[FIXED] 05 jeep liberty 3.7 charging system not charging.
  • gilbert
  • gilbert's Avatar Topic Author
7 years 11 months ago - 7 years 11 months ago #20009 by gilbert
God bless you my brothers and sisters.
I have a question is the voltage regulator inside the alternator? Does the pcm only control pulse to the regulator? The control wire being 19 on the PCM what does GEN.SRC mean.
Thank you for your help.
Last edit: 7 years 11 months ago by Tyler.
7 years 11 months ago #20012 by randall.sick
Replied by randall.sick on topic 05 jeep liberty 3.7 charging system not charging.
Pretty sure it's in the ECM.
My rides, 1998 Chevy Tahoe 5.7l
1999 Chevy S10 2.2l
The following user(s) said Thank You: gilbert
7 years 11 months ago #20016 by bruce.oliver
Replied by bruce.oliver on topic 05 jeep liberty 3.7 charging system not charging.
Open the first file on this link. It will explain the charging system and how to test it www.remyautomotive.com/resource/Technical-Bulletins
  • gilbert
7 years 11 months ago #20019 by gilbert
Thank you Bruce.oliver for your respond , i did as the pdf said and it did not charge it just kept blowing the fuse.
  • gilbert
7 years 11 months ago #20020 by gilbert
I checked for voltage on the green wire and with it plugged in I get 0 volts unplugged batt. voltage is this what I should get?
  • gilbert
7 years 11 months ago #20022 by gilbert
So with the scanner I activated the generator field and i heard the alt. click does this mean that the pcm is good?
7 years 11 months ago #20026 by Tyler
bruce.oliver wrote: Open the first file on this link. It will explain the charging system and how to test it www.remyautomotive.com/resource/Technical-Bulletins
Nice. B) Pretty sure this is what they're calling a 'Dual Field B' system. PCM switches power to the field coil in the alternator, and the other side is permanently grounded.
Which green wire? Or, did you mean the brown/dark green wire? The 0V plugged in doesn't sound good. With the engine running and the alt plugged in, that wire should read something. :unsure:
So you grounded one field terminal and applied B+ to the other? If it popped the fuse, that'd suggest a shorted field coil. What rating of fuse did you use?
7 years 11 months ago #20036 by Tyler
Monde wrote: Tyler, 0 v at the brown/dark green wire could be the pcm trying to protect itself from something wrong it senses in the alternator. Don't you think? I am only saying this because he has battery voltage with the connector unplugged suggesting no short to voltage or open.
It could be? I'm honestly not sure what kind of protection strategies this PCM might use on this output. I wanted to clarify with gilbert about his manual field test (with the jumper wire), 'cause that strongly suggests a shorted alternator. :unsure:
Maybe the next step would be to connect a test light to B- and probe the brown/dark green wire? That'd show the PCM a known good load. If it pulses, then SOMETHING is working. :lol:
  • gilbert
7 years 11 months ago #20037 by gilbert
Hey Tyler my bad it is the brn/dk grn wire and yes with truck running no voltage with it plugged in. If i unplug it i get batt. voltage as for the test from the I put one wire to ground and the other to batt. . I did wait until after I started the truck before putting it to batt. poss. I used a red 10 amp fuse. How can I test the field coil?
Thank you brothers for your help.
  • gilbert
7 years 11 months ago #20042 by gilbert
Yes Sr. I do have batt. voltage at the brn/red wire coming from the batt.. It's at the brn/drk grn wire that i have no power with engine on and plugged in. If i unplug it I have batt. voltage at the harness side , grounds are good.
  • gilbert
7 years 11 months ago #20051 by gilbert
Tyler so you are saying to put batt. neg to the brn/grn with my test light. Engine on and should it be plugged in or unplugged ?
  • gilbert
7 years 11 months ago #20054 by gilbert
Engine on test light on batt. neg. Plug in i get nothing. Plug disconnected light on.
  • gilbert
7 years 11 months ago - 7 years 11 months ago #20083 by gilbert
Thank you all for your help the liberty is fixed it had a short in the rotor. I got that fixed and the alt. is charging no damage to the pcm thank God .
P.S Why can't I edit the topic to fixed?
Last edit: 7 years 11 months ago by gilbert. Reason: had to add to comment
7 years 11 months ago #20086 by Tyler
gilbert wrote: God bless you my brothers and sisters.
Thank you all for your help the liberty is fixed it had a short in the rotor. I got that fixed and the alt. is charging no damage to the pcm thank God.
Great to hear, sir! :cheer: Monde called it, too - the PCM sensed the short and protected the driver when connected to the alternator. B) I wonder how a test light connected across the field connector would have behaved? WIth a key cycle in there to let the PCM reset.
We're working on that. According to the forum settings, you should be able to, but it still doesn't work. :angry: Sorry about that! I'll edit the [FIXED] in.
7 years 11 months ago #20090 by rockp2
Connect a test light to the "Action" button on your screen, then probe a username on your screen. If the test light doesn't light, then you know the forum settings are shorted. :evil:
  • gilbert
7 years 11 months ago #20093 by gilbert
God bless you my brother's and sister's.
Well Bruce.Oliver link me to a way to test the alternator to see if it was the alternator or the PCM. That is where I started and found that I kept popping the fuse on the test wire. Then Tyler pops in and says that there is a short in the coill field so I took it apart and found that I had continuity from the slip ring through out the hole rotor.
Time to create page: 0.409 seconds
