on a scan, or was there no communication with the pcm?
Like Dtnel said, one step at a time. Get that pcm talking before you worry about anything else. Start with checking powers and grounds.
Replied by PDM on topic Car turns over but won’t start no spark no fuel and no check engine light
kentrell.joseph wrote: we tried connecting a computer scanner tool but no luck
