A/C Pressure Sensor Voltages
  • aluiaam
  • aluiaam's Avatar Topic Author
2 years 1 month ago - 2 years 1 month ago #65428 by aluiaam
A/C Pressure Sensor Voltages was created by aluiaam
Car: 2013 Chevy Sonic 1.8L, M/T, LUW engine code
Issue: A/C compressor is not being commanded on
All of my troubleshooting has pointed me to the refrigerant pressure sensor. For brevity's sake I'll leave out the details of everything I tested to get there, unless anyone is curious. At 65°F ambient, with the car having not been run recently, the static pressures measured low-side 72 psi and high-side 77 psi. This pressure should be within the range to allow the compressor to be engaged (32-450 psi on high-side), so I started checking the pressure sensor. Diagram is attached for reference.
With sensor connector mated to sensor and X1 demated from ECM, I measured 11.53 kΩ from 26 to 13, and 6.82 kΩ from 12 to 13. (I also verified wire integrity, no shorts to chassis, etc; again, details if you're interested). I applied 5.00 V across +26/–13 with my own power supply, and I measured 0.974 V across +12/–13. Given those resistances I measured I would have expected 2.958 V (=5*6.82/11.53). I also measured 6 mA total current, where I would have expected 0.434 mA (=5/11.53k). I can't explain the voltage or current measurements.
  1. Does anyone have a volts-to-pressure chart for this sensor? I can't find one, but I suspect 0.974 V might be less than 32 psi.
  2. Is there anything wrong with my methodology? Measuring resistances, applying external voltage, comparing voltages and currents to expected values - are those meaningful tests?
  3. Is there anything different about the way the ECM applies 5V versus the way I did?
Thanks in advance! First time posting here, but I'm a long-time viewer of SD's videos.
Last edit: 2 years 1 month ago by aluiaam. Reason: Text-based "diagram" did not come out looking correct. Attaching a picture instead.
2 years 1 month ago #65431 by Tyler
Replied by Tyler on topic A/C Pressure Sensor Voltages
Hey aluiaam! I couldn't find a pressure/voltage chart in service info, but I did find this bit in the scan tool data parameters chart:
According to this, it would seem that your voltage reading of .974V should be sufficient to allow compressor engagement.
I wouldn't say that there's anything wrong with your testing or methodology, necessarily. Thorough, certainly! But maybe a bit indirect, or possibly unnecessary.
I mean no offense here, but is there a reason you didn't want to do voltage readings at the A/C pressure sensor with the engine running and the A/C requested on? Or, was there a reason you didn't trust the 5V regulator in the ECM?
  1. Is there anything different about the way the ECM applies 5V versus the way I did?
Not that I can see. The only difference I can think of between your setup and the vehicle would be that the ECM may employ a bias voltage on the pressure sensor signal line, which may result in a difference in circuit behavior.
As far as your inoperative A/C goes, I think your next best bet is a scan tool. GM typically provides excellent scan data regarding A/C operation. You'll be able to see the pressure sensor signal, plus the A/C compressor clutch relay command AND the A/C request from the HVAC controller. Between those three PIDs, you should get a pretty good idea of where the problem lies.
  • aluiaam
2 years 1 month ago #65456 by aluiaam
Replied by aluiaam on topic A/C Pressure Sensor Voltages
Thanks for the info, Tyler! I actually didn't have any back probe pins, so that's why I disconnected at the ECM and applied my own 5V. There are no DTCs related to 5V ref circuits or anything related to A/C. I went out and got some back probe pins and retested with the full circuit intact. With ignition on, at 75 °F ambient (over 50% humidity) and static gauge pressures around 90 psi on low and high side, voltage was 1.15 V (and 5V Ref was good too). I started the car and turned on the blower and A/C, and of course it started working, blowing cold and everything . I let it cycle for ~10 minutes at idle while I watched the gauges and multimeter. Low side cycled between 20-40 psi, high side cycled between 140-200 psi (depending on whether condenser fan was on). Sensor voltage tracked the high side pressure too, 1.6-2.1 V. All in all the system seems to be working fine when it does come on, so I'm chasing an intermittent problem.
Can you recommend a scan tool that will read those HVAC PIDs? Bidirectional commanding for compressor clutch would be nice to have too. I have an Innova 5210. It reads 42 PIDs in total, but no HVAC PIDs (AC pressure, evaporator temp, etc).
2 years 1 month ago #65458 by Tyler
Gotta love intermittents!   Glad to hear it's blowing cold for now, anyway.
As for a scan tool, it's tough go to wrong with the TopDon TopScan:
www.topdon.us/collections/service-tools/products/topscan
The TopDon (Launch) coverage for GM vehicle is usually excellent. HVAC scan data and bidirectional controls will be there, as well. As long as you have a smartphone, it's an incredible value at $60. Paul even used it in a recent Premium video:
www.scannerdanner.com/scannerdanner-prem...sor-diagnostics.html
2 years 1 month ago #65467 by Tyler
Happened to have a '14 Sonic in today, had a look at the A/C data while I was at it:
Also checked that it has the compressor clutch bidirectional function:
  • aluiaam
2 years 1 month ago #65472 by aluiaam
Thanks for the recommendation and the screenshots! The TopDon looks like it has a pretty good feature set. I'll check it out.
Time to create page: 0.580 seconds
