Do not disconnect battery?
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 3 months ago #11207 by Dylan
Replied by Dylan on topic Do not disconnect battery?
I feel guilty already! :woohoo: ;)
8 years 3 months ago #11237 by Ben
Replied by Ben on topic Re:Do not disconnect battery?
Haha I forgot all about this post. I don't have time right now to explain it but I will get back to this soon
8 years 1 week ago #13822 by EricGoodrich
Replied by EricGoodrich on topic Re:Do not disconnect battery?
I realize this is an old post and may not have any interest to anyone anymore but I'll throw my experience in here anyway. I have never disconnected a battery to weld on a vehicle. I have never witnessed a vehicle being damaged by welding with the battery connected. I have welded on vehicles hundreds of times with absolutely no issues. I've welded everything from frames, body, exhaust, engines ( to remove broken exhaust manifold bolts ). I've used both MIG welders and TIG welders on vehicles, again without any issues. If I think of it, the next time I weld I will hook up my scope and measure the current in the negative cable to the battery and I will also scope for voltage spikes. And, if I think of it, I'll post my results here.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 1 week ago - 8 years 1 week ago #13841 by Dylan
Replied by Dylan on topic Re:Do not disconnect battery?
EricGoodrich wrote: I realize this is an old post and may not have any interest to anyone anymore but I'll throw my experience in here anyway. I have never disconnected a battery to weld on a vehicle. I have never witnessed a vehicle being damaged by welding with the battery connected. I have welded on vehicles hundreds of times with absolutely no issues. I've welded everything from frames, body, exhaust, engines ( to remove broken exhaust manifold bolts ). I've used both MIG welders and TIG welders on vehicles, again without any issues. If I think of it, the next time I weld I will hook up my scope and measure the current in the negative cable to the battery and I will also scope for voltage spikes. And, if I think of it, I'll post my results here.
Oh no I'm still interested! It would be great to post the captures of your scope so we have some more insight on the subject.
Last edit: 8 years 1 week ago by Dylan.
  • Noah
  • Noah's Avatar
8 years 5 days ago #13888 by Noah
Replied by Noah on topic Re:Do not disconnect battery?
Almost every time I break out the welder now I think, "damn, I should have put an amp clamp on the battery cable!"
8 years 5 days ago - 8 years 5 days ago #13897 by Denisf
Replied by Denisf on topic Re:Do not disconnect battery?
We do a lot of welding on our fleet equipment (Municipal Government repair shop) and we do a tad more than just disconnecting the battery in some cases ( Fire Trucks with Multiplexing systems). A few times, our techs forgot to disconnect the ABS modules before welding on trailers and we did fry two of them.
Just as an example of the procedure Ford recommends.
Welding Precautions
Last edit: 8 years 5 days ago by Denisf.
The following user(s) said Thank You: Noah, Dylan, Tyler
8 years 1 day ago #13998 by EricGoodrich
Replied by EricGoodrich on topic Do not disconnect battery?
Did some exhaust welding today. Standard MIG welder. Battery connected. Blue channel is an inductive amp clamp around the battery cable. Red channel is voltage across the battery terminals.
The three second Mark is when I began welding. The seven second Mark is when I stopped.
I apologize for not providing pictures of waveform zoomed in, honestly there was nothing to see anyway.
8 years 20 hours ago #14044 by Tyler
Replied by Tyler on topic Do not disconnect battery?
EricGoodrich wrote: Did some exhaust welding today. Standard MIG welder. Battery connected. Blue channel is an inductive amp clamp around the battery cable. Red channel is voltage across the battery terminals.
YES. This is exactly what I've been meaning to do! B) Many thanks sir, much appreciated.
Still, it's really interesting that Ford wants you to be super careful when welding on their trucks. :blink:
Denisf wrote: We do a lot of welding on our fleet equipment (Municipal Government repair shop) and we do a tad more than just disconnecting the battery in some cases ( Fire Trucks with Multiplexing systems). A few times, our techs forgot to disconnect the ABS modules before welding on trailers and we did fry two of them.
Welding Precautions
Here I was thinking I was overly cautious when disconnecting the battery. :silly:
7 years 9 months ago #16151 by Tutti57
Replied by Tutti57 on topic Re:Do not disconnect battery?
Last summer there was a guy over at my house grinding a few stumps and noticed I had a welder out by my car with the hood open. He came over and told me that among many things, he was a "master welder" and to always disconnect the neg cable because he was doing some work on a car when he started out and cooked the rod bearings...we left it at that.
7 years 9 months ago #16154 by Tyler
Replied by Tyler on topic Re:Do not disconnect battery?
Tutti57 wrote: Last summer there was a guy over at my house grinding a few stumps and noticed I had a welder out by my car with the hood open. He came over and told me that among many things, he was a "master welder" and to always disconnect the neg cable because he was doing some work on a car when he started out and cooked the rod bearings...we left it at that.
Really? :huh: That's a new one on me...
  • graywave
  • graywave's Avatar
7 years 9 months ago #16156 by graywave
Replied by graywave on topic Do not disconnect battery?
I disagree with the article a bit. I have never disconnected the battery before welding and i'll tell you why. This is my theory, electricity takes the path of least resistance, I ground the welder directly to the metal I am welding. If I am welding the exhaust, I am not putting my ground cable to the frame as this will require the high voltage to travel much longer distance not only possibly creating a bad weld but possibly traveling through other components as well. If I am welding on the frame, my ground cable is attached to the frame I am working on, its not being attached to the axle, fender, exhaust, battery, PCM, dash board, etc... The electrons will not flow through anything other component. Why would it? I don't see a problem at all as long as you use your thinking cap and ground to the area your welding.
  • graywave
  • graywave's Avatar
7 years 9 months ago - 7 years 9 months ago #16158 by graywave
Replied by graywave on topic Re:Do not disconnect battery?
A friend of mine said he disconnects the battery cause the electricity traveled through the wheel bearing and welded it....I wonder where he was grounding! On the hub? Proper ground location should prevent mistakes like this.
I can argue this further, Ignition coils...Those can blast 50,000 volts into the cars chassis. Why doesn't that effect the car electronics? Because its going directly to ground, proper ground location. You don't see the spark plug grounding through the PCM. lol.
Last edit: 7 years 9 months ago by graywave.
7 years 9 months ago #16160 by Tutti57
Replied by Tutti57 on topic Re:RE: Re:Do not disconnect battery?
I agree with your logic here. I think these other guys and their bearing stories were more likely already bad or nearing bad before the welder came out. Then talking it out loud lead to someone blaming the welder for the failure.
  • JeffBirt
  • JeffBirt's Avatar Topic Author
7 years 9 months ago #16165 by JeffBirt
Replied by JeffBirt on topic Re:Do not disconnect battery?
At least it was not the muffler bearings!
  • Noah
  • Noah's Avatar
7 years 9 months ago #16307 by Noah
That's why old model T Ford's had wooden wheels, right?
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
7 years 9 months ago #16319 by Dylan
Noah wrote: That's why old model T Ford's had wooden wheels, right?
Lol :lol: :lol:
Time to create page: 0.386 seconds
