2017 Honda Accord 2.4L P0303
  • brianmstoltzfus
  • brianmstoltzfus's Avatar Topic Author
10 months 4 weeks ago - 10 months 4 weeks ago #91934 by brianmstoltzfus
2017 Honda Accord 2.4L P0303 was created by brianmstoltzfus
Hello, I have a 2017 Accord (180,000 miles) in the shop with a cyl 3 misfire under heavy engine load. It sets P0303 then disables the injector until the next key cycle. I did a quick swap of the coils and plugs with no change. I attached the scope captures which were taken under the misfire conditions. I have attached the leads to all coils feed, cyl 3 battery voltage, and cyl 3 trigger from ECM. I don't like how the battery voltage occasionally spikes or drops out and it seems to happen randomly for multiple coils. No parts have been replaced. Any input is appreciated. Edit: I should add, the downstream lambda goes lean when the fault occurs.
Last edit: 10 months 4 weeks ago by brianmstoltzfus. Reason: Additional info
10 months 3 weeks ago #91942 by Tyler
Replied by Tyler on topic 2017 Honda Accord 2.4L P0303
Thank you for adding the captures.   I agree, there's some spikes and noise going on in the voltage trace, but I don't think I'd sweat it too much. The spikes are always occurring at a coil firing event, which suggests that the spikes are actually just noise picked up by your test leads. Since this was during the misfire, I'm assuming you were using super-long leads (or daisy chaining leads together), which makes picking up noise almost inevitable.
Since the downstream goes lean during the fault, that'd suggest a fuel injector issue. Does your scan tool have the Cylinder A/F Test available? Run it a couple times and see if the #3 injector gets flagged as lean.
Do you have a means of watching secondary ignition?
  • brianmstoltzfus
10 months 2 weeks ago #91986 by brianmstoltzfus
Replied by brianmstoltzfus on topic 2017 Honda Accord 2.4L P0303
I do not have a good way of watching secondary ignition on a test drive which is the only time the fault occurs but I agree it is lack of fuel and plan to scope the injector amp draw to see if the pintle hump goes missing.
10 months 1 week ago #92003 by Tyler
Would you mind sharing your captures with us, if you do end up getting injector current waveforms?
FWIW, I don't know that a sticking pintle will show up in a GDI injector current waveform. Not in the same way as port fuel injectors. My experience has been that when these injectors fail, it has less to do with a mechanical problem and more to do with a poor spray pattern/atomization.
  • brianmstoltzfus
10 months 1 week ago #92028 by brianmstoltzfus
This is good to know! I'll definitely share when I get back to this car!
Time to create page: 0.245 seconds
