1997 Tacoma 2.4, No Spark, No Start, Can't Solve. Impossible Fix?
I cant get the coil to spark using the t pin and test light method. So, what do you mean by eliminate the black wire from the coil? Do you mean the wire from the tach to the coil? Is there a ohms range to test on that wire?
Is that the B-R wire according to the wiring diagram attached? Its a little confusing, because on the diagram is just an arrow pointing to 'tachometer' with no wire color.
The fact that there is not spark neither inyection pulse, must keep you focused on pcm signals and voltages (also ground voltages).
Probably root cause why you don't have injection pulse, is the same why you don't have spark.
I would look first for injection pulse (which is much easier to see without scopemeter).
Now, whats interesting is that I connected my multimeter to B12 at the tachometer wiring connector (see diagram) and ground. I have OHMs resistance when doing this test. Does that mean that black tachometer wire is grounded somewhere? Maybe at the ignitor?
- Rallymechanic
I have had a crankshaft tone wheel break before on one of these engines, so no crank signal, so no ignition or injector pulse.
Pull the crank angle sensor and try and see if you can see the teeth on the tone wheel.
Maybe even turn it over by hand as well, just to make sure it is rotating.
Toyota do have a superceeded part for this.
Best of luck.
Rallymechanic wrote: Having a read through your post, what engine is this? 2RZFE?
Best of luck.
Yeah Rally, thats a 2RZFE. How did you change the tone wheel? Pull the motor?
- Rallymechanic
But check your tone wheel is moving before you do this.....if not, then this could be your problem.
Let us know what you find.
cheers
