(FIXED) 2009 Honda Accord power loss, P0171
- fudgie
- Thank you received: 4
-STFT +46.9 at all times
Maf- (nice and clean) 2.8gps at idle, 1.25v at idle- hits about 3v when it makes a feeble attempt to rev
AFR- 16.2 at idle- hits 27:1 under snap throttle. If I blast some propane into intake- I can get trims into the +20 range and AFR drops back to 14.5ish.
Fuel Pressure- 50psi
Injectors at idle 3ms- snap throttle 15-17ms
I checked for vacuum leaks even though in my opinion this is way beyond a vacuum leak- found nothing. I honestly thought for sure I was going to have low fuel pressure but not the case. Even under snap throttle bogging- fuel pressure stays at 50psi. I did a quick current ramp of pump and I need a little assistance as to what I'm seeing. Am I correct in thinking that pump rpm is right around 8000? Does the waveform look ok? I was expecting to see less rounded humps. I asked the lady if there was any chance she filled it up with E85 but she doesn't remember putting gas in the car in the past two weeks. I took a sample and its brown in the jug and smells like gas so I'm not sure on that front. Thanks for any advice!
- CurrentDraw
- Thank you received: 27
Does your shop have previous history with the vehicle? Does she maintain her car on time, specifically oil changes?
The K24 timing chain in her vehicle has a tendency to stretch due to lack of oil changes affecting mechanical timing. Generally speaking it should trigger a P0341 (cam out of phase) but I have had ones which only triggered a P0171 and/or P030x.
Pull the timing cover off and check the timing. Good luck sir
- CurrentDraw
- toadyboy1957
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
Here is a known good you can reference with.
CH1 (yellow) = CKP
CH2 (green) = Intake CMP
CH3 (blue) = Exhaust CMP
- fudgie
- cheryl hartkorn
- Thank you received: 130
- fudgie
- Thank you received: 1539
Why is it so crazy lean...
- fudgie
- Thank you received: 1116
- fudgie
Just curious, do you recall what the injector drop numbers were? I imagine they'd all have to be plugged to some degree to get the symptoms you found...
- Ro-longo
- fudgie
fudgie wrote: The whole time I knew it was a fueling problem but working on imports for 20 years- I have only changed injectors once and that was on an 88 Volvo 740t. It was a good reminder for me that just because "they never have problems" doesn't mean that they cant and I need to keep an open mind.
Truth.com right here. Injector issues are waaaaayyyy down on my suspect list when it comes to imports, especially Asian makes. Very nicely done, sir.
They stock them at the dealer. :lol: Kinda reassuring to hear that, huh? Recently, I was a little bit nervous about recommending replacing the turbo on a Ford Edge, until I heard they're on backorder. :woohoo:
