P219A diagnostic techniques
- Thank you received: 1420
2012 Terrain, LEA (2.4L) engine is setting a P219A Air/Fuel Ratio Imbalance Bank 1 and a P0300. Previous tech did plugs, intake gaskets and clean the PCV passage, cleaned the MAF, and ran two induction services. Code resets.
I get it and immediately note the misfire at cold idle. Counts up on #1 and resets P0300 almost immediately. Classic carboned intake valves, and the borescope confirms. Induction services aren't cutting it on this one. I get the OK to pull the intake again and manually clean the valves. I also run the Automated Injector Balance test a few times, and don't see an obvious issue. The spread between the injectors is typical of what I see on known good LEA engines.
Valves are clean, cold miss is gone, but P219A resets on the highway. Trims are around +7% total when the code sets, and no cylinder is counting misses. I go over all my testing again, including the injector balance - still looks good. It's down to a injector issue (that I can't prove), or a tiny crack in the exhaust manifold (that I've seen tons of times and never causes a P219A). We go for the injectors anyway.
After the injectors are installed, I get the P219A monitor to run and pass. :woohoo: I redo the injector balance test at this time, expecting a night and day difference. Nope! :silly: None of the old injector tips were dirty, and a fuel sample taken before replacement was clean.
So, my question is, how could I have positively ID'd an injector issue sooner? Just working down the list of suspects seems inefficient and costly to me. I use to have SOME faith in the Automated Injector Balance test. Now I have serious doubts.
What say you?
Also ran the same Automated Injector Balance test on a '13 Equinox with no engine performance issues, and it gave similar results to the problem car. At this point, I have almost no faith in the automated test. :lol:
PDM wrote: Also, why the difference in rail pressure between before and after?
Good question.
PDM wrote: Also, why the difference in rail pressure between before and after? I have no idea about how this test works. I'm just looking at the numbers.
Sorry, the pictures that I posted don't represent the test very well. :blush: Here's the graphed data of the PIDs provided while the test is running. The PIDs you can look at while the test is running are fixed and cannot be changed (on the Snap-On, anyway).
www.scanshare.io/share/JsRrT38rsEuE9GUX1aaogw
Without having a scope on the injectors and the high pressure fuel pump solenoid, I can't say EXACTLY what the PCM is doing during this test.
PDM wrote: Do you have a shot like that for "before"? You could probably see a sluggish injector with that
I'll dig it up! I have a tendency to hit 'Save' on just about everything I think might be relevant/interesting, but struggle to find what I'm looking for later. :silly:
Something I've noted about the way the Snappy runs this test - it keeps a history of the results of the last test, if you run the test multiple times per key cycle. You can see this in the graphs, especially injector #4. The previous test showed 59.4 PSI, but the latest test shows 68.4 PSI. The two tests were run seconds apart, so it's not like fuel temperature or engine conditions changed a lot in between. :dry:
I'm really tempted to pay for a GM subscription so I can compare the Snap-On to the GDS2, and maybe the Launch and Autel if I have time. Maybe this is a decent test? It just doesn't get implemented well by Snap-On.
Looks like it doesn’t have the resolution you need either.
Ben wrote: I have had no luck with snapon's automated test either I've had tons of the Chevy 6.0's with plugged injectors pass that test with flying colors...
Thanks for responding. The only 6.0 I've had with a suspected injector issue went to the dealer begging for goodwill, so I didn't get to see the result.
Wow. I was hoping for something, but that really doesn’t tell you anything
:lol: Yep! I got a hold of yet another '13 Equinox today, separate from all the others I've posted so far. Ran it's injector test - results were similarly inconclusive.
Also ran the same test on the Autel. Aside from displaying the results in kPa instead of PSI, the test results are largely the same.
'15 Silverado 5.3L has a recurring P050D Cold Start Rough Idle. Has a mostly dead misfire on #3 for about 30 seconds. Smooth otherwise. Here's a before of the Automated waste-of-your-time Injector Test.
After pulling the intake once to clean intake valves and a lot of testing, I get the go ahead to replace #1 and #3 injectors. Here's the automated test afterwards:
What a useless test. :silly:
Side note, I'm very happy with the test I came up with to pin this one down. Put the Pico TA204 secondary probe on the #3 plug wire, and put the AESWave Paddle Probe on the #2 plug wire (which never missed). During a cold start, engine missing away, I saw this on #2:
Textbook waveform. #3 showed this:
Lookin' lean. Secondary ignition FTW.
Tyler wrote: What a useless test. :silly:
TRUTH
- Thank you received: 961
Noah wrote: Pretty slick nailing it down with a secondary ignition trace.
I got lucky that it had plug wires. :blush: I dunno that a capacitive probe on a normal COP would have worked well enough...
