1994 F150 no fuel!
- Jasonpsapp17
Banging on the rear tank actually got it to start again. Could have been coincidence (Assumed fuel pumps, but both?) Got it home and fuel pressure tested. Honestly the tests were all over the place low/not there. Did a couple random things like swapped back in the stock coil and found the pcv valve hose slipped off. Started, ran for 3-5 min and just shut down. I NOTICED AT THIS TIME THE PUMPS WOULD BOTH PRIME AND STAY RUNNING WHILE TRUCK WOULDN'T START (I think this is weird and points to a computer issue).
Decided to put in new rear pump yet all of a sudden things seemed back to normal, started ran for another 2-3 months until again it would crank and not start. Jumped it and ran for a minute before dying out. Unplugged battery and after reinstalling It ran and now it's home not starting.
I've been able to get spark and spraying some throttle body cleaner got the truck to run for a few seconds. I have zero fuel at the rail and cannot get the pumps to prime now. Fuel pump relay seems to click and I've begun testing the circuit at the pumps, inertia switch, and fuel tank selector. I believe I should have 12V all around with the key on right?
Thank you for reading this far I'd appreciate any help or advice!
- Ben
- Thank you received: 215
- Jasonpsapp17
- Thank you received: 727
- Jasonpsapp17
This is a wave of the bad motor. When the wave looks like this, I replace the blower/pump, whether it is working at that moment, or not. When, not if, the motor stops in a bad spot, it cant get started. Banging on the tank jostles the pump, just enough, to get out of the "dead" spot.
Having Dual tanks decreases the probability of this being the problem.
You may, or may not, have access to a scope. I just thought I would throw this out there.
Jasonpsapp17 wrote: Is the initial 12 V supposed to hold.
Yes. If you are testing on the power supply side of the circuit, it should hold 12v. You have a voltage drop.
- Jasonpsapp17
www.ford-trucks.com/forums/1435937-1995-...troubleshooting.html
This thread sounds like me almost exactly. It's just at the moment the fuel pumps won't prime. In the past the constant running of pumps has happened.
Earlier the truck just randomly started and ran for 15min before i turned it off. Wouldn't start again. Only on throttle body cleaner it'll run again for a few seconds. Definitely not getting fuel somehow
Jasonpsapp17 wrote: In the past the constant running of pumps has happened.
:blink: I can't explain that, at this point. But, if your dropping voltage at the fuel pump, I don't think THAT problem is with the PCM. Power for the fuel pump comes from 20 amp FUSE O, which is in the engine compartment relay box. What voltage do you read at THAT point when energizing the fuel pump? If you get a strong, solid battery voltage, move down the line and check the wire going INTO the inertia switch (DK GRN/YEL), then the wire going OUT OF the inertia switch(PNK/BLK). Keep moving down the circuit, working your way towards the fuel pumps.
This makes me suspect the Fuel Pump Relay.
- Jasonpsapp17
- Jasonpsapp17
Jasonpsapp17 wrote: Okay fuse O is dropping on engine crank. 12ish to about 10-11. Normal or is that typically going to happen.
It is normal for system voltage to drop a little while Cranking. I would say you do not have a voltage drop at Fuse O. What about WITHOUT cranking? Key on, fuel pump priming stage. Compare voltage at these points....(Fuse O, and terminals 87 and 30 of the relay)
- Jasonpsapp17
There is a gurgling/buzzing near the fuel pressure regulator and vacuum lines that Is present engine running and upon shutdown. Trying to trace it but cannot pinpoint (sounds like it's from the fpr). Someone once said it was an evap leak.
I used some propane to find a vacuum leak but no change. Honestly here's what I did but I do not think I changed anything.
1. I moved some of the relays around (done before/no difference).
2. Added a little water to the battery (figured I've been cranking+ no start, but hey who knows).
3. Had checked voltage on the circuit at the RED/BLUE+ORNG/GRAN+yellw few minutes before start. Circuit actually held 9.47 this time (did not drop to basically 0V) and the fuel pumps came on but zero pressure readings
It seems at times the truck likes to start and then it won't. The electronics store guy said fuel pump relay when I said pumps constantly running in the past. I'm assuming the relays are good but could how can I check those terminals exactly? I'll be looking into it but I really appreciate your help and patience!
