2010 Scion XB P0171
  • Stryper
  • Stryper's Avatar Topic Author
2 years 10 months ago #62163 by Stryper
2010 Scion XB P0171 was created by Stryper
Hi Ya'll As title says its throwing a P0171 code. Truck runs fine, no starting or driving issues. Just throwing code and reflecting it on plugs and poor mileage. No indication of vacum leak and squirted propane everywhere just to double check
I am using a Topdon Artidiag Pro scanner and ordered SD's book. I am no longer in car biz, and no wish to return, its just my hoopties. And I live across from a Toyota Service director so i have little faith in dealer diagnosing :)
LT trim is 22+ to almost 40 at snap throttle
ST trim goes from -18 to +7 " " " " "
MAF goes from about 4gms to over 45 on snap throttle
AFS is going from -1.6 to +1.6
I'm kind of leaning to AFS being wonky as it should be 3-4 area correct? Cause it still acts like a battery right?
I would add the truck has 250K + and I have gotten my monies worth :) Would add pictures but do not have Tapatalk fired up anymore.
  • pinstryper
  • pinstryper's Avatar
2 years 10 months ago #62165 by pinstryper
Replied by pinstryper on topic Re:2010 Scion XB P0171
Now pic uploads
Sent from my SM-G991U1 using Tapatalk
2 years 10 months ago #62168 by Cheryl
Replied by Cheryl on topic Re:2010 Scion XB P0171
What field did you go to? Hold the rpm steady at 2500-3000 rpm see what fuel trims do. Post pic of that
The following user(s) said Thank You: Noah, pinstryper
  • pinstryper
2 years 10 months ago #62172 by pinstryper
2500 rpm ish
Still unable to combine graphs on my scanner.
  • pinstryper
2 years 10 months ago #62173 by pinstryper
First afs is after unplugging purge to initiate vacum leak. Other pics from holding pedal and toggling scanner while taking picture with phone.
  • Stryper
2 years 9 months ago #62323 by Stryper
Replied by Stryper on topic What are Fuel Trim Limits on a Toyota 4 cyl?
Where can I find Fuel Trim Limits ? anywhere on line? Still trying to fix a 171 code.
TIA,
Michael
2 years 9 months ago #62338 by Tutti57
Replied by Tutti57 on topic What are Fuel Trim Limits on a Toyota 4 cyl?
They may be posted somewhere in service info, but I'm thinking that we still want to just look at the general +/- 10% and determine if it is inside that total trim range or not.
What is the vehicle you are working on, and if you want to share some of what you are dealing with, you may get some more help here?
  • Stryper
2 years 9 months ago - 2 years 9 months ago #62342 by Stryper
Thanks for replying, Most of what I am dealing with is under my P0171 2010 Scion thread. I got to the point I AAA it to a friends shop and so he could smoke it in case I missed something. He also redid my tests and got the same results.
Vehicle runs too good to have a fuel delivery issue, but he might as well check pressure anyway.
And injector ms and FT limits are shots in the dark at this time. ANY info just might be handy at this point
will add pics from phone below
Last edit: 2 years 9 months ago by Stryper.
  • pinstryper
2 years 9 months ago #62343 by pinstryper
Replied by pinstryper on topic Re:What are Fuel Trim Limits on a Toyota 4 cyl?
Added pics
2 years 9 months ago - 2 years 9 months ago #62346 by juergen.scholl
Replied by juergen.scholl on topic Re:What are Fuel Trim Limits on a Toyota 4 cyl?
The picture shows that the ecm (at this moment) is able to maintain fuel control. It has to make a BIG effort to achieve it which is reflected by the high LTFT number.
In general I have seen a good number of Toyota engines with dirty injectors exhibiting similar symptoms: lean code(s) without driveability issues.
With no unmetered air and fuel pressure in spec you want to look close at the injectors.
Last edit: 2 years 9 months ago by juergen.scholl.
2 years 9 months ago #62347 by Noah
I added your fuel trim question thread to the original help request to keep everything in one spot.
Please try to keep questions about the same car within the original thread. It makes it MUCH easier for anyone trying to help you, and for people who may have a similar issue in the future.
No harm done ;)
The following user(s) said Thank You: pinstryper
  • pinstryper
2 years 9 months ago #62348 by pinstryper
Thank You Herr Scholl,
thats the only issue i have not tested, just because it does not exhibit usual low pressure drivability issues.
Whats that 'when all other avenues ' quote?
2 years 9 months ago #62357 by Monde
Have you ever had a chance to do what Cheryl suggested? Increase the RPM to 3000 and see if the fuel trim gets better or worse. You can also do the fuel delivery test by watching the o2 at WOT. If you have a fuel-related issue, the o2 will be lean.
2 years 9 months ago #62362 by STIMECE
Replied by STIMECE on topic 2010 Scion XB P0171
Check your MAF and see if its dirty, its probably under reporting. If you dont know how to clean one properly I would suggest googling it because you do need to know where to clean. I am going to bet money its your MAF sensor being dirty and its under reporting the amount of air going into the engine which is why the LTFT are high because the O2's are sensing this command and therefore sending a command to the ECU to signal the injectors to add more fuel.
  • pinstryper
2 years 9 months ago #62365 by pinstryper
Did those test while driving actually, but my pictures were very poor. And as i mentioned above, i sent vehicle to another shop last Monday. And he redid everything and found same specs/issues i did.
And being fixing drivability issues has not been my day job for 40 yrs. I actually replaced. MAF and AFS with new Densos and saw same readings.
Its an injector issue i am 90% sure, cause it runs to good at 60-70 mph but still reads over 35 % LTFT.
If he does not find time to run fuel pressure test and install the rebuilt Denso injectors by end of today, i will have it towed back and do them myself.
And now my junk Topdon ArtidiagPro will only charge thru vehicle on top of being unable to graph 4 items at once!
I spent day yesterday calling in favors from dealers i work for and the Toyota tech looked at my screenshots and and actually was impressed i kind of knew what i was talking about, but he was also in his 60's.
2 years 9 months ago - 2 years 9 months ago #62366 by STIMECE
sure you can go 60 to 70 mph, and still have an under reporting MAF. You can also still have bad new parts, dirty fuel filter or bad fuel pump.
Going 60 to 70mph is not really constructive, load is more pertinent in this case and the associated LTFT, STFT Upstream and downstream %'s and V's
So under full load you have a max LTFT value....plus 40%LTFT's and a STFT around 0% and a low downstream V you have having a fueling problem.
Although I wonder what the case would be if the voltage was high on the down stream
Last edit: 2 years 9 months ago by STIMECE.
  • Stryper
2 years 9 months ago #62549 by Stryper
Replied by Stryper on topic Yippie! no codes !
finally ! Just wanted to Shout out to Ben and Juergen ! 717 and 117 issues are fixed ! Turns out Fuel Pump and the Input sensor. And finding wire colors sure helps. The only toyota input sensor video is NOT input but output :) guess I need to comment on that guys post, but who would think the input is farthest from engine ?
Thanks Ya'll
Michael
2 years 9 months ago - 2 years 9 months ago #62550 by Tyler
Replied by Tyler on topic 2010 Scion XB P0171
Thanks for the follow up, Stryper! :cheer: Ben and Juergen are definitely rockstars. I moved your shoutout post into this thread so they'd get notified of the reply. ;)
Last edit: 2 years 9 months ago by Tyler.
2 years 9 months ago #62551 by juergen.scholl
Replied by juergen.scholl on topic Yippie! no codes !
Thanks Ya'll
Michael
Thank you for the update! Good to know you fixed it.
Time to create page: 0.345 seconds
