Reapring/gluding engine cover plastic panels
  • JeffBirt
  • JeffBirt's Avatar Topic Author
7 years 8 months ago #22004 by JeffBirt
Has anyone every found a way to glue/repair an engine cover (plastic) panel. I have one that has mounting foot broken off. I can fabricate a new foot but I'm wondering if there is an adhesive that will bond to the plastic they make these out of (2005 Escape V6). If nothing else I guess a mechanical fastener can be sued to secure a fabricated mounting foot. There is no point in looking at a junk yard as I suspect all of them have broken in the same place.
Thanks!
7 years 8 months ago #22006 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Reapring/gluding engine cover plastic panels
No eBay APP ID and/or Cert ID defined in Kunena configurationI think the material A.B.S. I am not sure how good a bond you would get with 2 part expoxy, in the past I have used a long nut called a stud joiner and large "penny" repair washer
7 years 8 months ago #22007 by Andy.MacFadyen
7 years 8 months ago #22010 by Tutti57
You can try Q-bond. It's not cheap but it works pretty well on plastics. It's basically super glue with hardening powder.
7 years 8 months ago #22016 by Tyler
You have a first gen Escape that still has the engine cover? :blink: Amazing!
I like two part epoxy, personally, but it takes time to set up. Glue it up and let it set overnight.
  • Noah
  • Noah's Avatar
7 years 8 months ago #22044 by Noah
I have successfully "soldered" my plastic glasses frames with a soldering iron using a black plastic zip-tie as solder.
I'm also quite fond of silicone gasket maker to glue things to other things. It holds great, is chemical, heat and vibration resistant, yet you can remove it whenever you're ready.
I'm not sure if either is a viable option for you.
7 years 8 months ago #22258 by vb4me
If it is abs then you can glue an abs part to it with acetone. Just coat both parts and join together. For a stronger bond "melt" some scrap or shavings of abs into the acetone then apply like a paste.
7 years 8 months ago #22403 by PDM
I second Q bond. A cheaper alternative is something I use regularly. Super glue and baking soda. Search for Sweet Project Cars on Youtube. He has a video on repairing plastic this way
Time to create page: 0.374 seconds
